Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
Raypak BO 538 auto ignite fails in the morning,but starts manually when
The button is pressed and works well for the rest of the day,any comments are welcome
    Top Expert:
  • Raypak Master
  • 5,922 Answers
Check gas pressure possible too much demand in morning
Posted on Nov 07, 2017
2 Suggested Answers
  • 368 Answers
SOURCE: My Raypak 406A was out of propane. Now there is
Sometimes when either a propane or natural gas system has air in the lines they will not work. To be safe I would recommend you call the Raypak technical support line at 800-947-2975 or800-627-2975 and they should be able to help you figure this issue out. I hope this helps.
Please vote on this answer. Thank you.
Posted on Aug 27, 2011
My perguote 208year will not start until 34 turn over have to put foot on excelarater in mornings to start after that no probplem start right away till next morning same problem.
get ignition coil checked. If it is EFI DO NOT press on Accelerator when starting it.
Could have a leak in fuel and it evaporates over night
if carby fuel may be leaking out over night as vapour. In mornng you are fuel pump refilling fuel into carby until it starts again.
Mar 12, 2016 | Cars & Trucks
Raypak boiler BO 538 auto start fail to ignite in the mornings,
do you have this on a timer? if so run without timer if pump goes off and heater is on it will error out if keeps on check gas pressure to heater if too low it will error out
May 08, 2014 | Raypak Free Hydraulic Lift Gate Delivery -...
How to change the day
You posted under Aube timer.
If you have different brand timer, add a comment with clear description of buttons so I can find the correct model number and post best answer.
Open following link to download manual for your Aube timer.
http://waterheatertimer.org/Aube-timers.html
For example with Aube T1032: If you have different Aube timer, then open that manual for specific instructions.
Press PGM button to select Program1 ON.
So 1 and ON are displayed.
Press Day button to select choice of days for Program1 ON.
Press HOUR and MIN buttons to select ON time for Program1 ON
Next, press PGM button to select Program1 OFF.
Repeat steps for Day, Hour, MIN.
When program is finished, close and press the cover to return to normal operation.
Last, press and hold cover until AUTO is displayed, and now program will operate.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 25, 2011 | Aube Technologies Aube 7-Day 40-500w Light...
I am trying to st the timer to turn on at 5PM and turn off at 11PM.
You posted under Intermatic HB88RC timer
If you have different timer, add a comment
HB88RC timer manual:
http://waterheatertimer.org/pdf/hb88rc.pdf
HB88RC programming Instructions:
Install AA battery in timer so display will show, and you can program
Set clock:
Hold down clock button.
Press day button until current day displays.
Press Hour button until current hour displays.
Press min button until current minute shows.
Release clock button
Program timer:
Press PROG button until 1 ON displays
This is Event1 ON
Press Day button until selected day or days displays for event1 ON
If you want all week long, then press day button until all days show: MO TU WE TH FR SA SU
Press Hour button until 5pm shows >> this is event1 ON
Press Min button until :00 displays for event1 ON
Press PROG button until 1 OFF displays
This is Event1 ON
Press Day button until selected day or days displays for event1 OFF
Match days with ON time: so press day button until all days show: MO TU WE TH FR SA SU
Press Hour button until 7pm displays >> this is event1 OFF
Press Min button until :00 displays for event1 OFF
When programming is finished, press clock button to display current time
When programming is finished, press MODE button to select MODE > you want AUTO for timer programs to operate
Press MODE button once and this is manual override, and lights come on.
Press MODE button again and RDM displays, this is for random timer operation
Press MODE button 3rd time, and timer is set to AUTO
After setting MODE to auto, press clock button to display current time.
Plug timer into receptacle.
Plug lights into timer.
Dec 18, 2010 | Intermatic HB88RC - 7-Day Programmable...
I DON'T KNOW HOW TO PROGRAM THE TIMER I'VE LOST THE MANUAL. I NEED TO SET IT MON- SUN FROM 7PM TO 12PM IT SHOWS: 1 ON THIS IS WHERE I HIT HOUR & PUT 7:00PM THEN I HIT PROGRAM IT SAYS 1 OFF I HIT...
Here's HB88RC programming from the top:
Remove batrery from back of timer to reset timer and clear everything.
Re-install AA battery in timer so display will show, and you can program
Set clock:
Program timer:
This is Event1 ON
Press Hour button until 7pm shows >> this is event1 ON
This is Event1 ON
Press Hour button until 12pm displays >> this is event1 OFF
Add a comment any time.
A lot of folks have written in about this timer going bad and they have been unable to program the timer. Of course most timers work perfectly fine.
Same problem pool heater shows hayward pool heater bo error
BO means that you have bypassed operations. ie automation. if no automation is present then press and hold the Down arrow and Mode button for 3 seconds.
Aug 01, 2009 | Hayward H Series Pool & Spa Heater 400k...
Ignition locks up!
Try spraying a little lubricant in there, if you haven't tried already, like silicone spray. Make sure you push hard into park & press brake pedal harder as well, and wiggle steering wheel hard.
Jan 30, 2009 | 2001 Chrysler 300M
Maint. Required Lght on
Use the procedure:
1- turn off the engine.
2- press and hold the select/Reset button on the instrument panel, then
turn on the ignition switch ON (II)
3- Hold the button for approximately ten seconds until the indicator resets
Dec 18, 2008 | 2005 Honda Pilot
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
123 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
