Question about JVC HD-56G786 56" Rear Projection HDTV
Is there more than one lamp in a jvc hd-56786
    Master:
  • JVC Master
  • 688 Answers
NO!
http://www.shopjimmy.com/dlplamps?tv_brands_select=Jvc&tv_models=Jvc+HD-56G786
Posted on May 09, 2014
2 Suggested Answers
fieldy14
  • 456 Answers
SOURCE: rapid blinking light (lamp) on a JVC model HD
It normally means the lamp is in need of being replaced, and its all depending on the use of the TV as well as how long the lamp life is. You should be able to access the lamp via a small section near the rear or the back of the TV unit, if the lamp is blown or faulty it will look the same as a blown light globe.
To obtain a new lamp contact the brands authorised repair agent as they will be able to get trade prices and in turn, give you the best price,
Also make sure that whoever replaces the lamp resets the lamp use time as the TV will still not start if you don't reset the lamp use time as it will still think it has a faulty lamp. I hope this helps, good luck.
Posted on Dec 05, 2009
How do I change the lamp in my my JVC HD 61Z456 television
On the link below page 78/79 will tell you how to replace the lamp.
http://books.jvc.com/Download/642587931/LCT1928-001A-A.pdf
Good Luck and please rate 4 thumbs up for the free answer
Sep 30, 2010 | JVC HD-61Z456 Television
61 inch projection tv flashing on and off
The most common problem with JVC LCD rear projection TV is bulb failure. Do not panic, this is normal after 2-5 years of use.
You can change the complete assembly or for less cost just change the bulb. Do not use Osram or other funny brand "rebuilt" or locally made bulb. Use a Philips replacement and all should be good.
Changing the bulb involves removing the lamp assembly and taking it apart like a puzzle and replacing the bulb. JVC are a little more difficult to do than most others because the wires on the original bulb are molded into the glass on the original bulb. Wires must be cut and stripped of insulation before connecting to the new bulb.
All JVC LCD Rear projections TVs use TSCL110 TSCL110U TS-CL110U Lamps.
HD-61FB97 HD-61FC97 HD-61FH96 HD-61FH97 HD-61FN97 HD-61G587 HD-61G657 HD-61G787 HD-61G887 HD-61Z456 HD-61Z575 HD-61Z575AA HD-61Z585 HD-61Z786 HD-61Z886
Check this out for all JVC models to identify the lamp and bulb. JVC Gallery.
easyab
Apr 22, 2010 | JVC Televison & Video
Rapid blinking light (lamp) on a JVC model HD
Dec 05, 2009 | JVC HD-52Z575 52" Rear Projection...
Lamp for JVC HDTV model HD-56ZR7U
It takes the TS-CL110UAA LAMP.
Aug 18, 2009 | Televison & Video
JVC HD DILA 56G886. replaced lamp and now it shuts down after 10
we found that it is an auto shut off system on the TV due to over heating. The lamp, if not cooled correctly shuts down. We added a mini fan in the back and it seems to work fine now.
Jan 25, 2009 | JVC HD-56G886 56" Rear Projection HDTV
NO PICTURE OR SOUND
Hi
Usually, if the red light is flashing and you get no picture, that means that the lamp life cycle is finished and you'll have to get a replacment lamp. the lamp has about 3000 hours of life (2 to 3 years under nomal use).
You can buy a replacment lamp from here
http://cgi.ebay.com/NEW-DLP-LAMP-BULB-JVC-FOR-HD-61G787-HD-61G887-HD-61Z456_W0QQitemZ320274762989QQcmdZViewItem?IMSfp=TL0807151554r7572
Hope this helps
Cheers
Aug 10, 2008 | JVC HD-61Z456 Television
JVC HD-56G886
Call your cable company, the lamp has nothing to do with the inputs, Maybe one of the connections is barely connected from moving the TV to replace the lamp.
May 06, 2008 | JVC HD-56G886 56" Rear Projection HDTV
Jvc hd -61z456
These guys are correct, you need a new dlp lamp. The lamp # for your particular television model is the TS CL110UAA.
Apr 21, 2008 | JVC HD-61Z786 61" Rear Projection HDTV
JVC HD-56G786 56" Rear Projection HDTV Logo
60 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
