Question about Garden
Any info on a 24cc walbro Carb - Garden
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 221 Answers
There should be some stamped numbers on the carburetor. I would need those numbers. While the carb can be rebuilt I would recommend a new replacement as often times a small piece of debris is hard to find and clean out leaving you with a rebuilt carb that still does not function properly.
Posted on May 08, 2014
I have a 42' poulan riding mower w/ a 14.5 B&S engine, it has a Walbro carb...needing to replace the carb thats on it, I found that the Engine offered two different manufacturers of carbs?
i think walbro is a better carb. nikki is ok but just dont like them. it should be ok. why dont you just put a rebuild kit in the one you have? that is only $10.00 or $12.00
Jun 19, 2016 | Poulan Garden
I need manual for rebuild a 24cc walbro carb
Charlie:
When you buy the rebuild kit, the instructions should come with the parts. These carburetors are pretty simple, if you have a digital camera, you can photograph the disassembly and use the photos as a referenced to reassemble the carb.
May 08, 2014 | Garden
I need the settings for a 24cc walbro carb
Charlie:
Gently turn both screws in all the way, and turn each one out one and a quarter turns. the machine should start. adjust from there making small adjustments to either the fuel or air needle valves.
Pour gas in carb. will run few sec. replaced both gas lines and filter.
You will need to clean the carb or if this unit has a walbro carb buy a rebuild kit and it will work just fine.. Good Luck...
Mar 23, 2011 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
I am trying to find a diagram (exploded view ) of the Poulan BVM200VS carburetor . I took the carburetor apart to clean it and not sure which way to reassemble. Thanks for any help.
Hi again.
if carb is a zama, it is stamped on the bottome plate of the carb, if it isn't there its probley a walbro, which should be on the side of the carb in raised letters. I have rebuilt many of these carbs and have had very little luck in them working. Best to just stop fighting the bull and buy a new carb. They cost around 35 to 40 bucks.
I'm on yahoo as izuz1999, if i can be of any further help.
Sep 25, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Thottle will no stay in one position. There is a black spacer that slides over the throttle shaft between the shaft an the leaver. Will a new leaver come with that black spacer. Blower model wt200
Three (3) possible carbs were available on your machine.
If you have:
Walbro model WT-606 carb, the choke and throttle levers are available in kit form (which leads me to believe the spacer comes with them). Throttle lever kit part #530071726 and choke lever kit part #530071725.
If you have:
ZAMA model C1Q-W11 carb, the choke AND throttle levers are BOTH a part of the carb itself. (Would need a whole carb to get your part.) Complete carb part #530071465.
If you have:
ZAMA model C1Q-W11C carb, the choke and throttle levers are available in kit form (which leads me to believe the spacer comes with them). Throttle lever kit part #530071715 and choke lever kit part #530071716.
Hope this helps.
Oct 04, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Can't figure out type of carburetor on my leaf blower.
I have seen 2 different carburetors used on this unit. A Walbro and a Zama. You will need to get the information off the carb. (Walbro WYC-10 or Zama K39A) are the two I have seen, but you need to be sure what yours is. Then purchase the correct O/H kit and rebuild it.
Apr 10, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
