Question about GE GTDP300EMWS Dryer
Why does dryer only runs as long as start switch is depressed?
I can smell the heat, so the element is good. The drum turns so the motor is good.
  • 400 Answers
You give no information regarding make or model, but I believe you will find that the "run switch" on the motor is not working. This is a centrifugal switch located in or attached to the motor. With make and model, one could track down the part and replace it.
Posted on May 08, 2014
  • 1028 Answers
SOURCE: Ge Cloths dryer will not stay running or turn drum
probably broken belt some dryers have broken belt switch that shut dryer off if belt broke
Posted on Nov 25, 2008
  • 163 Answers
SOURCE: GE Profile Harmony Dryer DPGT750EC Drum won't turn & no heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
TheMobilian
  • 8220 Answers
SOURCE: GE dryer DDE5300 runs only
Broken belt. The safety switch will not allow the motor to stay running if the belt is broken. Open the door and look up at the 12 oclock position and their will either be 2 or 4 screws holding down the top. These must be removed and then you can get the top to come up(or off on newer models). Once you have the top up you can get to the screws which hold the front on (2). Then you simply remove the front and get it out of your way. On some these dryers there is a friendly rear hatch to help you replace the idler.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 09, 2009
hektor1961
  • 70 Answers
SOURCE: GE DRYER HEATING ELEMENT
Yes, the whole drum needs to be removed:
Before you go trough this make sure you know for sure your elements need replacement by checking for continuity at both element terminals.
Make sure you do the same with your high limit thermostat on housing.
How to remove the drum?:
Disconnect the power source to your dryer before you begin to remove the drum. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Pull your dryer out from the wall. Behind it, on the bottom, you will find a lower panel that will give you access to the unit's belt tensioner (also known as an idler pulley arm). Remove the screws holding this panel in place, and then remove the panel itself. Reach inside and release the belt tension by removing the belt from the motor pinion.
Older GE dryer models have a small drum bearing inspection plate in the center of the back of the dryer. This drum bearing inspection plate provides access to the dryer's circlip (also known as an e-ring). This clip holds the rear drum shaft in place. Newer models do not have this circlip or the drum bearing inspection plate.
If yours is an older GE model with an inspection plate, remove the plate now. It will be held in place with a single screw. With the plate removed, you will be able to see the drum support shaft and the e-ring (circlip) holding the shaft in place. Use a small screwdriver to remove the e-ring. You may also want to use a magnet to keep the circlip from falling into the dryer. You will also find several metal and nylon shims between the bearing and the e-ring, inside the bearing, and between the bearing and the drum. Take careful note of how they come off so that you will be able to put them back on again in the right order.
Now remove the front panel of the dryer. There are a couple of different ways this is accomplished. Whichever method you use is dependent upon your model. Some older models have two spring catch clips under the cabinet top, one on the left side, and one on the right side of the front. Use a putty knife, or some other flat and thin object to wedge in under the cabinet top. Release both spring catches and lift the cabinet top off the dryer. In some newer models, there will be screws joining the cabinet front panel to the cabinet top. You will have to open the door in order to find these screws. Once they are found, remove them and then slide the cabinet top forward and lift it off the unit.
Next, there are two screws located in the bottom of the front panel, one in each corner. Loosen these, but do not remove them just yet. Locate and remove the two screws at the top inside of the dryer's front panel. Again, there is one screw in each corner. Proceed to remove the other two screws you have just loosened. Disconnect the door switch wires and then lift the front panel off your dryer. With the front panel removed, lift the drum and slide it out of the dryer.
NOTE: In some models, you will have to remove the dryer drum glides before you can remove the drum. Also, now that the interior of your dryer is completely exposed, it might be a good time to vacuum out all of the dust and lint that has built up in there.
Posted on Aug 17, 2009
dmftrucker
  • 1922 Answers
SOURCE: i have a GE DWSR463EG2WW dryer 3 months out of
sounds like your motor start capacitor is defective, its usually mounted on the motor case and is cylindrical in shape and will have two wires coming out one end,unplug the unit and then take an insulated screw driver and short the two terminals of the cap before touching in case it still has some residual charge remaining
Posted on Sep 20, 2009
Asko t701 dryer burning smell
Loud noise is not a good description. What does it sound like? The dryer has a belt that turns the drum, the belt can wear and slip, there is a also a tensioner pulley on the belt system and then there is the motor that turns the drum. The smell could be from the belt, however you should know that dryers are not maintenance free and you have to clean them at least annually because they can build up lint in the cabinet and that lint can get into the heating element and it can start a fire.
Aug 19, 2016 | Asko T701 Electric Dryer
My Maytag Performa Dryer model PDET920AYW will heat but drum will not turn. Belt is not broken. Can you help?
It is possible that the motor start/run capacitor has failed, rendering the motor unable to get going. The capacitor will look something like this
http://como-reparar.com/guides/tumble-dryer-turning-find-fault-replace-motor-capacitor/
Jun 16, 2015 | Maytag Dryers
What causes Electric dryer to not start & run
Open the door and depress door switch have someone activate start button when humming rotate drum if it starts and continues to run replace motor
Apr 04, 2015 | Dryers
Dryer starts but will not stay running
This is what is probably going on. There are two parts in the motor that cause the drum to rotate.
One of them is "start" winding. It literally starts the drum's rotation. Once the drum motor has started the drum to move. The second portion of the motor, known as the "run" winding takes over and keeps the drum turning. When the Drum winding burns out. The same symptom is caused when the switch attached to the motor is also damaged. In your case, although this is rare. I think it may be the switch.
The reason being is that the motor has a combination switch that also connects one side to the heating element. In a nutshell, If you get the dryer not continuing to turn AND the heating element stays on. There is a problem with the switch.
If you get the heating element going on when you push the start button but turns off when you release the button. The problem is the motor having a burned out run winding. Either way, it is less labor intensive to replace the motor when you take it out. Doing it switch is not easy. Hope this helps. If not write back to me and we can continue.
HAVE A HAPPY NEW YEAR
Best, Mark
Jan 01, 2011 | Kenmore Dryers
Dryer won't stay going after button is released and the door safety button is still functioning, also the heating element is still working.
Best, Mark
Dec 28, 2010 | GE Dryers
Maytag dryer makes an electrical buzzing noise when start button
It sounds to me like the motor is not turning, but the heating element is coming on. with no air flowing over the element, it is getting too hot. Can you operate the start switch with the top tilted up so you can see if the motor is turning but the drum is not, and just where the buzzing is coming from. Also, I would try the dryer on manual setting and on air dry to see if any setting works. Good luck
Jan 07, 2010 | Maytag MDE6000 Dryer
Dryer powers up but won't start - smell of electrical burning. Is it the motor bushes? zanussi TC7103W
Electric dryers usually have a motor with a switch that prevents the heating element from being powered until the motor is spinning. In series with this are limit switches to prevent overheating if there is too much lint or too little air flow around the heating element. Also, the motors are induction or brushless. So the smell is coming from the heating element burning off some lint nearby as it reaches the high limit temperature and shuts off. This can be due to two conditions if we can assume the motor is running (has a switch that is closing to power the heating element). The most likely condition is that the drive belt is off the pulley or broken and the drum is not turning. You will be able to tell this easily by sounds or by opening the door to see the drum slowing down. If that's not it, examine the blower which forces air through the drum. There are a lot of variations, so look for air intake and drum exhaust ports that can be clogged with a sock, lint, etc.
Dec 12, 2009 | Zanussi TC7114W Electric Dryer
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Hoover Condensing dryer malfunction
Hi Mike,
The motor probably has experienced locked rotor current and fried the windings. Of course the capacitor could have shorted. If you can find it, look at the capacitor and if the can looks like it's lid is swollen or pooched out, then go for replacing the Capacitor. If you remove the motor and smell the case and it smells burned, you motor is shot. It does not have to lock down to be bad. The windings do not rotate in an AC motor.
Nov 02, 2007 | Hoover HDC6 Electric Dryer
GE GTDP300EMWS Dryer Logo
51 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
