Question about Dryers
What does a locked symbol on Samsung front load dryer mean?
Has a locked symbol and won't start how do I correct
3 Suggested Answers
jnchahn
  • 252 Answers
SOURCE: what does be2 mean on
You have a bad board. I recommended that you have professional come and replace. You are looking at about $125 or so to fix it.
Posted on Apr 30, 2011
ZJLimited
  • 17970 Answers
SOURCE: What does F-1 mean on
The "F-1" error code means a failure occurred with the electronic controls.. This could mean that wires are broken, the electronics shorted out or a manufacturer's default error shut the washer down.
Prevention/Solution: The electronic control panel needs replacement. Find your dryer serial number and search for the part online. This is a lengthy job that usually requires a repairman unless you have dealt with and repaired dryers before.
If your dryer was purchased within the past couple of years, the dryer could be covered under the warranty. Visit the Whirlpool customer service page for more information or Whirlpool-Duet-Dryer-fault-codes
Hope this helps.
Posted on Jun 02, 2011
What does The Hourglass symbol mean on a Samsung front load washer
The hourglass symbol usually means the machine is "Delayed" This might be because of a breakage or issue inside the machine. If this is not the case, check the user instruction manual
Oct 03, 2016 | Samsung Washing Machines
I am receiving an error message of L5 for my Samsung Dryer DV328AEW/XAA
I have uploaded the manual for this dryer to Fixya.com and the link to same is below. The following error information is on page 26 of the manual. Good luck to you:
INFORMATION CODES
Information codes may be displayed to help you better understand what is occurring with your Dryer.
CODE SYMBOL ( L5 )
MEANING
- Heater temperature control problem.
SOLUTION
- Call for service. See below. (see contact info in manual.)
Please let us know if helpful by clicking the button below, thanks!
http://www.samsung.com/us/support/owners/product/DV328AEW/XAA
7 3 cu ft Large Capacity Stainless Drum Dryer Neat White Samsung DV328AEW...
Jul 29, 2016 | Samsung DV328AEW Front Load Electric Dryer
Lock symbol is on but the door won't open
Hi Maire,
The door cannot open when the lock symbol is showing. Check your owner's manual for fault finding tips.
Aug 30, 2015 | Hotpoint Aquarius WD640 Front Load...
Light flashing won start
Common error with front loaders is the door interlock. Make sure the door is positively closed. A gentle open hand push at the erea of the door lock often gets a machine started.
Regards
John
Jan 30, 2014 | Kenmore Elite 45986 Front Load Washer
Error code LOC ?
LOC means that the control lock has been engaged. (This feature also keeps a child from changing any setting when a load is in progress or starting the dryer with the cat in the unit.) On at least one Frigidaire dryer, press and hold the Options and Select touch pads for at least 10 seconds (until the display changes) to toggle the lock on and off.
Usually, the two keys to press for the Control Lock will have a line between them with a padlock symbol in the middle of the line. (This symbol will be in a very small font.) This may help you find the keys to press if other models of Frigidaire dryers use a different combination of touch pads.
I hope this helps.
Oct 24, 2013 | Frigidaire Electric Dryer
Lock displaying symbol
Haven't done this exact model but usually it means keypad locked (child lock) should be in the manual how to unlock. Usually hold down a couple of buttons for 5sec.( most of the time a faint lock symbol will be written between the buttons on the button panel.)
Sep 23, 2013 | General Electric WCVH6800J Front Load...
Digital timer stuck on 10 min.won't start the spin cycle
I know this isn't the solution you were hoping for but here is the manual for your machine:
http://www.samsung.com/ca/consumer/home-appliances/washers-dryers/washers/WF203ANW/XAC-supportforward
You say it rotates L & R...do you mean it agitates but the timer isn't advancing?
Dec 30, 2012 | Samsung WF203ANW Front Load Washer
Door lock symbol showing on screen and door will
Assuming child lock is not on...Water not fully going away/ blockage @ filter.
Nov 02, 2009 | Hotpoint Ultima WDM73 Front Load Washer /...
The digital display is showing a KEY symbol flashing, and i can't program a new load. What does this mean?
This is the childproof lock symbol and prevents you from changing a program once it has been selected The symbol flashes if the program is changed during a wash cycle. If the machine is switched off mid cycle with the lock on then it will continue the program as so as the machine is switched back on. To activate the lock press the START button and hold for 4 seconds and the key is displayed. To deactivate the lock press the START button and hold for 4 seconds until the key symbol disappears.
Sep 30, 2009 | Bosch Exxcel WFX 2467 Front Load Washer
Dryers Logo
Top Dryers Experts
