Question about Garden
I need the settings for a 24cc walbro carb - Garden
    Sergeant:
  • 391 Answers
Charlie:
Gently turn both screws in all the way, and turn each one out one and a quarter turns. the machine should start. adjust from there making small adjustments to either the fuel or air needle valves.
Posted on May 10, 2014
I have a 42' poulan riding mower w/ a 14.5 B&S engine, it has a Walbro carb...needing to replace the carb thats on it, I found that the Engine offered two different manufacturers of carbs?
i think walbro is a better carb. nikki is ok but just dont like them. it should be ok. why dont you just put a rebuild kit in the one you have? that is only $10.00 or $12.00
Jun 19, 2016 | Poulan Garden
Any info on a 24cc walbro Carb
There should be some stamped numbers on the carburetor. I would need those numbers. While the carb can be rebuilt I would recommend a new replacement as often times a small piece of debris is hard to find and clean out leaving you with a rebuilt carb that still does not function properly.
May 08, 2014 | Garden
I need manual for rebuild a 24cc walbro carb
Charlie:
When you buy the rebuild kit, the instructions should come with the parts. These carburetors are pretty simple, if you have a digital camera, you can photograph the disassembly and use the photos as a referenced to reassemble the carb.
Need to find proper carb needle valve settings for case 444 Kohler
This is the Kohler K321 engine.
You can find the service manual here: (14.16 mb)
http://www.kohlerengines.com/onlinecatalog/pdf/tp_2379.pdf
The inital carb adjustment setting procedures start on page 29
Kohler carb low idle 2 1/2 turns from closed Walbro carb 1 1/2 turn from closed
Kohler carb high idle 3 1/4 turns from closed Walbro carb NA
Thanks for choosing FixYa,
Kelly
Jul 08, 2011 | Garden
Pour gas in carb. will run few sec. replaced both gas lines and filter.
You will need to clean the carb or if this unit has a walbro carb buy a rebuild kit and it will work just fine.. Good Luck...
Mar 23, 2011 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
I am trying to find a diagram (exploded view ) of the Poulan BVM200VS carburetor . I took the carburetor apart to clean it and not sure which way to reassemble. Thanks for any help.
Hi again.
if carb is a zama, it is stamped on the bottome plate of the carb, if it isn't there its probley a walbro, which should be on the side of the carb in raised letters. I have rebuilt many of these carbs and have had very little luck in them working. Best to just stop fighting the bull and buy a new carb. They cost around 35 to 40 bucks.
I'm on yahoo as izuz1999, if i can be of any further help.
Sep 25, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Thottle will no stay in one position. There is a black spacer that slides over the throttle shaft between the shaft an the leaver. Will a new leaver come with that black spacer. Blower model wt200
Three (3) possible carbs were available on your machine.
If you have:
Walbro model WT-606 carb, the choke and throttle levers are available in kit form (which leads me to believe the spacer comes with them). Throttle lever kit part #530071726 and choke lever kit part #530071725.
If you have:
ZAMA model C1Q-W11 carb, the choke AND throttle levers are BOTH a part of the carb itself. (Would need a whole carb to get your part.) Complete carb part #530071465.
If you have:
ZAMA model C1Q-W11C carb, the choke and throttle levers are available in kit form (which leads me to believe the spacer comes with them). Throttle lever kit part #530071715 and choke lever kit part #530071716.
Hope this helps.
Oct 04, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Parts number
You need to know if it is a walbro or a zama carb. to start with.
then look closely at the carb. and find #`s
very small
walbro will be wt or wa then some #`s
zama will be c1q or c1u and some #`s on the opposite side of carb.
Walbro will be on the same side
you need to know the carb. #`s so a kit can be found for that particular carb. IE: complete kit or diaphram kit
May 20, 2009 | Homelite Consumer Products MightyLite...
Garden Logo
44 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
