Question about Sharp AR-M205 Copier
H4 error for sharp ar-5316e
How can I fix?
    New Friend:
  • 91 Answers
Try reset the code by pressing [#] [Interupt] [C] [Interuptr] [14] [COPY/START]
If error still exist, check the thermofuse and the heater lamp
Posted on Jun 23, 2009
SOURCE: MY SHARP AR-5316E DISPLAYS H4 AND IS NOT WORKING
Dear friendscom, H4 :Heat roller abnormally low temperature.
__ possible cause __
  • Thermistor failure
  • Heater lamp failure
  • Thermostat failure
Perform the following procedure to reset the code:-
"#" key-- Interrupt key-- "C" key --Interrupt key--14--print
Posted on Jan 12, 2011
SOURCE: Sharp AR-5316E Error CODE U-2
error code u-2
Posted on Mar 14, 2010
007tech
  • 95 Answers
SOURCE: My sharp ar-5316e photocopier displays H4. what should i do
The H4 means "Heat roller low temperature detection"
Basically the fuser is not reaching a specified temp within a specified time frame. There are several causes/posibilities :
Thermistor abnormality
Heater lamp abnormality
Thermostat abnormality
Control Board PWB abnormality
or it is just a one glitch and it can be reset.If re-seting the copier does not work then it could be something physically wrong.
To clear error go into SIM mode by pressing the following keys one after the other "#" "interupt" "C" "interupt" (must be in copy mode to start off). enter 14 and start key. Confirm if requested to do so. copier must be restarted when this is done. Do not play around with any other settings in SIM mode.
If error persists then one of the above items is at fault. you could pull out the fuser unit and open it up to check for any dirt/debris buildup around the thermistors/thermostat.
Hope this will help.
Posted on Apr 10, 2009
  • 7 Answers
SOURCE: I have a sharp copier, model AR-285, H4-01
H4 error pertains to lamp errors.
that would either be the copy lamp or the heater lamp.
check both lamps.
with heater lamps,it's usually caused by either a broken heater lamp or a dirty thermostat on the heater roller assembly.
Posted on Jun 10, 2009
  • 109 Answers
SOURCE: Sharp Copier AR-286 Error Code H4-01
you can remove this error by enter the sim14.
Posted on Apr 08, 2010
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
Jan 12, 2011 | Sharp AR-5316 Advanced Digital Imager...
H4 error on SHARP AR-5316E plz help
h4 refers to the fixer/fuser, check to see if there is a paper jam in it
Jun 03, 2010 | Sharp AR-5316 Advanced Digital Imager...
check both lamps.
Jun 09, 2009 | Sharp Office Equipment & Supplies
Code H4 comes up when the sharp copier ar-5316 is switched on. it cannot be use. what shall I do to solve this problem of error code H4.
Hello sir; H4 code require reset procedure as follow;
1, press"#" "interupt" "c" "interupt" these 4 keys.
2, enter 14 , then press start
3, turn power off and back on .
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Is showing me H4 i need the solution now
Dear sir; H-4 Means heat unit problem, try to reset first,follow the steps as below;
1, press "#", " interupt", "clear", "interupt".
2, enter 14.press start.
3, power off and back on again.
If can not be reset then you have go to check the heater lamp, thermos fuse or thermister,
If you need more help let me know I'm alway here. Good luck, don't forget give me a good rating.
HAVE A HAPPY HOLIDAY !!!
Dec 21, 2008 | Sharp AR-5316 Advanced Digital Imager...
HELP, H4 ERROR
The fuser isn't heating up on time. You could try turning the copier off for 30 seconds and turing it back on again to see if it goes away.
If it doesn't happen, there is a part that has to be fixed on the fuser to correct the problem. Usually it is the thermistor.
Aug 16, 2008 | Sharp AL 1215 Black and White Copier
HELP, H4 ERROR
H4 is normally caused by the fuser taking a little longer than normal to warm up. Most of the time it is not caused by the hear rod itself. I will send you the process here is a few minutes.
Jul 24, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M205 Copier Logo
1,254 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
