Question about Kenmore Dehumidifiers
Kenmore dehumidifier stops running
I have a Kenmore dehumidifier, 580-52450200. It runs for about 5 minutes then shuts down. If I turn it off for a few minutes, it will turn back on and after about five minutes, shut down. Both the fan and compressor are affected. I removed the cover and vacuumed it very well, including the humidity sensor. I ran it without the cover, and it stayed on and seemed to work fine. I put the cover back on, and the problem returned. Water collects in the bucket fine, the suction line is cold, the liquid line is hot. Not sure what's telling it to shut down. Your help is appreciated.
  • 883 Answers
SOURCE: No water collection
compressor may be starved for freon or blockage in freon line...tech must troubleshoot.
Posted on Jun 08, 2007
SOURCE: runs for a couple of minutes and then stops
Try cleaning out the air filter using cold water. I did not even know the unit had one until I had the same problem. Pull out the bucket. The filter is located where the front top edge of the bucket would be located if it were in the instrument. Remove it by pulling straight down. It may be taped to the instrument for shipping purposes. According to the manual, this should be done every month. I have had the machine since Katrina and this is the first time I have had a problem. Hope this helps.
Posted on Aug 19, 2007
SOURCE: Kenmore 580-51650000 dehumidifier
It is more than likely the compressor is not running, only the fan.
It seams that the humidity sensor is flaky on these units. You can,
operate the unit, by opening up the dehumidifier and unplug the sensor from the main board. The unit will cycle on and off and remove the water from the air.....good luck
Posted on Apr 21, 2008
22yooper
  • 828 Answers
SOURCE: Dehumidifier Error?
Your bucket full switch may be defective. If you are capable, bypass it since you are draining to another place other than the bucket.
Posted on May 09, 2008
  • 121 Answers
SOURCE: Dehumidifier runs but does not condense water.
It sounds like an issue with the control bord. This dehumidifier should have a 5 year warranty through LG. You will need to have this serviced. If it is under warranty by LG they will either refer you to a local repair shop and they will pay for the repair or they will replace it if you do not have a repair shop in your area. Call them and explain the problem to them. Make sure that you have your reciept. Here is the contact information for LG:
Toll Free Phone Number: 1-800-243-0000
Email: customerservice@lge.com
Keep me posted. If you found this solution helpful please rate it when you get a chance. Thanks - Tech101
Posted on Jul 08, 2008
How to repair my kenmore 58054501500
ck the water catch bucket , sometimes ive seen machines stop after running a few minutes because it shook catch bucket from its perch
Jul 16, 2014 | Kenmore Dehumidifiers
My kenmore 70 pint dehumidifier turns on but will run for two to three minutes and then it turns itself off. Is there a sensor that would have stopped working? My email is mkemusic@sunlink.net
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 24, 2010 | Kenmore 54501 Dehumidifier
Dehumidifier runs for approx. 15 min works fine then shuts off and doesn't come back on.
run it without the filter with a 1 part vinegar 4 parts water. then try it with a clean or new filter. You may need to run it a few (5-6) times before it stops shutting off by its self.
Aug 22, 2010 | Kenmore 54351 Dehumidifier
When its turned on the fan runs for a minute and shuts off. It hasnt cycled since.
There are many reasons for a dehumidifier tto not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Apr 18, 2010 | Kenmore 54351 Dehumidifier
Kenmore dehumidifier M/N 580.53650200 only runs for about 1 minute, then stops. Dehumidifying level is set to minimum (40) and it's damp in the basement so I know the air is not too dry. The fan works, the...
Well to knowledge the problem 40 percent is dry. means your basement is great. humidity should be 30/50 percent 50 grows mold. also if it runs for a min the auot shut off is activating. check this first.
Manifestr
Oct 06, 2009 | Kenmore 5365 Dehumidifier
Dehumidifier model M7DH65b 2A
Its too old where you are running the appliance - lift it up in the air or raise the heat in the room. This is *not* a low-temp dehumidifier.
Jun 09, 2008 | Maytag M7DH65B2A Dehumidifier
Dehumidifier
IS THE ROOM HUMIDITY LOW. IF IT IS BELOW 30% THE HUMIDISTAT WILL SHUT DOWN THE UNIT. THE AMMBIENT TEMP SHOULD BE ABOVE 65 DEGREES AND THE HUMIDITY SHOULD BE ABOVE 50 %.
Mar 26, 2008 | Kenmore 53301 Dehumidifier
Dehumidifiers Logo
141 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
