Question about Human Touch Back Pad Massager with Heat Black HT1470
Heat function on Sharper Image Shiatsu Massager Pad Stops Working
The heat function used to work with the rod glowing red. It has stopped working altogether after only 10 usages. Can it be fixed and how?
Thanks
MCS-490H
Is it possible that there are differences in power sources between where you originally used your massager and India? The massager may have lasted just long enough in the new environment to fail.
Dec 10, 2013 | Homedics Shiatsu Massager
I'm having a problem with my Homedics SBM 300H Massager. I was using it when it suddenly stopped, after hearing a faint "pop" sound from it. I tried re-plugging it in another outlet but still no...
Yes there was a short circuit and am sure the massager and the cpomputer where plugged in the sane extension box that was why there was loss of power when the massager stopped working.For the massager it is the fuse so get a new fuse for it.
Jan 21, 2011 | Homedics SBM 300H Therapist Select Shiatsu...
Can Homedics Therapist Select? Shiatsu Pillow with Heat be used under 220 V power? Thanks
If it is set up for 110 volts, you should not use it on 220. Most likely you will burn the motor out in a matter of minutes.
Jan 24, 2010 | Homedics PA-4H Programmable Percussion...
My homedics back massager with heat, stop working all of sudden, does it needs battery even though it has an electric cord.
the back massager with heat stopped working, bought a new power cord, still does not work, must be something in the back massager, but what to do ? ken
Mar 02, 2009 | Health & Beauty
Homedics programmable percussion massager with heat
The motor is Jammed
Try Taping it or banging it lightly
if that don't work im sorry ether needs repair or buy a new one
Regards; Aaron
Sep 15, 2008 | Homedics 10 Motor Back Massager with Heat
Massager support
Keep the massager still on the one spot for approximately 30 seconds then move it onto the next part that needs massaging
Aug 27, 2008 | Human Touch Back Pad Massager with Heat...
Human Touch Back Pad Massager with Heat Black HT1470 Logo
108 people viewed this question
Top Human Touch Health & Beauty Experts
Michael Vincent Cruz
NOEL
NOEL
Are you a Human Touch Health and Beauty Expert? Answer questions, earn points and help others
