Question about Westinghouse Electric Dryers
How do you remove the cage for a westinghouse fan model Y-4692
I need to get the cage off to clean fan. I have no clue any one that can offer help. Also how do you get to the motor?
4 Suggested Answers
SOURCE: Vintage Oscillating Electric Table Fan ~ Repair & Service
go to this link, hope you might find something useful.
http://www.hudsonscustommachining.com/FAQs.doc
or you can go to this URL http://www.vintagefans.com/contact.htm and post your question there.
Posted on Sep 29, 2008
  • 360 Answers
SOURCE: Can't seem to remove the exhaust fan - I don't see any screws?
on most of these units, there are tabs that hold one side in place and across from them is a detent that needs to be physically moved out of the way for the motor to swing down (uses the tabs as hinges), once the motor mounting plate swings down the tabs will slide out of the slots and the motor is out of the unit.
please take the time to give this solution a fix ya rating.
clarkco
Posted on Mar 19, 2009
  • 273 Answers
SOURCE: We have an old Westinghouse
There are many sources for antique fans and their parts. I cannot list them all, but here are a few:
http://www.afcaforum.com/
http://www.fanmanusa.com/
http://www.vintagefans.com/index.htm
http://www.fanaffairantiquefans.com/
http://www.fancollectors.org/
http://www.collectibledetective.com/s/370/antique-fan.html
Good luck from Detroit, MI.
Posted on Jul 11, 2011
How do I take apart to clean fan part real black
Hi Sherin,
You have to remove the screw or undo the clip which locks the front half of the fan cage to the back half. Then you can split the cage open, exposing the fan. You should be able to remove the fan impellor itself either by just pulling it off or by undoing a screw. Once cleaned, reverse the order to reassemble.
Jul 26, 2015 | Dryers
How do I clean dryer squirrel cage?
To remove drum/fan drive motor:
• Remove rear panel & rear air duct. Remove belt from belttensioner. Remove top panel & drum if needed for better access.
• Disconnect terminal connector from motor, then remove two screws from motor mount & one screw holding fan to front shield. Lift rear of motor mount up and slide entire assembly toward rear of dryer.
• While holding motor shaft, not rotor fins, remove fan blade from motor shaft. Remove three screws, then remove fan housing from motor.
• Remove spring clamps by pushing ends of them down and away from motor. Lift motor up from motor mount.
Cage motor is the best blow out with compressed air. Also, by the way, clean the fan housing from the inside.
Dado
Nov 16, 2014 | Bosch Dryers
Clean fan
Flip open the latches around the cage to open that part up. Once open, turn the knob in the middle of the blade to the right. Normally iyou turn it left, but on this ne you turn right. That enables yo to remove the blade. Behind the blade is a rather large plastic nut, which you turn to remove and that takes the back part of the screen off. Use your vacuum to vacuum out the dust from the motor, the cages, and the fan blade. After that use a mild soap and water solution to wipe off the rest. I found it very helpful if you use a thick wet hand towel to clean the wire cage. It cleans it very well! Then just put it all back together again and your fan will look brand new.
May 30, 2012 | Holmes Products HANF96 Table Fan
I do not know how to clean this fan. Do I need any tool for cleaning this fan? Thanks
generally a soft brush should work fine. Also if you have it compressed air will help. this can be doen without opening up the cage. but opening up the cage might make it easier
Aug 28, 2011 | Vornado VF20 Table Fan
How do I clean a Hawaiian Breeze tower fan?
Unplug fan. Lay the fan face down. Remove the four screws holding the stand to the base. Slide the stand all the way off the cord. Look at bottom of fan and find the small half circle indent just to left of center. There is a screw there, remove it. Go to the hand grip at the top of the back and pry out the two white rubber plugs to reveal two more screws, remove them. Back cover can now slide downward. May take a little squeezing at the center of the grille where internal clip is. Remove two screws at top of squirrel cage. Turn squirrel cage and loosen screw at bottom collar on motor shaft. Tilt the top of the squirrel cage outward slightly and slide upward to remove the squirrel cage. You can slip upper metal bracket off and set aside. Motor is held in by two screws, remove them and flip motor out of the way. There are two screws below where motor sat that hold in base of front grille, remove. Front grille has a series of clips along edges, carefully pry them inward from bottom to top and push grille gently outwards. You can now clean the rear grille, front grille and squirrel cage in warm soapy water and allow to dry. While they are drying, use a vacuum and dust rags to clean interior. When parts are dry, reinstall front grille and reinstall 2 screws. Reinstall motor with two screws. Turn motor shaft so flat notch is pointing up. Recommend to spray a tiny bit of WD-40 or a tiny dab of moly grease on shaft at top of squirrel cage, then replace upper bearing bracket on top shaft. Slide collar end of squirrel cage onto motor shaft and align screw with shaft flat and tighten. Reinstall two screws at bracket at top of squirrel cage. Align back cover just a bit toward bottom, then slide upward and clips will snap into place. Reinstall two screws in hand hold area, then reinstall screw at bottom of cover at half circle notch. You'll need either a magnetic tip screwdriver or a pair of long needle-nosed pliers to get screw in hole before tightening. Feed cord back through base and reinstall 4 screws. It took me about half an hour to do this whole process on each of my two Hawaiian Breeze fans, but they now look brand new and run very quiet.
Aug 05, 2010 | Tower Aloha Breeze Fan
DEll E310 fan make strange noises at various times. How can I replace the fan?
You didn't state which version you have, Slimline, Mid-Tower, or Desktop.
I'll give you the link to the Dell Dimension E310 Service Manual, and we'll go from there,
http://support.dell.com/support/edocs/systems/dim3100/en/sm/index.htm
FIRST:
Computer off, unplug the power cord from the surge protector, FIRST, then unplug the power cord from the back of the power supply. (Back of computer)
Unplug all cables connected to the computer. If you are not 100 percent sure where they plug into, now is the time to make yourself a chart, and add notes.
Work on a table, open the computer case.
(Cover Release Latch button on the rear of the computer, top side. The Right side cover opens.
Tilt it out, lift it up to remove. Or on the Service Manual main page, scroll down to Removing the Computer Cover, and left-click on it)
With the computer cover open TOUCH the metal frame of the computer case, to relieve your body of Static electricity.
(Static can fry out your computer's hardware components, and you probably won't see it, or feel it)
1) The Floppy Disk cable has to be partially removed.
2) The Processor's Heatsink Assembly has to be removed.
3) The SATA harddrive cables, need to be slipped out of the top of the Fan assembly cage's, squeeze connectors.
(This will make more sense, once you view the SATA harddrive's cables, and where they go across the Fan Assembly)
4) Then you can access the Fan Assembly, to get to the Fan.
A) With this Dell Dimension model, you have to remove the Floppy Disk flat ribbon cable, to access the Heatsink assembly, that sits on top of the Processor.
Remove it from the Floppy Drive ONLY. (Not shouting) Leave the cable connected to the motherboard.
You also have to slip the Floppy Disk's flat ribbon cable, out of the connector tang, that is on top of the Processor's Heatsink assembly.
(Flat steel tang, that is part of the Heatsink Assembly's frame, or cage. Pull up on the side that faces the rear of the computer, slip the Floppy Drive cable out)
This information is more easily seen, if you view the illustrations for - Removing a Floppy Drive.
On the main page of the Service Manual, scroll down to Removing and Installing Parts, and left-click on it.
On this page scroll down the left column, and left-click on - Floppy Drive
B) Removing the Processor Heatsink Assembly:
The Processor Heatsink Assembly is essentially a U shaped metal cage, that has a Heatsink attached to it.
There are 2 screws that hold the front of this metal cage down, and when removed, the cage itself tilts towards the Back of the computer.
(You may have to remove the Power Supply, to access the top screw of the Heatsink cage, or use an Offset screwdriver)
The tangs are triangular shaped, and are on the bottom of the metal cage, towards the Front of the metal cage.
The metal rectangular cage tilts back on two pivot pins, then it can be lifted up, and off.
In Removing and Installing Parts, left-click on Removing the Processor, for illustrations. (Or scroll down the page to this heading)
C) Removing the SATA harddrive cables, out of the connectors on top of the Fan Assembly:
This can be more readily seen by clicking on -
Installing a Harddrive, in Replacing and Installing Parts.
D) Now you can access the Fan.
The Fan is inside a shroud. The shroud is held to the Fan Assembly cage by plastic tangs, that are part of the shroud.
The tangs go through slots on the plastic Fan Assembly's cage.
The tangs are squeezed in, so that the hook end of the tang is able to slide out of the slot.
(It may be that the tang is pried towards the outside, so that it will clear the slot)
It's a lot of fun(?) trying to keep to tangs squeezed, so that you can slip one side of the Fan shroud, out of the slots.
This should release tension so that the other side's tangs will be able to slip their corresponding slots.
Buying a replacement fan will require a little homework, and searching various websites that offer a compatible sized fan. (Or peruse your local Mom and Pop computer repair shops)
You need to know the diameter of the Fan, as well as the thickness, (Or depth), of the shroud that surrounds the fan.
Also what type of connector it uses. 2 pin, 3 pin, or 4 pin.
The size of a fan, and the thickness of a Fan shroud, are usually stated in Millimeters. If you use the Inch system, go online, and use a free Millimeter to Inch Converter.
Here is one example, of a website that offers computer case fans,
http://www.directron.com/casefans.html
BEFORE you reinstall that Processor Heatsink Assembly! (Not shouting)
You MUST clean the top of the Processor's case, and the bottom of the Heatsink that sits on the Processor.
You will either see Thermal Paste, or a Thermal Pad.
If it is a Thermal pad, remove it, throw it away.
They are Junk, and cannot be reused!
I use an old credit card to scrape the top of the Processor's case, and the bottom of the Heatsink.
Stiff plastic, and is anti-Static.
I use Isopropyl Alcohol with Q-tips to clean the remaining thermal paste residue off.
(Rubbing Alcohol. 91 percent alcohol, or better is best)
Usually takes quite a few Q-tips, dipped in alcohol to do this.
Both surfaces must be CLEAN!
CAUTION!
Isopropyl Alcohol is EXTREMELY FLAMMABLE, and burns clean. The flame is virtually colorless. Use in a well ventilated environment, and with no sparks, or flames present.
The top of a Processor's case, and the bottom of a Heatsink are not perfectly smooth. To the human eye they may seem so.
There are microscopic pits, and valleys. These create Air Pockets.
Air is an Insulator, not a Conductor.
Thermal paste fills these voids. Thermal paste is an excellent Conductor, and transfers heat well.
The heat Must be transferred from the Processor to the Heatsink, so that the fan will transfer the heat away, from the fins of the Heatsink.
When a Processor becomes too hot, it turns off. (BIOS turns it off)
This is a Fail Safe feature that is built-in, to keep the processor from burning up.
Jan 31, 2010 | Dell Dimension E310 PC Desktop
Cleaning a 14F0 Honeywell Fan
thank you for using fixya. The blade cage has locks and screws that you can remove from the back. once the cage has been removed, you can remove the blade attached to the motor using a vacuum cleaner or you can remove the blades by undoing the screw on the center detaching it from the motor.
Jan 04, 2009 | Honeywell HV-180 Floor / Box Fan
Ceaning inside of fan
With a little more detail on how to clean the 84001. There are 2 screws at the top of the unit on the back side and 1 on the bottom with a small removable cover. Remove those screws and the cover can be removed.
There will be some resistance towards the middle because of 2 clips on both sides. Be carefull not to pull too hard on the ends ; possibility of breaking the cover. Try pressing on center of the cover on one side of the edge.
There are 2 screws holding a bracket that holds the top of the fan. Remove those screws. Then on the bottom there is a shaft that attaches to the motor. You will find a set screw that you need to loosen. When you loosen and remove squirrel cage you will notice a flat spot on shaft. That is where the set screw is to be put when assembling the fan back together.
After cleaning just follow the steps back to assemble your 84001 and enjoy a clean brisk breeze. I hope this helps explain in more detail on how to clean it.
Oct 13, 2008 | Tower Aloha Breeze Fan
Dryers Logo
48 people viewed this question
Top Westinghouse Electric Dryers Experts
Dan Webster
Dan Webster
Are you a Westinghouse Electric Dryer Expert? Answer questions, earn points and help others
