Question about Hunter 23534 Oceanus Graphite Ceiling Fan
I have 23534 fan i need to change to a new remote control
Do I change from ceiling or just above the light under glass
    Genius:
  • Hunter Master
  • 1,617 Answers
The receiver would be in the top of the fan housing.
Posted on May 08, 2014
SOURCE: ceiling fan
hi you have a problem with your fan do you have the remot book how to operate the fan remote we lost the booklet for the instruction maybe you can send me a copy of your booklet instruction for the fan is your fan is from the compagny home collection and the brend or model tampa thank you
Posted on Nov 25, 2007
johnny5846
  • 379 Answers
SOURCE: ceiling fan remote will not turn on light
common problem , i went to home depot and bought a new remote for my hunter fan , and it worked again , salesman was very knowledgeable and helpful . thanks. explain the problem to him , he can help .
Posted on Dec 30, 2008
  • 3 Answers
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Posted on Sep 07, 2009
  • 2841 Answers
SOURCE: remote control will not turn on/off fan or light.
The transmitter is the remote. The receiver is located inside the fan mounting bracket next to the ceiling. If you replace it make sure to set the dip settings on the new receiver exactly as they are on the old one. Wire the new receiver exactly as the old one is wired if it was working before.
Posted on Nov 07, 2009
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
it also could be one of the the jumpers fell out of the remote
they are located just above the battery. you will need to match the placement of the jumpers with the receiver mounted in the fan.
Posted on Mar 09, 2010
Hardwired ceiling fan turned off by itself and stopped responding to remote control, but the light turns on/off.
I've had problems with Minka Aire also. You might need a new receiver. Call Minka @ 1-800-307-3267 and talk to someone in tech dept.. Should be a one year warranty on the receiver.
Aug 17, 2015 | Minka Lavery Minka Aire F888-BNW...
I need a light kit for hunter fan model #23530
  1. Hunter Fan - Accessories
    www.hunterfan.com/Accessories
    Need more control? We have many universal remotes and wall control options for yourfan and light ... Customize your lighting. Add a new light kit or change the lighting hardware on your fan. Complete light kits. Need lighting parts? Glass and ...‎Complete Light Fixtures - ‎Controls - ‎Glass/shades
Jul 09, 2015 | Hunter 52" Ceiling Fan With Light And...
What causes light flickering in Hunter Oceanus ceiling fan?
Might need a new receiver. I have one if that's your problem. fanman9952@aol.com
Sep 06, 2014 | Hunter 23534 Oceanus Graphite Ceiling Fan
Where to purchase replacement remote
I have a receiver unit for that fan @$79.00 + shipping.
fanman9952@aol.com
Remote controlled ceiling fan not responding
most problems with remote controls cannot be repaired outside of what is suggested above. If you have problems, contact the manufacturer, perhaps the fan is under warranty, or parts are available. Otherwise chances are the fan will stay broken.
ceiling light
May 23, 2012 | Dryers
I can still control the Fan function with remote, but can no longer turn the light on. I installed a new bulb and even new battery in the remote. The light still doesn't turn on. Also cleaned remote as...
Howdy,
Is it possible this fan also has a pull chain switch for control of the light? If not, it sounds like the light board in the receiver has burned out, which is a fairly common issue. If the above does not work, call Hunter at 1-901-745-9222, a direct line to tech support. Be sure to have your fan model # ready as they will need it to get your correct receiver. If it's under a year old they should give you a replacement provided you can provide proof of purchase.
Sep 22, 2010 | Hunter 52" Ceiling Fan With Light And...
Changing the light in a 54shrl
Redington III. The remote receiver is integral to the light kit. There is no replacing the light kit, you can, however change out the glass, but you're stuck with what you got.
Apr 01, 2010 | Hampton Bay 52 In. White Redington...
The remote control works other than changing the direction of the blade. how do i manually change blade direction?
Look on the side of the Fan above the light fixture there is a little black switch you just need to switch it, make sure the fan is off before switching it.
Jan 11, 2010 | Hunter 52" Ceiling Fan With Light And...
Aug 13, 2009 | Hunter Ceiling Fan Remote Transmitter...
Ceiling fans on same frequency
There should be dip switches in/on both the remote control and the ceiling fan that enable you to change the control frequency. The only thing that you have to ensure is that the two components are set to a matching frequency.
The switches in the remote are located in the battery compartment just above the batteries. Remove the dome on the ceiling fan and you should find the switches for that unit. Just compare the two and match whatever changes you make from one unit to the other.
Originally answered by d0n0r in this question
May 25, 2009 | Universal Remote Control Hampton Bay...
Hunter 23534 Oceanus Graphite Ceiling Fan Logo
131 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
