Question about Garden
My ryobi rt190/also has sticker that says electrolux 96016000400,will not move when transmission is disingaged with lever on back
When jacked up both wheels turn in different directions
  • 86 Answers
SOURCE: rear wheels locked
To move tractor you can remove one of the back wheels and remove key in shaft then replace wheel you should be able to move it .
Posted on May 12, 2009
  • 218 Answers
SOURCE: I HAVE A RYOBI RT190 RIDEM MOWER AND I HAVE NO
I would suspect a blown fuse or a bad ignition switch..or a bad ground from the battery to the frame..i hope this helps...Keith
Posted on Jul 01, 2009
  • 66 Answers
SOURCE: Possible transmission problem
As far as the tires turning in the opposite direction when hoisted in the air...their suppose to do that so your fine there. Can you give us a bit more to go on than it wont start? Will it turn over? There are usually two reasons why an engine won't start...spark & fuel. If either one of these are not present...no go. www.nnyparts.com
Posted on Jun 01, 2010
  • 252 Answers
SOURCE: My new zero turn simplicity
hi there Brian 357638
sounds like you have a safety switch problem
try disconnecting seat switch and retry if works could be wire grounding some where or faulty switch then try fitting a jump wire to seat switch wire connector retry or you have a blade engagement switch playing up or a nuetral switch playing up but more likely a seat switch
take a look
cheers pauly46
Posted on Jul 03, 2011
philwalker78
  • 608 Answers
SOURCE: Lawn Tractor Model 917.273338, auto
Hi, gearshift will not move because the brake lever is frozen. To fix your problem, remove the short brake lever(half inch socket I think), remove the brake pad housing under it(seven sixteenth socket). Inside this housing are two pins that need to be free and greased. Knock them out and clean them with every paper, also clean the holes they slide in with a drill bit. Reassembled and adjust the half inch nut so that the brake lever rotates quarter of an inch before it activates the brakes. Hope this helps, regards Phil.
Posted on Jul 06, 2011
2003 Ford Escape car was in park and moved into reverse but car moved forward instead
Most transmission control lever with cable lock bolt become lose in time need to re adjust position to the right place and tighten the bolts ,it can easily done by jacking up the suv and look under the transmission .
Nov 18, 2017 | 2003 Ford Escape
How to adjust transmission cable to shift right
Turn the ignition key in a clockwise direction until it reaches its first position, meaning the position the key occupies before it begins to crank the engine if turned further, then move the transmission's shift knob to the "D" position. Turning the key to this position is necessary to unlock the transmission's shift knob. The engine need not be started to adjust the transmission's cable.
Jack up the vehicle with a shop jack, then lower the car onto safety stands to increase the workspace underneath the transmission.
Loosen, but do not remove, the single nut which attaches the end of the transmission's shift cable to the driver's side of the transmission with a wrench.
Position the shift lever on the side of the transmission, where the end of the shift cable attaches to, to the "drive" setting by first rotating the lever in a clockwise direction until the lever stops. Slowly rotate the lever in a counterclockwise direction. As the lever is rotated, it will click. The first time the lever clicks, the transmission is in second gear. The second time the lever clicks, the transmission is in the "drive" position.
Tighten the single nut which attaches the end of the transmission's shift cable to the transmission's shift lever to between 10- and 20 foot-pounds of torque with a torque wrench.
Lift the vehicle with the jack and remove the stands, then lower the vehicle to the ground.
I hope this helps.
Nov 30, 2010 | 1997 Mercury Cougar XR7
I can't disingage the lever to cut grass on my craftsman riding lawn mover. Now because of this I can't start the mover.
the lever moves an arm on the deck connected to a pivoting plate holding the idler pulley. when you push up the lever, it pulls the pivot [and idler pulley] back and puts tension on the belt. if this pivot gets rusted, it sticks and won't release tension on the belt. find the pivot point and lubricate it thoroughly with oil, wd-40, or liquid wrench, then work it back and forth by hand until it is freed up
Aug 02, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Mower starts fine but stalls immediately upon
Check the switch connected to the brake curcuit.
As you suspect, that is more than likely the problem.
Good luck.
Jul 15, 2009 | Garden
I HAVE A RYOBI RT190 RIDEM MOWER AND I HAVE NO JUICE TO TURN OVER THE MOTOR...BATTERY HAS BEEN REPLACED AND IS NEW BUT I HAVE NO POWER AT ALL...NO LIGHTS ECT...
Jun 18, 2009 | Agri-Fab Agri - Fab Snow Blower - 42"
Ryobi gas chainsaw- chainsaw brake is stuck on. How do I release
You just have to pull the lever back, like it was on the saw, until it clicks/unlocks. It may be hard to do, but thats what has to be done.
Jun 11, 2009 | Ryobi Garden
Clutch will not disingage when i pull the lever .
Sounds like it is not adjusted properly, or you have the clutch misaligned. You can check for proper operation with the bike off, and the clutch cover off while pulling the clutch lever. Should be able to see it move 1/4-3/8 of an inch.
Jun 09, 2009 | 2003 Yamaha YZ 125
Transmission has been rebuilt but manual shift lever wont work and it is not bound up in transmission it something under the transmission pan
I sounds as though your friend bent the parking pin, or tried to engage park with your van moving either forward or back and has wedged it somehow. you can try to grease the **** linkage or have this done it may help or you may need a new park pin
Apr 26, 2009 | 1999 Dodge Durango
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
