Question about Tablets & eReaders
Dopo d7015 How can I get glass replaced? - Tablets & eReaders
How do I reset my 9" dopo tablet
Press to reset the tablet. Insert a paper clip or other small object with a narrow tip into this reset hole at its bottom.
25829542-zbf0iuqrbs3vw1pstdxvekqu-4-0.jpg Gopakumar Gopalan Google
Aug 20, 2015 | Double Power DOPO M-975 9" 4 GB Wi-Fi Grey...
Where can I buy a digitized screen glass panel for my dopo 10.1 quad core tablet, model com1081?
You can buy it from any nearest tablet store. It's available everywhere.
Mar 03, 2015 | Tablets & eReaders
I can't unlock my DOPO DP8856K TABLET
Not sure about Dopo but my Surface tablet has this problem at times and the solution is to press the start button at the same time as holding down the volume button. Hold for 10 seconds. Sounds weird but may be worth a try.
Feb 07, 2015 | Tablets & eReaders
My Dopo tablet want charge, what could be wrong and what can i do
1st, try unplugging and repluggin both ends. If either one is loose, it won't charge. Then, I believe the DoPo tablets use the same cable that most cell-phones use - the micro usb connector. So, if you have one of those, check to see that it is the same as the cable that came with it then, try the cell-phone charge/cable. If that don't work, you may need to return to store.
Jan 02, 2015 | Tablets & eReaders
Dopo m7088
not familiar with this brand. On Kindle I press and hold the power button for 20 seconds. Release and It flashes a few times. When it comes back up it works again. your support group is best place to start for most problems
Mar 22, 2014 | Tablets & eReaders
My dopo D 7015 has a problem when i try to downlaod. it starts to down load but never gets any farther than that. A "error when downloading"comes on the screen.why?
You may need more space--try deleting data or apps from the tablet's internal memory. Move what you can to external memory--probably your micro-SD card (if available, and that's possible--given certain apps, that may not prove possible). Always, it's a great idea to take some time to delete data, cache (temporary memory) and apps proving harmful or no longer necessary! Your micro-SD card (or other compatible external storage) generally isn't included with tablets or phones--you may purchase the cards at stores or online.
Dec 16, 2013 | DOPO Tablets & eReaders
I forgot the password to unlock my 10.1 internet tablet dopo
My son has forgotten his password and pattern, how do we resolve this issue?
Jan 12, 2013 | Archos 101 Internet Tablet Notebook
Tablets & eReaders Logo
11 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
