Question about Printers & Copiers
Canon image runer 3200 error sign
Copier shows error sign e000001-00040 shows and turn off and turn on sign
  • Printers & C... Expert
  • 270 Answers
Re: canon image runer 3200 error sign
This error has to do with the Fixing Assy overheating. The sub code "0004" is indicating there is difference in temperature between the two thermistors. Pull open the access drawer on the left side and undo the two screws that secure the fixing assy. Once removed, see if there any small pieces of paper hanging out possibly stuck between either sensor causing the temp difference. If any of this seems beyond your capabilites just order a new fixing assy and save the labor charge. Good luck.
Posted on Nov 14, 2007
0 characters
3 Points
Why my canon ir1133 printer is showing e733/0000 error message?
ERROR E733-0000 Stops printing and shows sign "Turn ...
Nov 20, 2013 - ERROR E733-0000 Stops printing and shows sign "Turn main power ON". Error ... error message when printing d1350 imageclass. Jan 03 ...
Oct 29, 2015 | Canon imageRUNNER 1133 Laser Multifunction...
My Canon copier, Model IR 400s, Shows the error code : E 604. What is the problem ? How can I Solve it ?
Problem :
E604 Error Code. You followed all the troubleshooting steps in the service manual and still have an E604 code.
Solution :
Check the Image Server Memory or the Image Processor PCB. The recommended Image Sever Memory should be Kingston 32MB, 144 pin EDO Module, 64 Bit, 60 nanoseconds, No Parity.
Jul 13, 2012 | Canon imageRUNNER 400S Copier
E000021-0001 error code
The Canon Color Image RUNNER 3200 machine has two on and off switches. Facing your machine. One is on the right side and the other is on the back left side. Shut machine down. Wait for about 10 min.s turn switch on.
Feb 13, 2012 | Canon iRC3100 Printer
My sharp AR 5516 shows f2 04 error code, please what is the solution
You have to change your developer, you can see developer spillage inside the machine it is a common problem in this particular model. Rate this and vote for this after your problem resolved.
May 20, 2011 | Sharp AR-5316 Advanced Digital Imager...
Canon Image runner 3200 error code E000002-0102
press *28*
press "clear"
then off the main unit and on it
Sep 26, 2008 | Printers & Copiers
Canon Image runner C 3200 printer gives error code E000677-0080
your quickbooks file is in the wrong format example tiff or pdf let your it know they can change it to the correct file format
Aug 15, 2008 | Canon imageRUNNER C3200 Copier
Error code Canon IRC3200
change the black drum reached end of its life
Canon Tech
Jul 22, 2008 | Canon imageRUNNER C3200 Copier
Printers & Copiers Logo
252 people viewed this question
Top Printers & Copiers Experts
old marine
old marine
Are you a Printer and Copier Expert? Answer questions, earn points and help others
