Question about Panasonic Computers & Internet
When is start the race there is a yellow screen at the bottom half of the screen
2 Suggested Answers
  • 126 Answers
SOURCE: hdtv with yellow half circle on bottom of screen
Odds are real good that the cooling fluid in the blue picture tube assembly has become contaminated. Only solution is to pull blue crt and dump out old fluid and clean and reinstall new fluid. Once done a fair amount of re-alignment is required. This is not a job for a do-it-yourselfer. Most tv shops would charge in the area of $250 to $300 for this repair.
Posted on May 01, 2009
How do I fix vertical lines and no picture.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 20, 2015 | Vizio E320VP 32" LCD TV
The auto print head alignment prints ok. The Nozzle check from top to bottom prints as follows: 3eBK ok; 6C top half light blue - bottom half darker blue; 6C ok; 6M top half light pink - bottom half darker...
It sounds like your black (K) or Black/Yellow (KY) head needs to be replaced.
The problem appears to be in the top half of the black head.
Without knowing more (like what make/model the printer is) I can't help more than that.
Mar 09, 2011 | Office Equipment & Supplies
Yellow Screen over most of the TV?
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 05, 2009 | Hitachi 50UX57B 50" Rear Projection...
Print test shows yellow block top half as a light color yellow and the bottom half as a normal darker yellow. tried cleaning a few times and no help.
There could be some paper scraps on the bottom of the printhead, take it out and blot gently on a damp paper towel, if it doesn't help, you'll need a new printhead.
Aug 14, 2009 | Canon I960 InkJet Photo Printer
Hdtv with yellow half circle on bottom of screen
May 01, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Yellow area on screen
either burn in or magnetic field interference. I suggest moving any speakers away from the tv. if thats not the case, then find a strong magnet, make sweeping motions across the screen with it but dont touch the screen! Keep doing this until the colors change, then "sweep" them with the magnet into a corner and they will mostly dissapea.......r, sounds complicated but worked for me. can be scary so dont try unless sickly despearate or confident.   Hope This helps!
Jan 24, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Only half the screen is being projected?
i am having the same issue............any solutions??
Mar 31, 2008 | Toshiba 50H72 50" Rear Projection...
Picture separated on 1/2 of screen
This sounds like a convergence problem. This is a common problem that is usually fixed 98% of the time by re-placing the STK392-020 ic or STK392-110, and check the fuse devices on the covergence PCB. I'm sure the actual parts numbers depend on the peticular brand. Good Luck!
Nov 09, 2006 | Toshiba TP43H95 43" Rear Projection...
Computers & Internet Logo
14 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
