Question about GE JES1344SK Microwave Oven
How do I change the lightbulb?
The oven works fine, the bulb inside is burned out. How do I change it?
4 Suggested Answers
fathitkf
  • 1871 Answers
SOURCE: Lightbulb on ceiling of oven went out. How do I
Hello :
1:Unplug the microwave oven from the outlet. Wait 20 minutes for the capacitor that is inside the microwave to discharge.
2:Unscrew all the screws around the casing by turning them counterclockwise.
3:Remove the cover by lifting off.
4:Locate the light bulb in the microwave. This will be located on either the right or left side.
5:Unscrew the light bulb by unscrewing counterclockwise. Some light bulbs are held into the socket by two notches; for these you will need to gently push on the bulb and turn counterclockwise to unsecure the bulb, then pull out of the socket.
6: Place your new bulb in the empty socket and secure by turning clockwise until tight, or if the bulb is one with notches on both sides, then guide the notches into the slot on the socket, push gently and turn clockwise until clicked into position.
7: Replace the cover and screw back on. You are now done and may plug back in the microwave.
Warning : Unplug the microwave before starting and wait 20 minutes for any residual electricity to be bled off from the capacitor.
Things you will need : Phillips screwdriver
good luck .
please rate !
Posted on Mar 28, 2010
MicrowaveSvc
  • 9047 Answers
SOURCE: need to replace light bulb inside ge sca1000 microwave
The service manual is here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 20, 2011
MicrowaveSvc
  • 9047 Answers
SOURCE: Arcing sparking to carousel wheel. have 8 year old
I think the problem is just coincidental to the lamp replacement.
i would say there is grease or food debris on the turntable support or turntable motor coupler.
The service manual is here and you can order parts from the Pros here.
Posted on Sep 24, 2013
How do I replace the lightbulb in the microwave and what light bulb do I need to purchase?
to replace the bulb in microwave ovens you will have to take the outside case off the unit as the bulb placement is not accessible from inside the oven
when you get to the bulb take it to an appliance repair shop and they will have a bulb
Sep 09, 2015 | In Microwave Ovens
Magic Chef microwave MCO160UW stopped working after trying to change the lightbulb.
First thing to do is unplug it and take a pair of needle nose pliers and get the base of the old bulb out and replace it. Microwave ovens have a lot of things wired in 'series' which means that is one switch,bulb or any thing else in the circuit goes out then the circuit cannot complete it's path and will not let the other parts function. It is a safety feature that is built into them. As in many things I think they over do the safety features but they didn't ask me when they built it. LOL! Try replacing the bulb and let me know how it works.
Mar 15, 2014 | Microwave Ovens
Magic chef microwave
There's a fuse that has blown. look for it near the bulb socket or on the main board inside the unit.
Jan 24, 2014 | Microwave Ovens
Arcing sparking to carousel wheel. have 8 year old GE advantium 120 microwave oven. Was working just fine with a burnt out lightbulb but when I replaced the over head lightbulb it started to arc to the...
Sep 23, 2013 | GE Advantium 120 Convection/Microwave Oven
Replace a lightbulb in a microwave
That's covered on page 24 of the owner's manual.
If you've misplaced yours, you can download it online here.
If you need to order a bulb or other part or accessory, visit here.
May 31, 2010 | Maytag MMV5207A Microwave Oven
Lightbulb burned out for microwave model # KHMS 1850SSS-0 Kitchen Aid Where can I purchase a replacement? Thank you, Carrie
Most home improvement stores and even some Walmarts/Chain grocery stores/Ace Hardware carry replacements. You will need to remove the cover from the microwave oven on most models unless your bulb is inside a protective cover inside the actual oven. Take the bulb with you when you go to make certain of a proper match. Be certain to unplug the oven if you need to remove the cover in any case.
Oct 13, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Spacemaker xl1800 - heats, but lights and carousel out
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Can not change interior lightbulb
how do I change the little light bulb on the top to take off the cover what do i need.
Please, lvinci@gmnew.com
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Can't get the light bulb out from under the counter microwave
the clear rubber is from the factory to keep the bulb from turning you need to cut this before you can replace the bulb . thats why the first bulb broke . there is no trick to getting them out , see if there is a glue strip on the broken bulb that if you chip off it will then turn . just be carefull what ever you do . ge thinks there microwave will die before the lights burn out ! it screams of there trust in there products . good luck
Jan 09, 2009 | GE JVM1650 1000 Watts Microwave Oven
How do i change the lightbulb in my Zanussi ZCM32T Combination Oven
hi
two VERY important things... first, turn off the breaker (power) to the unit, and second, do NOT touch the bulb with your bare hands (use thin gloves or rubber gloves), you don't want to get any thing on the bulb, like grease. I don't know this exact model but, to remove the bulb, there should be a grill on top of the microwave, take that off and there should be a panel above the bulb inside, remove that and you should be able to reach the bulb now.
Mar 21, 2008 | Microwave Ovens
GE JES1344SK Microwave Oven Logo
26 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
