The serial number of my TV is FDAT069334EV. Model 1256277174. I cannot get the remote handpiece to activate the TV. It has always been slow, but now it does not work at all. I have owned the system since new in 2006. Could you advise me of a fix, or where to obtain a new handpiece? I live in Brisbane, Australia.
SOURCE: universal remote
only a uhf remote will work from that location, you will probably need to get a dish network 6.0 or 6.3 remote
SOURCE: how do i program my remote
1. TV on.
2. On your Dish Network remote PRESS AND HOLD the small clear tv button until all buttons across the top of the remote light up and release.The only button lit should be the clear tv button that will be flashing.
3. Press the small red tv button next to the power button and release it. This should leave the clear tv button that was flashing lit solid.
4. Now slowly depress the channel up key until the tv turns off.Each time the up channel button is depressed the clear tv button will cease being lit and once it is released the clear tv button should remain solid. If the clear tv button flashes multiple times it usually means there is no known code for your tv, there may be another code that will work so continue on.
5. Once you are successful in getting the TV turned off press the channel down button once and then the channel up button. This should turn the TV back on.
6.Press the # key button on the remote. The clear tv button should flash three times then press the record button and try the volume up/down and the small red tv button. You should be able to turn volume up and down and turn tv on /off. If only one of these function it means that you have only found a half code and need to try the process again. Not all TV's have full codes or any codes at all especially combo units.
SOURCE: philips plasma tv model #42pw996217
Kevin I don"t know if you still have this problem? but if so I have a box and a remote. make a good offer and its yours.
R.Carter
469-337-4962
[email protected]
SOURCE: code to work remote for a tv
buy a new remote online so it will be coming in the soon . but would like to say many thanks for getting back to me .yous brian .
SOURCE: Cannot access channel 73 on TV2
If you are unable to access the TV menu using the buttons on the TV itself it is possible you can with the TV2 remote if it still controls the volume etc. for this TV. If it doe not you will need to find a code for your set in the manual for the receiver or you can go to the following link to find that info as well.http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/receiver/625.shtml
Assuming you have control of the volume still press the small TV button on the top left of the remote. Now press the menu button and you may be able to access the TV's menu. If so you need to run a channel scan/auto program the TV. You may need to use the buttons on the TV still to maneuver through the menu.
If you are still unable to access the menu you may need to purchase a universal to access the menu.
