My sound gets staticky once or twice a day if I turn tv of and on it fixes it it for a little while. 32 inch toshiba vierra
    Habit-Forming:
  • 166 Answers
If you are connected to a cable box, it may be a problem with connection. I get wierd sounds when watching my Uverse service via HDMI connection occasionally, but switching the channel up and back down usually clears the problem.
Posted on May 08, 2014
  • 10 Answers
SOURCE: TV goes black, won't power off
If the power indicator remains on (or LED remains green) when the unit goes dead, you will need to replace the main board to resolve.
Posted on Dec 22, 2008
dave1645
  • 834 Answers
SOURCE: my 32 inch westinghouse lcd tv's screen turned pink when on
your T-con board is failing you need a tech to replace it about a 150 dollar job
Posted on Nov 18, 2009
SOURCE: Dell 32 inch LCD Tv volume and menue problems
I had the same problem with my tv.No sound! I finally figured it out. It was the speaker wires! Once I changed them to a slightly stronger speaker wire, it worked great! I have sound to my tv and I haven't had any problems since then.
Posted on Dec 16, 2009
SOURCE: Wall mounting Panasonic Viera 32" tv
There's a little more elaboration required on the above post...You need to remember that the base has two long pins that go up into the TV. These pins are held in by two screws each. The screws are on each side of the TV (two vertical inline screws, inside a small inset section). Remove all four screws and the TV will come up off the base. Pull it straight and gently, but firmly, to unseat it from the pins.
Posted on Dec 28, 2009
  • 8457 Answers
SOURCE: I have a 32 inch tv have sound no picture
Does the picture flickers show up few sec.than dies,than have sound left only.Yes,than the 1 or 2 long LCD inverter boards are dead.Tries websites like Shopjimmy.com,Ebay.com to buy those long 1 or 2 inverter boards for the replacement.
Posted on Jul 12, 2010
My 32 inch toshiba tv has lost sound , I've heard that a first time installation fixes this but I'm not sure what to do
If the TV has no sound, it will have some problem with it. A first time installation will not rectify this problem, and I don't know who told you this foolishness. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact any experienced service technician, or the nearest service center.
Mar 12, 2013 | Televison & Video
I own an 32 inch RCA TV Model No. F32444 one day
The TV has burned out.......Don't switch it back on again unless you want to get electrocuted, or burn your house down
Jan 19, 2010 | RCA F32444 32" TV
I have a toshiba 32 inch 1997 tv. When I turn32G90 it
It sounds like the picture tube may be weak (because it's orange) but it going to half ascreen is not caused by the picture tube but likely a vertical circuit problem. If this problem happened suddenly (going orange) then the picture tube is probably good and at least worth bringing in for an estimate.
Oct 06, 2009 | Televison & Video
Have a 32" Toshiba LCD TV with no sound
go into menu look for sound click inside speakers or try to use outside speakers. i fixed 3 or 4 witk same trouble... good luck & happy 4th
Jul 03, 2009 | Toshiba REGZA 32RV530U LCD TV
Toshiba LCD TV AV500E Turns off then on every 5 minutes
It sounds to me that the Main board is causing the problem. But I would get in touch with Toshiba for a warranty repair. It has a one year parts and labor warranty. It makes it a lot cheaper for the pocket.
Good Luck,
Skyassoc
Jun 01, 2009 | Toshiba 32AV500U 32 in. LCD HDTV
Sound Noise Using HDMI Cable
The first solution was to use the remote controls on the recorders and shuttle from 480p to 720p to 1080i.
The other solution was to run left and right audio cables from the output of the DVD recorder to the audio inputs of the tv. Then, go into the setup menu of the recorder and tell it not to output sound using the HDMI cable.
The first solution has to be done each time the machines are turned on for the first times of a day.
The second solution fixes the problem once and for all....
Feb 17, 2009 | Olevia LT32HVM 32 in. LCD Television
Problem with 32-inch Toshiba flat screen tv
yes take it back sounds like a back light issue
shad
Jan 04, 2009 | Sharp R-1480 Microwave Oven
TV repair
hi there, yes it is worth fixing for a 32 inch tv. , check up the connection inside and some loose connection or some cold solder. do some cleaning and check up. ty
Dec 29, 2007 | Philips 32PW6006 32" TV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
