Question about Panasonic Kx-t7625 Basic Phone
How do you turn DND off on a KX-T7625?
No one can intercom me and cant get the FWD/DND to go off and stay off.
5 Suggested Answers
Centernet
  • 38 Answers
SOURCE: FWD/DND light won't turn off on KX-T7633
Depending on how your system is programmed, you should be able to turn the light off by simply pressing the FWD/DND button. Otherwise it will require you to dial a "cancel code" which also can be different on various installations. You can try *7100, but that is just one popular code.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Posted on Oct 14, 2008
cnavarro
  • 2460 Answers
SOURCE: FWD/DND - PANASONIC KX-T7130
Don't laugh. Push the button and read the display. It will either unset DND or CF :-).
The 7100 command is part of the sequence to cancel those features on most phone systems and 790 or 79# will reset the extension. Of course it may be different if you have a TDA or TAW box (*7100) or a KX-T xxx10 system.
Carl
Posted on Nov 16, 2008
cnavarro
  • 2460 Answers
SOURCE: Panasonic Digital Model KX-T723OE The key FWD/DND
I'm guessing that you didn't mention that the phone doesn't work, it must be in FWD mode. You can cancel CF, or get someone to go into 990 area 9 bit 3&4 and reverse the bits so it will be solid on FWD and flashing on DND.
Carl
Posted on Nov 03, 2010
cnavarro
  • 2460 Answers
SOURCE: kx-t7433 how to turn on fwd/dnd does not work
What happens when you dial 165 on the intercom? If you get voice mail, then try dialing 7104 165 # on the intercom. That sets CF-No Ans to voice mail for your set and the FWD/DND button should light solid (or not, it's a program option) or flash. If you dial 7101 it should turn on Do Not Disturb (7100 cancels). In DND, the FWD light should flash.
Once you have set these two conditions up, the FWD/DND button has 3 states, FWD, DND, and OFF.
Carl
Posted on Jul 14, 2012
Kx-t7433 how to turn on fwd/dnd does not work
Carl
Jul 10, 2012 | Panasonic KX-T7633 Corded Phone
I have an issue with my FWD/DND function. Until yesterday, I was able to receive "in" calls. Apparently I accidentally hit the FWD/DND button! At first I wasn't getting ANY calls (never used...
I don't know about a "user guide" but the Operating Manual would work wonders. http://www.public.carl.airpost.net/Pana/TDA/200_TDA_OM_06-121.pdf
The FWD/DND button has 3 steps of keypress, Off, FWD, DND. The idea is you press it until it stops flashing or being lit and you have nothing set. If that doesn't work, try Call FWD/DND cancel, *7100 on the intercom.
Carl
Mar 10, 2011 | Panasonic KX-T7633 Corded Phone
I have a panasonic KX-T7625 and I would like to set it to go to voice mail after 3 rings. How do I do this?
On the intercom you dial *7104 xxx #. The xxx being your system VM extension (usually 500). Then you dial *71318. Note, the 18 is a 2 digit number for 18 seconds. That will make the 4th ring be into the voice mail system and it should answer on the first ring. You can adjust the time from 00-99, except after you get to 30 or so, the transer recall timer should pull the call back in before your phone answers.
After you dial the 710x code, you should be able to press the FWD/DND button and have it cycle between on and off. There is also a 3rd state DND, but it also has to be initially dialed from your intercom.
Carl
Jan 21, 2011 | Panasonic KX-T7625 Corded Phone
FWD/DND SHOWING RED AND INCOMING CALLS RESTRICTED
If you have not found an answer to this as yet just pick up intercom and enter 7100 at the phone. This will clear any DND. Now enter intercom 7105165. This will give a long tone and the DND/FWD lamp will flash showing Call forwarding active for VM.
Jan 18, 2011 | Panasonic KX-T7630 Corded Phone
I need to turn of fwd/dnd
Take the handset off the hook, then press the FWD/DND button followed by 0 (zero). When you hear the tone, hang the handset back up. This will work with the PT (Panasonic Proprietary telephone) system. (Alternatively, pick up the handset, press 7 (seven) 1 (one) 0 (zero) 0 (zero) and hang up after the tone. This works for PT and SLT phones (single line telephone))
The same sequence works to cancel call forwarding (except for follow me forwarding). In the Follow me mode, pick up the handset, press FWD/DND or 7 1 0 followed by 8 and the extension number. Then hang up after hearing the tone.
I hope this helps.
Sep 23, 2010 | Panasonic KX-T7130 Corded Phone
FWD/DND
The behavior of the FWD light is programmed in system options. By default, it's usually set to be solid on FWD and blink on DND.
Here's a quick cut and paste from the OM for 76xx phones.
Dial *7x0y Where x=1-3 and y=1-6 for the following conditions:
Do Not Disturb *7101 / Cancel *7100
Call Forwarding (FWD)
– Both Calls *710
– Outside Calls *711
– Intercom Calls *712
2 (All calls) + phone no. + #/
3 (Busy) + phone no. + #/
4 (No Answer) + phone no. + #/
5 (Busy/No Answer) + phone no. + #/
7 (Follow Me) + your extension no./
8 (Follow Me Cancel) + your extension no.
So, if your voice mail is 500, you would dial *7105500# to set CF B/NA for intercom and outside calls.
Carl
Sep 14, 2009 | Panasonic KX-T7633 Corded Phone
Panasonic kx-t7030 FWD/DND button
Outgonig calls and the FWD/DND button are not realted. Walk up to the phone and dial 790 on the intercom. That should reset everything.
Now, try that calling out and see what it's doing. If you can dial "9" from the intercom and get an outside line, start dialing a number and see if it fails. Watch the display at all times. If it is still broken, post back.
Carl
Jun 23, 2009 | Panasonic KX-T7030 Corded Phone
Panasonic kx-t7633
On the intercom dial *71x1 where x is 0 for all calls, 1 for outside calls and 2 for intercom calls. *71x0 cancels, or you can just press the FWD/DND button until it goes out.
Carl
May 07, 2009 | Panasonic KX-T7633 Corded Phone
FWD/DND light is on and so is an extension light but the FWD/DND setting is off but when i check messages, i get a busy signal.
If the FWD/DND light is lit solid, the extension is in DND if it's programmed properly. You can test this by pressing the FWD button and reading the display. It will clear and press it again and it will set and tell you what it did. (if DND and FWD are both set it shows 3 states).
At the phone, press intercom and dial *710x where x=2 for all calls, 3 for busy, 4 for no answer or 5 for busy/no answer plus the extension of the voice mail plus #. Your FWD light should blink and you have now set FWD to voice mail.
Carl
Mar 12, 2009 | Panasonic KX-T7633 Corded Phone
Panasonic Kx-t7625 Basic Phone Logo
14 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
