Question about MSI Computers & Internet
Fn f8 not working - MSI Computers & Internet
4 Suggested Answers
shuttle561
  • 32 Answers
SOURCE: Fn+F8 hotkey dose not work but the remain FX go fine
Another Alternative is to check your BIOS to see whether or not your Wireless is turned on, if it is not pressent in your BIOS then update your BIOS Driver on the Internet to ver 1.4, Double check your version Compatabillity. Next if the adapter driver is installed, follow the following intructions: start -> settings -> control panel -> system -> hardware -> device manager -> now look for the wireless adapter, see if it is operational or marked with an error -> if it is marked check that it is configured for automatic, and also the resources. Set the configuration manually if so. restart the system.
1) Resource conflict = change resource settings
2) No adapter = check if the adapter is enabled (Y) then see if there is any conflicts (y) correct the settings e.g. resources and see if windows shows that the device is enabled (N) try to enable this device. If (N) then goto BIOS settings to correct it.
Hope this helps
Posted on May 24, 2009
leecom72
  • 4806 Answers
SOURCE: I don't know what fn f4 or fn f8 do.
Laptop keyboards can differ with the function keys and are set out different depending on make and model.
If you take a look at the F4 and F8 keys, is there any symbols (in blue) on them? If there is post back here with a description of the symbols, If there is no blue symbols on the keys then they will do nothing and there is nothing to worry about.
Regards.
Posted on Jul 16, 2009
SOURCE: fn and f7/f8 not working
You need to install the special keys manager for all of that.
Posted on Apr 02, 2010
Restore FN + F8 key to reactivate Wi-Fi on Toshiba Satellite L500
My laptop didnt enable the wifi with the fn+f8 key.
I even reset the cmos and nothing.
Then I went to toshiba drivers website and after installing the "thku" "toshiba hotkey utility" the fn+f8 start working and enable/disable the wifi. It now shows a popup windows when I press the fn+f8 key.
Before the wifi led was always off. Windows detected the wifi device but nothing on the wifi available list.
Now the led is always on, starts orange when I turn on the pc and blue when connected.
Oct 05, 2012 | Toshiba Satellite L500 Series Notebook
My fn key wont work on toshiba sattelite pro
FN (Function Key) that is usually located near the bottom left on the keyboard is not a key that you press by itself to do anything. The FN key works in combination with the (F1 thru F12) and any other key that has the same symbol or color as the FN Key. You have to Press and HOLD the FN key while pressing another key.
If the FN key is Blue and for example your F8 key has a (white F8 on it and a Blue battery icon on it) then to see your battery metor (how much charge it has left) you would Press the FN and hold it then press the F8 key. The F8 that is white does not require you to press the Blue FN.
Sometimes the FN key might have a white square on it, then the keys that work with the FN key will also have a symbol with a white square around it.
Mar 25, 2012 | Toshiba SatteliteĀ® Pro A200 PC Desktop
How can i get my fn key to work
How do I adjust the screen brightness?
Press and hold fn button on your keyboard, then press F7 to decrease brightness and F8 to increase brightness. That is Fn + F7 or F8.
If F7 or F8 doesn't work try F6 or F9.
Or you can just start from F1 to F9. One of these buttons certainly would work.
Regards.
Apr 19, 2011 | Compaq Presario Notebook
My HP Pavillion M70 monitor is saying "video cable connected?" when I try to use the monitor. I am trying to output my laptop to the monitor because my laptop screen is wearing out, but I cannot get it to...
go into the BIOS settings and tell it to use the LCD/Monitor as a display.
or
press fn key+(F5 or F7 or F8) 1x or 2x or 3x.....
Fn key combination. The Fn key is located at the lower left of the keyboard, normally between the CTRL and the ALT key. Toshiba uses Fn-F5 to toggle between the laptop LCD and an external display. IBM or Lenovo uses FN-F7, Acer varies with the model, using Fn-F5, Fn-F3, Fn-F8, Sony Fn-F7, Dell Fn-F8, HP or Compaq, Fn-F4. There are variations with the age of the laptop and not all manufacturers have standardized on a key combo across the whole range, but you can usually figure it out from the little graphics on the function keys that line the top of the keyboard.
Aug 25, 2010 | HP Pavilion M70 17" CRT Monitor
How do i make my screen brighter on presario v2000
Decrease Brightness (fn+f7) The fn+f7 hotkey decreases the brightness of the notebook screen. The longer you hold down the fn+f7 hotkey, the more the screen dims. Decreasing screen brightness conserves power. » To increase screen brightness, press the fn+f8 hotkey.
Increase Brightness (fn+f8) The fn+f8 hotkey increases the brightness of the notebook screen. The longer you hold down the fn+f8 hotkey, the more the screen brightens. » To decrease screen brightness, press the fn+f7 hotkey.
Nov 03, 2009 | HP Compaq Presario V2000 Notebook
Which function key do you use to project on a Dell laptop?
Fn + F8
It cycles through three options:
Internal LCD - Both - External output
Cheers
Nov 02, 2009 | Dell Latitude D600 Notebook
Presentation mode is off appears when you try to FN F8 Dell Latitude E6500
check device manager to be sure your video card is functioning properly. If it looks good in device manager, shut off the pc, connect the external monitor/projector to the pc and start up the pc with the external device powered on. if no video from external device, then the video card/external connector is probably bad. Contact Dell if in warranty.
maybe the fn/f8 keys are not working. Can you get a safe mode boot prompt by repeatedly pressing the f8 key immediately following power up on the laptop? if no, f8 key is likely dead and you need a new keyboard. If f8 is okay, does the fn key work with other functions? if no, fn key is bad - new keyboard.
Hope this helps!
Aug 08, 2009 | Panasonic PT LC75U Multimedia Projector
Computers & Internet Logo
16 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
