Question about Janome 6019QC Mechanical Sewing Machine
Why wont my needle thread pick up my bobbin thread
SOURCE: Janome Memory Craft 9500 Troubleshooting
The solution that I found last night was the thread tension. I have never touched the dial, only had it set on 'auto." When I started playing with it, I realized the top thread should be really easy to pull through the machine and it wasn't. I started turning the dial (to 3 or 4) and the thread slid through the machine perfectly. No more birds nest! I really thought it was bobbin initially because of the horrible sound it was making.
Posted on Jun 05, 2008
Mongo32
  • 111 Answers
SOURCE: inserting bobbin
needle's in backwards
Posted on Jun 01, 2009
  • 136 Answers
SOURCE: will not pick up bobbin thread
Unusual for this machine. Check to be sure the needle is inserted with the flat side to the back of the machine. If it is, remove the needle plate, bobbin and bobbin case. Turn the hand wheel slowly toward you and see if the point of the hook is above or below the eye of the needle when the hook point is aligned behind the needle. If the eye is above the point of the hook the machine is out of time and best taken to qualified technician.
Posted on Jul 04, 2009
  • 17 Answers
SOURCE: Is the bobbin suppose to spin?
attempt to tighten nut on the hand pulley.if not turn grabbed problem can be in transferred trough gears...
Posted on Dec 27, 2009
Zenqi
  • 208 Answers
SOURCE: needle not picking up bottom thread
Remove the needle plate and the bobbin case.
Ensure that the needle is inserted all the way up into the needle clamp.
Set the machine for straight stitch, center needle position.
Slowly turn the handwheel in the normal sewing direction and observe the following hook timing setting:
When the needle reaches it's lowest point and travels up 3.5mm, the point of the hook should be directly behind the needle, or at least within 1 or 2mm.
Another view is as the hook passes the needle, it should pass the needle slightly above the eye of the needle.
If the timing looks good, use some alcohol on a bit of cloth to clean the hook, careful around the tip of the hook as it is very sharp.
If the hook timing is off, you will need to take it to a knowledgeable service person as there are several possible solutions and several other related adjustments which will need to be made.
Posted on Jan 16, 2010
My upper thread wont pick up the bobbin thread suddenly. How do I fix that problem?
Install a brand new needle. A bent/dull/damaged needle sometimes will not pick up bobbin thread.
Check that the needle is installed facing the correct direction.
Also check that the bobbin is wound smoothly, the bobbin is turning the correct direction in the bobbin case, and the bobbin tension is threaded correctly.
If it still will not pick up the bobbin thread, there is most likely a timing issue, ie the needle is arriving at the wrong time to intercept the bobbin thread. Search the internet for sewing machine timing discussions or take it for service.
Nov 03, 2016 | Sewing Machines
My brother vx-1120 needle wont pick up bobbin thread to make a continuous stitch
Install a brand new needle. Make sure it is installed correctly.
Remove the bobbin/bobbin case from the machine. Check that the bobbin is turning the correct direction and the bobbin tension is threaded correctly. Reinstall the bobbin case and confirm that it is latched into place.
Retest your machine. Slowly turn the handwheel and watch the needle descend and see if it picks up the bobbin thread. If not, then there is probably a sewing machine timing issue. Take it for service.
Nov 01, 2016 | Brother Sewing Machines
Wont pickup bobbin thread when sewing.
Make sure you are using a brand new needle. Bent/damaged/dull needles frequently will fail to pick up the thread.
If it continues to skip stitches, it most likely has a needle/hook timing issue--the needle arrives at the bobbin at the wrong time to intercept the bobbin thread.
There are web sites and videos available that discuss sewing machine timing, or you can take it for service.
Sep 10, 2016 | Sewing Machines
My 532 wont pick up cotton from bobbin
First, install a brand new needle. Used/worn/bent needles will sometimes fail to pick up the bobbin thread.
Make sure the bobbin is installed correctly in the bobbin case.
If it still will not pick up the bobbin thread, most likely the machine is out of time (the needle arrives at the incorrect time to intercept the bobbin thread). Take it for service or search the internet for web sites or videos dealing with sewing machine timing.
Sep 03, 2016 | Sewing Machines
NEEDLE THREAD WILL NOT PICK UP BOBBIN THREAS
you should try these needle called the organ needle they have 10 pcs. HAx1 130/705H 15x1 size 100/16 these needles are longer and strong . Maybe the one you have is too short
Oct 19, 2014 | Elna Quilter's Dream 6003Q
Why wont my needle pick up my bobbin thread
1. Either the needle is smaller than required and does not reach down enough to loop the bobbin thread.2. Or the bobbin thread is not kept out of the shuttle and does not make a loop with the needle thread.
Apr 05, 2012 | Brother Sewing Machines
Wont pick up bobbin thread
1.check needle to see if it's bent or blunt end
2.check bobbin & bobbin case for lint or loose thread
3.could be a timming problem- would have to be serviced
Jul 28, 2010 | Brother LS-2125 Mechanical Sewing Machine
Are you certain that the needle is in correctly? If it opens at the front the flat side of the needle should be facing the back. If it opens on the left hand side then the flat part of the needle should be facing into the body of the machine. If top and bottom are threaded correctly and the needle is in properly and fully in position it should pick up. If it doesnt then you "could" have a timing fault.
Oct 02, 2009 | Singer 7444 Mechanical Sewing Machine
Bobbin not picking up through the needle part of the machine
thread only shows the bobbin thread when i sew and needle thread also please e-mail me the attachment instructions. marybellroberts@msn.com
Oct 14, 2008 | Singer 3116 Simple
Machine wont pick up bobbin thread
needle won't pick up thread I think the timing is off, how do I retime it?
Aug 25, 2007 | Kenmore Drop-In Bobbin 16231 Mechanical...
Janome 6019QC Mechanical Sewing Machine Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
