Question about Vehicle Parts & Accessories
White smoke once you crank car
White smoke when starting car
  • waruisa May 08, 2014
    piston rings starting to wear out or your oil level is above recommended level
  • minoman May 18, 2014
    WHITE smoke is almost always WATER in cylinder. check intake gasket by applying 3 in 1 oil or wd40 at joint of head and manifold while running. If smoke turns blue from oil being sucked in, change intake manifold gasket. BLUE smoke means you're burning OIL, BLACK smoke means too much fuel or not enough air going into engine. For WHITE smoke,also remove radiator cap from COOL engine,start car and idle for 3-4 minutes, if you see lots f bubbles it's a head gasket. Also check oil filler cap for yellowish "varnish" looking deposit which means water in oil. Pull oil dipstick , if oil looks milky or like coffee with cream, you have water in the oil. A cracked block is also a possibility if engine was overheated.
    Novelist:
  • 178 Answers
I have found that usually water is getting into the engine though gaskets or cracks in block, causing steam to flow after water reaches the very hot metal parts of a running engine.
Posted on May 17, 2014
    New Friend:
  • 10 Answers
White smoke would be a bad head gasket. Check the radiator water to see if it has changed color and/or is low. Check the oil to see if it is coffee colored. If it is, it's definatly a blown gasket.
Posted on May 10, 2014
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 24 Answers
Ahh you are burning oil. Betcha you have a slight leak - possible gasket leak
Posted on May 07, 2014
Smokes when cold and stops once it warms up
How many miles on engine?. What color smoke? If white clouds of smoke that goes away when it warms up that indicates a possible housing seal. Another symptom would be having to add coolant. view this video -> https://www.youtube.com/watch?v=4H-B1nckyFE
Nov 20, 2013 | 1991 Mazda RX-7
After smog pump reinstallment, car wont crank
If car cranked but white smoke came out of the tailpipe.The car may have either a bad head gasket or a cracked cylinder head.You mentioned changeing the radiator.Did the car overheat severely?This would stress the headgasket.The car may not start now because the plugs are wet(water)or the rings have lost their ability to seal compression due to overheating.
Apr 14, 2013 | Ford Taurus Cars & Trucks
White smoke whrn i crank it
normal to see a little white smoke when first start engine on cold morning.as engine warm up should not see white smoke not heavy.if you getting a lot heavy smoke you have leaking head gasket.check engine oil it should look milky looking.
Nov 04, 2012 | Cars & Trucks
After starting car it sputters and white smoke from exhast. I drive the car for 5 min, sputtering the whole time, and turn it off - will not start until it is cranked and gas pressed for couple min. Then...
White smoke is usually from water and water will make the car splutter. Did you get water in your tank at some time. If you have water in your fuel, you will have to drain the tank and refill with good fuel. The engine will run fine once it is hot but if a lot of water goes into a hot cylinder it can cause a lot of damage.
Apr 01, 2010 | 1998 Oldsmobile Intrigue
97 Bonneville wont crank
white smoke is an indication of a leaking headgasket. if this is the case the coolant could have fouled out the plugs
Mar 29, 2010 | 1997 Pontiac Bonneville
1999 buick 3.8, was running rough with white smoke.
white smoke tells me engine coolant is mixing with the combustion chamber. you have leaking head gaskets
Feb 07, 2010 | 1999 Buick LeSabre
Craftsman riding mower starts, then runs for 30 seconds, then pours out white tons of white smoke and sputters and dies. It will then re-start and repeat the same. The amount of smoke is tremendous. It...
The smoke is oil going in to the combustion chamber, will have to check for broken rings or piston. also if the tractor was stored in a position that the oil would run to the combustion chamber it will do that untill all the oil is burn
Mar 22, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
94 COUGAR GETTING TOO MUCH FUEL WONT START
my guess would be a defective fuel pressure regulator, not 100% but i have seen that before ,usually a bad regulator will usually produce a rich (gas) smell and or very white thick exhaust smoke(raw unburned gas),almost the same appearance as smoke from a blown headgasket, and also usually if you hold the thottle to the floor,and crank it for several secs it sould start,if not another alteritive to getting it to start(as to check for white smoke) is to pull the fuel pump relay to stop fuel flow long enough to get it to fire,once it does replace fuel relay,and crank holding it to floor tiil it starts,hopefully this will help you ,good luck
Dec 12, 2008 | Mercury Cougar Cars & Trucks
Vehicle Parts & Accessories Logo
102 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
