Hello, I have a Frigidaire model LTF7000ES0 and it is frozen. I was washing a very small load and paused it to add more, when i closed the door and pressed the start button it gave me three quick beeps and the display toggled between the time remaining and pause. It will not let me change any of the settings. anytime I press a button it just beeps the times. I looked on the error code sheet and it says drum overfilled with causes of inlet valve, pressure switch or control board failure. Please help. Thanks
  • 41 Answers
Sorry have no info on this model have you tried draining the mach manually then switch it back on i have seen this type of prob on other makes main control board is sometimes required
Posted on May 11, 2014
3 Suggested Answers
SOURCE: I have a Frigidaire front load washer model FTF2140ES2 that will
The rubber around the door tore and the washer leaks bad.where do i find that part.
Posted on Jun 21, 2009
SOURCE: Hi!
I've had the same problem. I removed the top lit and found some pressure transmitter and a pressure switch. I suspect that the pressure transmitter is use for measuring the waterlevel in the machine. I think the membrane loses its flexibility over the years.
I pulled of the hose from the transmitter and blowed and sucked a few times on the transmitter. After doing this the machine washes without a problem since then.
Hope it helps for you.
Posted on Oct 24, 2010
My front load affinity will not start, says pause
Hello friend, thank you for your post!
I see that your Frigidaire washer, FAFW3517KW, is constantly showing you pause, when you press start it flashes the pause again, and that the door lock light does not come on. You could be seeing a couple of different possible reasons this is happening such as your control panel, door lock assembly, or door switch. Since it could be any of the underlying issues I would recommend having a professional come out to the home and repair the washer. -Matt
Aug 02, 2014 | Frigidaire Affinity FAFW3517KW 3.5 Cu. Ft....
My affinity front load washer will not complete any cycle and the display screen goes blank.. what could be the problem
Hey friend, I appreciate your post!
From my understanding your Frigidaire washer, LTF7000ES0, will not complete a cycle and the display will also go blank. It sounds like it could possibly be a problem with your control board, drawer, or lock switch. Since it could be any one of these issues I would recommend having a professional come out to your home and repair your washer. -Matt
Jul 30, 2014 | Frigidaire Washing Machines
Why does my Frigidaire washer says pause and 18h
Hello friend, that's a great question!
In order to provide you accurate possibilities of why your washer continues to pause and show 18h, I would need your model number please. You can normally locate your serial tag (which lists your model number) on the upper front interior of the door frame on a front load washer. If you own a top load washer you would normally find the serial tag on the inside of the lid, on the right side. Thank you and I look forward to your response.-Matt
Jul 18, 2014 | Frigidaire Washing Machines
Error message e41
Hello Friend, thank you for your inquiry!
If you are receiving an error code E41 on your Frigidaire front load washer, your loading door may be ajar. Double-check to ensure that it is closed. If it is secure, reset the power to your appliance for about 30 seconds. You can do this by unplugging your washer or flipping your circuit breaker into the off position. If the error persists, it could either be the door switch assembly or your washer's main control board. In that case, a certified technician would generally replace the faulty part after proper diagnosis.
Hope this helps! - Z
Jul 07, 2014 | Frigidaire GLTF2070DS Front Load Washer
Fridgidaire front-loading washing machine model # LTF2140ES0 will not spin
Good Afternoon Friend,
I understand that your Frigidaire washer, model# LTF2140ES0, will not spin. To try and resolve your washer not spinning, please try the following:
    1)Check your washer door and make sure it is completely closed.
    2)Check your dispenser drawer and make sure it is completely closed.
    3)Your load might be too small. Add 1 or 2 similar items to help balance the load.
    If the above does not work, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Turn the power back on and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
Jun 20, 2014 | Frigidaire Washing Machines
Hello, I have a Frigidaire model LTF7000ES0 and it is frozen. I was washing a very small load and paused it to add more, when i closed the door and pressed the start button it gave me three quick beeps and...
Unplug it for 10 minutes. Plug it back in and see if it starts and runs normally. If it doesn't then I'd suspect the pressure switch first then the control board.
May 10, 2017 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire front load washer model LTF7000ES0 got out of balance with a heavy pillow and we had to stop it. Now it won't do anything. Everytime I start it, the door light comes on as usual, then a
Check to see if the door sags at all and doesn't line up correctly with the door latch. Then check to see if the drum wobbles when you rotate it yourself when not in use.
Jul 30, 2012 | Frigidaire ATF6000ES Front Load Washer
OK I have a frigidaire front load washer model #GLTF2940ES0 it won't start but the lights are on. I push the button and it blinks err then lock. what can I do?
hello mam
after taking the water to its drum to a given level it should start the thumble wash and if it wont then we should check the timer switch,motor,and the water level controler.so please call the engineer.
Oct 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Front loader model#LTF6000E
IS it giving you an error number such E20???
Aug 04, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
