Question about Transmission & Drivetrain for Ford Transit Connect
What is the recomended solution for code p0753 on a 2001 lincoln ls that wont shift past 1st gear after it warms up?
  • 39 Answers
P0753 - Shift Solenoid 'A' Electrical 1 - Check for Low transmission fluid level
2 - Check for Dirty transmission fluid
3 - Could be a Faulty shift solenoid 'A' valve
4 - Shift solenoid 'A' valve, harness, or connectors may be compromised. Inspect and repair/replace as required.
Read more: http://engine-codes.com/p0753.html#ixzz319LgGeCg
Posted on May 08, 2014
Can only select 1st neutral an 2nd gear
Hi Meihana and the usual suspects are:
1. Clutch dragging slightly.
2. Primary chaincase overfilled with lubricant.
3. Corners wore off shifter clutch dogs.
4. Shifter return spring bent or broken.
5. Bent shifter rod.
6. Shift lever is loose on the shifter shaft.
7. Shifter forks sprung.
8. Shifter pawl needs adjusting.
9. Heel/toe shifter coming in contact with the floorboard.
10. Transmission oil too heavy.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
http://pnwriders.com/threads/r1-wont-shift-past-2nd-gear.169723
Can shift above 2nd gear
Wont shift past 2nd gear
Shifting stuck won go past 2nd gear
Apr 06, 2016 | Motorcycles
Why won't my Lincoln ls engage into gear but will shift into all gears
Shifter cable ? Look at trans. range selector switch on the transmission , have a helper shift gears ! Does it move
Dec 31, 2015 | Lincoln Cars & Trucks
P0753
P0753 - Shift Solenoid A Electrical
- Low transmission fluid level
- Dirty transmission fluid
- Faulty shift solenoid 'A' valve
- Shift solenoid 'A' valve harness or connectors
- Shift solenoid 'A' valve circuit is open or shorted
Read more: http://engine-codes.com/p0753.html#ixzz31EB1WygL
May 07, 2014 | 2001 Lincoln LS
2005 lincoln ls transmission is shifting hard from 1st to 2nd gear
You replace the Transmission Pressure Control Solenoid Pack
There are 3 pressure control solenoids & 4 shift solenoids in one
plastic part ,made by Bosch
You remove the trans pan,the gasket is reuseable silicone
You remove the filter
You remove approx 7 -- T30 bolts, holding the solenoid pack
& one 10mm electrical connector bolt
HPN-9L2Z7G391A $515.30 / $ 332.20 cost -- for part
Aug 02, 2011 | 2005 Lincoln LS
I have a 2000 lincoln LS how do you check the trans fluid
Warm car to normal operating tempature,Put foot on brake run shift selecter through all gear ranges put car in park leave car running now check & fill to correct fluid level
Jun 22, 2011 | 2000 Lincoln LS
Tranny shifting hard
try changing your transmission filter if the problem continues try taking your car to a transmission shop and see what they tell you
Apr 06, 2009 | 2001 Lincoln LS
1996 Audi A4 Automatic transmission wont shift when cold
Silly question: Have you checked the transmission fluid level, and is it to manufacturer's spec?
Mar 13, 2009 | 1997 Audi A4
V-8 / Low Power / Doesn't shift correctly
Has your tech checked this vehicle for an exhaust restriction? He can check this with a vacuum pressure guage at the DPFE sensor hoses.You should have 1psi or less at idle and 3 to 4 psi at wide open throttle.Anything else would be a restriction.
Are you getting any trouble codes with this?
Jan 28, 2009 | 2000 Lincoln LS
Transmission & Drivetrain for Ford Transit Connect Logo
106 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
