Question about Vacuums
Komori feeder loosing suction - Vacuums
  • 94 Answers
Check the secondary filter, usually the HEPA filter. This gets clogged after extended use. Remove it and take it outside and gently tap it on a hard surface dirty side down till clear.
Posted on May 08, 2014
Why is my hoover agility not sucking up water
It is likely the recovery tank lid is loose. This means the suction is loosing. Worst case is the suction pump is faulty.
Look at this manual in the troubleshooting section.
http://hoover.com/file/655/
Sep 03, 2014 | Hoover F6212-900 / F6215-900 SteamVac...
When we plug in the hose the motor in garage runs but no air or suction comes out of the outlets. we cleared all the lines too.
Check to see if you have suction at the unit. If you have suction at the unit, your pipes are stopped up. If you don't have suction, you have a pipe loose under the house. Also you could just have a stopped up hose
Apr 29, 2010 | Electrolux Centralux Vacuum
Not alot of suction but when using the hose alot of suction is it a motor problem how do i fix it plz bagless up rite
It could be your belt, if it is loose it will not turn the roter at its max power which means less suction.
Mar 11, 2010 | Dyson DCO3 Absolute Bagless Upright...
The machine will not suction - it will spray and spin the brushes but will not suction - the power is going to the machine, but it will not suction.
Disconnect the suction hose. While running, check the suction port if it works, by putting a piece of paper. If the paper is taken in, then it is oK. Now, check the suction Hose for breaks or opening before the suction head. Breaks or opening breaks the suction power at the suction head. Loose connection between the suction pipe and the suction port also must be check as this will also cause the same
problem. You may need to replace the suction hose
to correct this problem,
Send us the e-mail and your vote if this solves your problem.
Sep 27, 2009 | Eureka Atlantis 2590A Wet/Dry Vacuum
Motor makes loud growling noise, no suction on model 270 i Miele canister style vacuum
Hi there SmartAlec from NelsonVacuums.com.au here. Unfortunately that normally means the motor has shot its bearings and/or its carbon brushes. I think it is time to purchase a new one. On the bright side there are some rreally great vacuums out there! If you want any help choosing a new machine send me a message. Happy Vacuuming :)
Sep 04, 2009 | Vacuums
Sebo automatic x1.1 loss of suction
Check that the dust channel from the sole plate/brush head isn't clogged. Open the trapdoor (usually orange in colour on the base) and inspect the dust channel - sometimes dog hair can get trapped between the main dust channel and the feeder. Other than that take off the main hose and see if there's a clog down there as well as the main part where the wand locks in at the back. Its reasonably easy to get a clog out from a Sebo X range model.
Jan 16, 2009 | Vacuums
Loosing suction
Well you did not state what model and brand this is, but usually if the hose or the dirt inlet by the brush roll gets clogged, then you lose suction. If you can't figure it out, usually there is a year warranty, take it in for warranty service.
May 07, 2008 | Vacuums
No suction in upright position
Check the adapters at the bottom. They're supposed to move cleanly when you lower the handle. It's pretty obvious if there's an air gap when you lower the handle, and you should hear the suction in the air gap.
And...call Dyson...their support is great!
Oct 24, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
