Question about Frigidaire Refrigerators
I can't find Condenser Coil in Beko FN244 fridge
Or cooling fan. I need to clean it as fridge compressor working non stop.
  • Official Brand Answer
  • 2,267 Answers
Good Afternoon GOODGIRL,
I see that you are wondering where the condenser coil and the cooling fan are located on your Beko FN244 refrigerator. I do see that your fridge is based out of the United Kingdom. I suggest contacting the manufacturer in the UK for further assistance. I have been able to locate a telephone number, of 08445 613 613, for your convenience. Hope this is helpful.
-Best Regards-
WP
Posted on May 12, 2014
Do I need a new fridge
Check for air flow, clean the coils. May need a new condenser fan.
Jul 28, 2013 | Refrigerators
I have kelvinator fridge it doesn't cool in both compartment we replaced the compressor il coold down for only 3dayes then returned back to hot state
is the condenser fan running back there?also did you clean out the condenser coil?usually when the middle strip gets hot the coil is filled with dust or the fan where the compressor is isn't running.the condenser fan keeps the compressor cool and all the heat from the machine escapes out through the condenser coil.check this,also the start device could be bad on the compressor,send model number next time you write so whoever helps you can look up your machine.hope this info helps you out.
Sep 15, 2012 | Kelvinator Refrigerators
The rubber on the fridge & freezer doors are hot
pull out the machine,remove the front bottom kick plate and then go to the back and remove the back bottom panel,check to see if the condenser fan blade is spinning and check the condenser coil to see if it's loaded with lint and dust.the fridge is running to hot,the way it cools down is the condenser fan blows air around to keep the machine cool and heat escapes through the condenser coil,if it's blocked with dust the heat is held in the coil,a shop vac works great for the coil,vac up as much dust as you can and then set the vac up on blow and blow the dust out of the coil,the coil will either be in the back or on the very bottom of the machine,if the fan isn't running try spinning the blade,it might run or something could be stuck in it,i've found from a piece of paper to a mouse stuck in the blade,if it is the blade you can leave the back panel off and stick a house fan back there to cool down the machine until you get a new motor,if the motor does run after you spin it i would still change it out as soon as possible,if it stops again you could damage the compressor and then it's new fridge time.you should clean the coil at least once a year.hope this helps and next time you need help send the brand name and the model number off of the machine that you need help with
Nov 12, 2011 | Refrigerators
My fridge gets really hot on top and between the fridge and freezer where the door meets
next time send the model number and brand name.usually when this happens is the condenser fan motor isn't working.pull the fridge out,remove the bottom back panel and check the fan to see if it's working,if it is check the condenser coil to see if it's filled with lint and dust,it could just need to be cleaned out but if it's that hot most likely the fan isn't running,if you get this tonight check it now,if the fan isn't running you could blow the compressor,the condenser fan blows and keeps the compressor cool enough so it doesn't overheat by moving the hot air and the heat also esscapes through the condenser coil so if that's clogged with dust the machine will run hotter than normal,if the fan isn't running you can stick any window fan back there and blow it onto the compressor to keep it cool until you fix the condenser fan motor,this way you won't loose any food and if the compressor goes it's new fridge time,to much to repair.hope this helps and good luck with your machine.one more thing,i've found the fans not running and by pushing the blade it runs again,if this happens the fan could run and never have a problem or it could stop an hour later but i would change it out no matter what.if it's a G.E. fridge and the motor isn't running,most likely it will be the computer board,i've found 10 machines doing this and the temp. settings turning on and off or the evap fan motor in the freezer runs slow and then fast and the condenser fan isn't running or running slowly,this is why you have to send the brand name and model number.
Oct 28, 2011 | Refrigerators
Fridge temperature not correct and freezer items are all defrosting. This also happened a year ago, except it was just the freezer and the fridge freezer is only 3 years old
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 08, 2011 | Beko Refrigerators
Beko frost free fridgefreezer cda543f not freezeing
The first thing I would do is to check the compressor and the condenser fan. Remove the cover on the back of the fridge and check how hot is the compressor? Is the condenser fan turning well? Also check the condenser coil under the fridge, it is very possible it needs cleaning.
If the condenser fan is not working properly then it has to be replaced. The part number for the motor is AP117874
If the condenser fan motor is fine and the cleaning did not help then the sealed system is low on Freon and in such case you need a certified technician to fix a leak and to charge the system.
Good luck in solving the problem...
May 07, 2011 | Refrigerators
Beko fridge freezer not working
Good luck in solving the problem of the freezer...
May 06, 2011 | Freezers
BEKO CDA539F Freezer does not freeze, fan seems to work, fridge seems to be at temperature. Food soggy/melted
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Oct 30, 2010 | Refrigerators
Our Amana fridge freezer has stopped chilling and freezing
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 26, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Freezer and fridge not cooling well i clean the condenser fan
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
,.f
Mar 13, 2009 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
81 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
