Komori ls 40,feeder will not pick up sheet ,or another problem it causes is a missed sheet
  • 1894 Answers
SOURCE: Auto sheet feeder fault
just reset the printer..
that will make you work
Posted on Apr 01, 2008
  • 13 Answers
SOURCE: printing business cards
Feed sheets through front manuel feed slot.
base tray is mainly for up to 90grm paper,anything heavier
can feed for a time but tends to fault.also try and clean the
paper pick up rollers regularly.
mongrelken.
Posted on Jun 08, 2008
  • 2072 Answers
SOURCE: Paper Feeder Jams
Use this link and when you call ask for Britt. I do NOT work there but I have used them for a long time and they are greart.
Here is the URL ..
https://www.partsdrop.com/store/
Posted on Jul 09, 2008
komguy
  • 2306 Answers
SOURCE: Miss feeds when print multilpe pages
The paper feed solenoid is sticking, it can be seen thru a hole in the back with the door opened. Not easy to get to, but I have been able to bend the stop tab slightly and run just fine.
Posted on Sep 02, 2009
  • 452 Answers
SOURCE: envelope feeder does not pick up envelope or
Hi; with alcohol clean the paper take up roller and the separation pad
Posted on Oct 18, 2010
Komori feeder loosing suction
Check the secondary filter, usually the HEPA filter. This gets clogged after extended use. Remove it and take it outside and gently tap it on a hard surface dirty side down till clear.
May 07, 2014 | Vacuums
Skiping nails
Usually caused by weak feeder spring, however if new spring does not fix problem then check or replace orings on the feed piston (3 orings) , replace the driver oring and make sure that the driver sheet seal is not broken. The sheet is located at the very bottom of the inside of the cylinder area. If good, the driver will not pull out of the gun from the top of cylinder. To see the condition of the sheet, gently pull up on the driver just enough to look down the cylinder past the bumper. If the sheet is missing a piece, air leaks past the driver and does not push the driver all the way back up to top of cylinder causing miss-fire. Good luck
Sep 09, 2013 | Hitachi NV45AB2S Coil Roofing Nailer
HP Laserjet 3050 all in one
pls clean printer solenoid it wl solve
Nov 27, 2012 | HP Pick Up Roller Rm1-0885 for Laserjet...
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Thanks
Apr 01, 2012 | HP OfficeJet 7410 All-In-One InkJet...
Sep 02, 2009 | Konica Minolta magicolor 2300DL Laser...
982 Service Engine
This is caused by an option on the printer not be seated correctly or there's a prob. with 2000-sheet feeder option.
Usual Cause:
  1. Reset power or power the printer off and on.
  2. If this does not resolve the error:
  3. Power the printer off.
  4. Reseat all of the paper feed options on the printer:
    • Remove all optional drawer options, like a tray 2 or tray 3 drawer, and reposition them from the bottom up.
    • Reseat the printer on top of the duplex option, if one is installed.
    • Reseat other options such as the envelope feeder or additional output bins.
2000-sheet feeder option? See below:
Explanation of the Issue
A cable can come loose inside the 2000-sheet feeder option and cause one of the following three conditions to occur:
  • The printer displays a 982.xx error. NOTE: The .xx extension can be any number.
  • The printer displays a 990.xx error. NOTE: The .xx extension can be any number.
  • The printer does not recognize the 2000-sheet feeder option installed.
The issue is with a toroid on one of the cables (see the blue/black wire cable highlighted in the image below). When the 2000-sheet feeder option is moved, the toroid can pull the cable loose, causing an error. NOTE: This toroid was removed in later versions of the 2000-sheet feeder.
Jun 11, 2009 | Lexmark T644 Laser Printer
Paper feed feeding multiple sheets plus noisy feed
The most likely cause of this problem is a paper feeder malfunction. Because you were not specific in the model you have, repair could be rather variable.
One plausible cause is the paper rollers have tried up. Normally when the small rubber rollers grip the paper, the friction generated by a properly moisturized feeder can grip a single sheet. If your rollers are getting dry, you can use some rubbing alcohol on a q-tip and rub it on the rollers. Make sure not to use isopropyl alcohol, that will cause the rollers to dry out even more. I've heard of people using WD-40, but I've never tried that. You would want the WD-40 to dry a while otherwise it will leave greasy residue on your nice white paper.
Another cause could be a small object (paperclip, staple, raisins) stuck in the paper feeding mechanism. Carefully inspect the feeder, comparing one side to another, and gently pushing on the movable parts to make sure they can move free. You don't want to push too hard or you could knock out a needed spring or damage the plastic gears.
Hope this helps!
Oct 16, 2008 | Canon Office Equipment & Supplies
ADF will only feed one sheet then stop
no,just try to clean the roller of the ADF at the same time the separator pad.make sure that you are using paper that is 24lb weight coz if you are using paper that is so thin if may cause also an issue that the ADF could not pick-up...if the issue is still occuring return/replaced the printer...
send feedback for further troubleshooting...
Aug 23, 2008 | HP Officejet 6310 All-In-One InkJet...
My Canon MF3240 picks up too much paper and causes a paper jam every time I print.
Aug 05, 2008 | Office Equipment & Supplies
21 people viewed this question
jasbo
jasbo
