Question about JVC Televison & Video
How can I get my JVC remote control for my CD player to work again?
The battery was knocked out of the remote and since then it hasn't worked. Changed the battery in case it was damaged but there is still no response from the CD player.
    Top Expert:
  • JVC Master
  • 74,377 Answers
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Try this link too
http://remotesearch.blogspot.com/
Posted on May 08, 2014
  • 95 Answers
SOURCE: RCA universal remote
This is the eastest way to program your remote. To program a component using the Automatic Code Search method, perform the following steps: 1. Turn on the component you want the remote control to operate. 2. Press and release the component button that corresponds to the component you want the remote control to operate. info.gif The illuminated ON-OFF button turns on and remains on.
aud_remote_on-off.gif 3. Press and hold both the component and ON-OFF buttons. info.gif The illuminated ON-OFF button turns off. 4. After the illuminated ON-OFF button turns back on, release both buttons. info.gif The illuminated ON-OFF button remains on. If you press an invalid button during Auto Code Search, the illuminated ON-OFF button blinks four times and turns off. The last programmed code under that component button is retained. 5. Press and release the PLAY button. aud_remote_play.gif 6. If, after five seconds, the component does not respond, continue to press the PLAY button every five seconds until the component turns off. info.gif Each time the PLAY button is pressed, the illuminated ON-OFF button blinks ten times while a block of 10 codes is sent to your component. This process continues until all of the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited. 7. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again. info.gif If the component does not respond, continue to press the REVERSE button every two seconds until the component turns on again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks. aud_remote_reverse.gif info.gif If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again. 8. To save the new code, when the illuminated ON-OFF button turns off, press and release the STOP button. aud_remote_stop.gif info.gif If some of the features of your component do not work, different codes in the list can be tried until you find the code that allows the remote to control the majority of your component’s
Posted on Mar 16, 2008
SOURCE: My Sharp Remote Control Is Suddenly Stop Working
Ok I just dealt with the Sharp customer support for this problem.
1) You need to unplug the TV for 1 full minute and remove the batteries from your remote aswell (this will reset the system)
2) Hold the power button on the remote for 30 seconds with the batteries still out of the remote and the TV still unplugged
3) After the 30 seconds replace batteries then press every button on the remote beginning with the power button in order from left to right and top to bottom (same way you read)
4) Then plug your tv back in and try the remote again.... and the remote and TV should be back in sync.
Posted on Jan 01, 2009
  • 1214 Answers
SOURCE: i have a brand new
You may need to recode the remote since you changed batteries, and the newly installed batteries are new, and installed correctly.
Posted on Jan 29, 2009
  • 127 Answers
SOURCE: remote control not working (no functions),
Do the contacts look ok?
you can check if it is working by looking at it with a digital camera
press a button on the remote
if it shows as flashing on the digital camera screen, then you know it is transmitting.
then your problem would be either the device you are trying to operate is not receiving, or the remote is using the wrong code.
if the code is wrong then look it up online. there are some helpful sites that tell you the codes and how to program the remote.
good luck!
Posted on Jan 02, 2010
Testimonial: "Great help its pushed me in another direction"
CheriT Dish
  • 146 Answers
SOURCE: My dishnetwork remote control 1 doesn't work. It
    • All DISH Network IR remotes
1. Goto System Info screen. You can enter the system info screen by either pressingthe system info button on the front of the DISH receiver box or by pressing thepower button once then the up arrow on the front of the receiver. If theseoptions are unsuccessful you can also open the smart card door on the front leftside of the receiver and pull out the smart card. 2. Onceyou are on the system info screen, hold down the SAT button until all modelights light up. 3. Entera number between 1 and 15 using the numeric keypad on the remote. 4. Pressthe pound (#) button 5. Oncethe SAT button blinks three times, press record. Note: If successful the number selected in step 3 willappear in the System Info screen under Remote Address.
Posted on Dec 30, 2010
I need a new remote
Several sources of replacement OEM remotes are on the internet.
Jun 15, 2016 | JVC XL-SV22 CD Player
Onkyo TX DS575x reciever remote problem
You might try this replacement
http://www.remotes.com/remotes/servlet/rs?a=gmi&uid=11953114154530&smodel=TXDS575&brand_pn=ONKYO_TXDS575
Nov 17, 2007 | Onkyo TX-DS575 Receiver
My remote control does not work anymore for my JVC MXJ30 Stereo. How can I determine if I need to buy a new remote. The stereo works when I turn it on manually. However the CD player has stopped working....
There are a couple of things going on here.
The CD issue is, uh, common. They die. CD-cleaners are dubious at best.
http://www.repairfaq.org/sam/cdfaq.htm
For the remote, try this advice:
http://remotes.com/remotes/servlet/rs?=Display&contents=help_deadremote&uuid=A12954406270641
"Dead" Remotes Can Be Saved How to Re-Start Your "Dead" Remote Control
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck!
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the
unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly. New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote. If you do then the problem might not be the remote but the sensor on the unit.
eBay has some RM SMXJ30J remotes cheap. This one will set you back $11.50 delivered.
http://cgi.ebay.com/JVC-RM-SMXJ30J-REMOTE-CONTROL-/120717037068?pt=LH_DefaultDomain_0&hash=item1c1b4bce0c
May 07, 2011 | JVC MX-J30 CD Shelf System
Where and how can i purchase a remote control unit for my JVC XL-SV22 VIDEO CD PLAYER
Required remote control is available at Remotes.com
Click above link to view remote and price info
Thanks
Jan 25, 2011 | JVC XL-SV22 CD Player
Remote control no longer works
buy a new one,,,(universal remote control)
Jan 30, 2010 | JVC HR-XV1 DVD Player/VCR
Receiver remote no longer works
It sounds as though your remote is working fine. Since the storm coincided with your problem I would say that your receiver suffered a power surge that damaged the infrared receiver inside the unit. One other thing to try is to unplug the unit from the wall for about one minute, then plug it back in and try it. If that doesn't do the trick you will have to send it to a repair facility.
Good Luck,
BB
May 16, 2009 | JVC Audio Players & Recorders
Need new JVC compatible remote control
I dont know what cd player you have! but you can order an orignal remote from www.remotes.com They may also tell you how to revive the old remote!
Please rate this free answer!
THANK YOU!
Jan 17, 2009 | Audio Players & Recorders
Yamaha RAV311 remote
Here's all the JVC codes I could find, good chance one of them will at least work the basic functions:
0017, 0018, 0019, 0108, 0136, 0153, 0178, 0190, 0213, 0218, 1000, 1001, 1007, 1011, 1017, 1036, 1043, 2033, 2045, 2053, 2070, 2073, 2099, 2126, 2127
Hope this helps.
Dec 31, 2007 | Yamaha RAV-300 Remote Control
Televison & Video Logo
52 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
