Question about Garden
How to disassemble Chapin pump assemby?
No pressure in sprayer. Want to take pump assembly apart.
4 Suggested Answers
thepatioman
  • 52 Answers
SOURCE: We have a 457 model
I recently ordered just the plug on the bottom of the shaft and it solved the problem. the company was really good about sending the plug right out for free at that. it worked and im back in business. just replaced it. no taking the pump apart.
The Pool Tech
Posted on Aug 07, 2010
emissionwiz
  • 76691 Answers
SOURCE: I e-mailed a question on a Chapin Hand Sprayer
You need to comment back on the email link you were sent. Do not start a new thread.
Posted on Mar 23, 2011
mc1bean
  • 3053 Answers
SOURCE: I would like to obtain
You can get the parts for those at home depot and lowels, I just bought one a couple of weeks ago for mine, most are adaptable. Also Sears seems to have good supply as well. Thanks Mike from Fixya
Posted on Jul 07, 2011
How do you refill?
Remove all pressure by keeping the hose open until no pressure is left. place pump handle down toward tank. Turn count counter clock wise to unscrew. Take assembly out of tank then fill tank. Reinstall in reverse order.
https://www.chapinmfg.com/sprayers
May 24, 2014 | Chapin 2 Gallon Spectracide Sprayer
No pressur in my home and garden sprayer
You have a leak. First ensure the pressure relief valve is closed. You can try spraying soapy water on the outside while pumping it up, and look for bubbles. The one way valve might be leaking, too. Good luck.
May 21, 2012 | Chapin 2 Gallon Spectracide Sprayer
I would like to obtain the nozzle and tubing for Chapin Spectracide pump sprayer. The containers is in good shape. Who sells just parts
Jul 07, 2011 | Chapin 2 Gallon Spectracide Sprayer
I have a 3-gallon gilmour sprayer--has worked well-only several month old-able to get good compression but can not get anyspray-even after taking apart and rinsing your help is appreciated thanks ...
This situation sounds like a plugged hose. Keep taking apart and you will find something plugging a small orifice, somewhere... Always flush with clean water after each use, many garden sprays crystalize over time......
Apr 24, 2011 | Gilmour & Spray Doc& Poly Tank Sprayer...
I e-mailed a question on a Chapin Hand Sprayer #1949 5 days ago and have not heard from anyone. Don
Welcome to FixYa!
"I have a Chapin Hand sprayer #1949 3 1/2 gal. I need to know how to get the pump apart to install a Industrial repair Kit #6-4627."
TO UNLOCK PUMP:
Turn handle counterclockwise until 3-prong clamp is loose.
Then rotate clamp counterclockwise to stop and lift out.
Thank you for using FixYa.
Keep me posted.
Jas247
Mar 23, 2011 | Chapin Garden
Sprayer drips instead of spraying
Pressure test: pump it several times then open the cylinder (like you were going to pour in more solution): was there a noticeable pressure release? If not, then your problem is in the pump assembly. Examine the end (the end which goes into the tank) flapper valve. While the pump is out of the tank, pump it a few times. Do you see/hear the flapper move with inflowing air? If not, herein lies your problem. Put a few drops of oil down the assembly where the pump slides up/down. Work the pump a few times. If this does not solve the problem, try to dissamble the pump mechanism and MAYBE you will be able to replace faulty intern parts/gasket. If you DO have internal pressure in the tank, yet no spraying action: disassemble all parts coming after the pump. Hose, off/on switch/lever, spray tip. Yes, it will completely disassemble. Inspect/clean everything/blow out the spray tip or use a thin needle to clean the tip. While you have everything apart, use "silicon plumbers' grease" and generously lube all of the o-rings: this will afford a very good seal and prevent pressure loss. You can buy the plumbers' grease at the big box stores or plumbing supply places. Good luck.
Feb 12, 2011 | H.D. Hudson 2g Yard N Garden Sprayer
My ChapinSpray N Go sprayer won't build air pressure in the tank when I pump the sprayer
Sounds like a faulty seal to me. Submerge the container in water and pump, bubbles will rise from the seal. Easy to fix, I had a look and you can pick up a seal replacement kit for this model at Amazon.com for under $12.00. You should also find them at any reperitable hardware store. Hope this helps :)
Feb 03, 2011 | Chapin 2 Gallon Spray N Go Pump Free...
I have a SOLO 461 sprayer. After months of good service, the pressure from the spray jet drops after a few seconds of spraying. If I close the trigger, then re-open it, the spray again lasts just a few...
if it is a diaphram style replace diaphram if it is a piston style replace piston how to's are easy on both just take ur time and pay attention to removal process
Jan 15, 2011 | Solo Sprayer Parts Shutoff Valve Assembly
Sprayer will not stop pumping when switched to pump mode after primed it will not shut down it just keeps pumping. .
Paint sprayer.
Flip lever down to prime > paint comes out small plastic hose.
Flip lever up to put pressure on spray line.
Problem: prime keeps running and spray line never gets pressure.
Future solution:
You did not clean sprayer very well last time, or it is rusted. When cleaning, run full 5 gallons of cleaner through machine twice.
You should fill spray line and pump with kerosene if machine sits idle more than few days.
We all forget.
Good news: you have prime. If machine doesn't prime, you probably have to disassemble.
More good news: There are two steel balls inside pump. Tap top one with hammer to loosen. Keep machine running. Keep lever up. Start tapping top one. Tap a little harder... keep tapping ... sometimes it will not free up ... take apart pipe and see if you can nudge ball loose >> be careful not to scratch anything... the sprayer is high pressure and all parts have to fit
Oct 07, 2010 | Garden
Garden Logo
81 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
