Question about Whirlpool Refrigerators
I have a whirlpool refrigerator model w8txewfyq02 the freezer isnt freezing and im hearing a clicking noise
When I
  • Whirlpool Master
  • 4,654 Answers
The clicking sound is coming from the overload mounted under the cover mounted on the side of the compressor. You most likely have a defective start relay and it is not allowing the compressor to start. When compressor will not start the overload clicks off to stop power from going to the compressor to protect the compressor from burnout. Defective relays are caused by defective run capacitor, wear, age or a defective condenser or evaporator fan motor. Here are the parts should you choose to repair this yourself=> W10197428 Start Relay and Overload and a 2169373 Run Capacitor You should also be on the lookout for a defective fan motor to prevent damage again to the start relay should it have been cause by a defective fan motor. I am here if you have questions, Thank You, John T. Appliance 911
Posted on May 08, 2014
SOURCE: Amana AFD2535DEW freezer/refrigerator with intermittent tempurature swings
I had the same issue. It was the relay overload which essentially provides the extra boost to get the compressor going. The switch tries for about 10 seconds before giving up and then retries 3 - 4 minutes later. In the early stages of failure, eventually it will work and the compressor will kick on. But eventually the switch will fail and will just cycle through the 10 second attempt every 3 to 4 minutes. The part is about $35 - part number 67005560.
Posted on Jul 10, 2008
  • 864 Answers
SOURCE: Whirlpool runs, but freezer not freezing and frig not freezing
If the compressor is running but the unit is not cooling you may have lost the refrigerant.  See if the condenser coils at the back or bottom are hot.  If they are only warm then the refrigerant is low and can be recharged.  Service tech should check for leak in coolant system.
Posted on May 30, 2009
woodchuck789
  • 4059 Answers
SOURCE: Whirlpool
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Posted on Oct 03, 2009
  • 24 Answers
SOURCE: Refrigerator doesn't cool/freeze - clicking, cyclying noise repeates, but doesn't cool
I've been told by a tech who repaired my MFD2560HEQ this past week that many of this model had a problem with compressor failure. Your symptoms are classic. What you are hearing is the starter relay trying to start a warm/hot compressor by supplying it with an extra jolt of electricity, but because of the faulty compressor (or if you are lucky a faulty relay) that's warm (cool ones start more easily often) is refusing to budge into motion and compress the freon. Maytag, I believe, has a five year warranty on the compressors. They did on mine, but unless you have an extended warranty the labor replacing it is not covered and that will be around 2-3 hours worth. This is the price we are paying for our quest for energy efficiency. Compressors are being built so small and light that they fail much more often than grandma's old, old refrigerator that was built like Fort Knox and ran for 45 years, remember? But we're being energy efficient! Thank you environmental extremists! I wish I could send you the repair bill.
Posted on Nov 08, 2009
SOURCE: FREEZER BUZZING NOISE - Whirlpool refrigerator Model# ED5FHEXNS01
My whirlpool side by side makes a vibrating noise when in cool cycle I press at the back of the panel in the freezer side and it stops
Posted on Apr 27, 2010
Freezer not freezing clicking noises
Almost certainty you have a rear control board fault these boards where notorious for capacitor faults causing relays to click and water dispenser to be erratic , the board can be repaired by a confident electrical engineer or you can buy a complete unit
Mar 31, 2017 | Whirlpool Refrigerators
I have a Whirlpool refrigerator (model # ET2AHTXLT00). It intermittently makes a loud clicking noise that comes from the left side of the refrigerator (when youre facing it). It still is cold inside both...
What you are hearing is the fresh food damper. It sounds like it stuck open or stripped. You should have a tech look at it. It could stick closed and make the fresh food section too warm. Ihope this helps.
Aug 25, 2011 | Whirlpool GC5SHEXNS Side by Side...
I have a whirlpool upright freezer,model EVL181NXTQ.There is a buzzing noise and the top half doesn't freeze..When you close the door,uou can hear the suction sound...Please help,freezer is only 2 years...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 01, 2011 | Whirlpool Freezers
Clicking noise and freezer wont freeze
clicking noise is present on all newrer refridgerators.
Jun 09, 2010 | Whirlpool ER6AHKXPQ Top Freezer...
My Whirlpool Refrigarator isnt cooling or freezing. Its running but there is no cool air on either side. Ive adjusted the temperature control to the coldest setting but still nothing...what could the...
Pull the lower front panel off. Inside you'll see a round small timer with a screw slot in it. Turn the screw slot slowly to the right (clockwise) only, until you hear a slight click. Wait five minutes and feel the walls of the freezer, they should be getting cold by now. If so, you need a new defrost timer. Thank you, Dana
Mar 26, 2010 | Whirlpool GD5SHAX Side by Side...
Whirlpool refrigerator side by side freezer won't freeze
your over-load/contactor is defective, un plug it from compressor and shake it if it rattles its bad
Oct 28, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer quit freezing
HI,
you can try this suggestion first.
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
thanks,
Mar 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Loss of cooling in refrigerator / freezer
you may have a bad ptc or cold control. if you hear a buzzing noise followed by a click, you have a bad ptc unplug the machine and call a service company quick
Jun 07, 2008 | Whirlpool ED2NTGXL Side by Side...
Refrigerators Logo
46 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
