Question about Samsung Refrigerators
Samsung RB2055SL Refrigerator Beeping as if the door is open, but it is closed. Seems to be cooling properly....What can I do to stop the beeping?
This is a bottom freezer unit, which seems to be working properly in the cooling department...However, it will not stop beeping as if a door is open, even when all doors are closed. How can I disable the beeping?
Demy
  • 20 Answers
SOURCE: beeping while door is closed
Does this unit have a light in the freezer or fridge section that turns on when the corresponding door is opened? If it does, take a peek between the door frame and the seal around the door( while the door is closed) by sliding a thin plastic fork or knife and see if the light is on.If the light is on while it is beeping then you know that the light switch is defective.
Posted on Jul 13, 2007
  • 400 Answers
SOURCE: Fridge/freezer beeping
There is a lever switch usually above the door (when door is in open position) on the fridge cabinet. Not on the actual door. The beeping should stop if this lever is pressed. If the door is positioned correctly it would depress this lever when closed. It may be that the door adjustment is slightly out. If the beeping does not stop when depressed, then your printed circuit board (located usually above the door) is faulty and needs to be replaced.
Posted on Mar 04, 2009
odiebugs
  • 949 Answers
SOURCE: Beeping from refrigerator about once a minute.
If this is listed under the right model, then the only thing it could be is some models have a
door alarm,that will beep if the door is not closed. You could check and clean the gasket.
Or it the switch that tells the fridg that the door is closed. Check if there is a top door adjustment to bring the door closer to the fridge where the door hinge is. This might apply or push on the switch more.
Posted on Mar 29, 2009
  • 363 Answers
SOURCE: LG Fridge door constantly beeping when closed
On the display panel press the right key that turns the door alarm on and off
Posted on Jul 21, 2009
SOURCE: refridgerator beeps and upper section not working
First, the Samsung Refrigerator is the only fridge that has one compressor, but two different evaporators to operate the freezer and the refrigerator separately. Thus, you can have the bottom freezer working fine, while the fridge part will not.
The reason your fridge is not working is probably a faulty door switch in the refrigerator. The switch is malfunctioning, telling the computer that the door is open. Therefore you hear the door alarm go off in intervals, even though the door is actually closed. If the computer registers an open door, it will not pump cool air into the refrigerator, as that would be a waste of energy. All you need to do is replace the door switch. Until you get a new one, you can temporarily fix your fridge by simply removing the old switch altogether. You will not have any light in the fridge, however, it will cool again just fine until you are able to install the new switch (a simple plug-in contraption, by the way).
Hope this helps.
Posted on Jul 30, 2009
My LG refrigerator (LFC23760) gives three beeps every few seconds. Any ideas?
it seems like the icebox is picking up a problem with one of its sensors (maybe a door sensor has gone bad so its thinking a door is opened) if however it has a door alarm it can be disabled by the control panel on front of the refrigerator
Jan 05, 2017 | LG Refrigerators
Frigidaire refrigerator beeps every 20 seconds or so. three beeps.
try opening the door.leave it open.unplug the fridge for at least 5 minutes, no less,with the door still open.after that,plug it back in.wait for it to beep.then close the door.
this would reset the door alarm,which beepes when the door isn't properly closed.
also you should wait 24 hours between changing the temperature or it can mess up your fridge.!
Oct 13, 2016 | Frigidaire Refrigerators
How to stop occasional five beeps?
Here is a good link on this subject:
Cause of Beeping Noise in Frigidaire Refrigerator eHow
If it is cooling OK, try unplugging and leave it for 5 minutes but if the beeping returns and everything is normal, it could be a problem with the control board...
similar issue no freezer:
Jan 02, 2015 | Frigidaire Refrigerators
My Samsung Cool' n Cool Fridge Freezer it wont stop beeping. The doors are both shut and the appliance is switched on. I have accidently broken the little plastic mechanisim that opens and closes upon...
Hello, it needs to be reset, There two reset buttons one for the frig/frez and one for the filter--drinking water/ice maker. GB...stewbison
Aug 31, 2011 | Refrigerators
Refridgerator beeps and upper section not working
Hope this helps.
May 28, 2009 | Samsung RB2155SH Bottom Freezer...
Samsung RB1855SW won't stop beeping and fridge malfunctioning
Thanks so much for the advice. I just gently pried the door sensor switch on my Samsung RB1855SL out with a butter knife and then pulled out the electrical connection and it fired up right away. It looks like some orange juice seeped in and corroded it. What a relief to have the fridge working again, not to mention to not have to listen to the beeping.
Apr 01, 2009 | Refrigerators
Mar 29, 2009 | Samsung RF265AA Bottom Freezer French Door...
Beeping
it could be the door switch had Samsung has had trouble with the tolerances on the doors.. the door switch will also keep the light on and the temperature will be unstable. you can test it by covering the door switch with some blue masking tape to hold it in and see if the beeping will stop...the other problems with the display sound like a faulty control board.. let me know if the beep stops..I would call samsung if it is still under warranty...
Aug 30, 2007 | Samsung RS2534 Side by Side Refrigerator
Beeping while door is closed
Thats hard to say what the problem is. I would need to know if there is anything on the control panel that also is lighting up while the beeping is going on. If you can find that iut it would be a big help in finding what your problem may be. Feel free to get back to me if you can find that out.
Jul 11, 2007 | Samsung RS2534 Side by Side Refrigerator
Refrigerators Logo
99 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
