Question about Brother CS-8150 Computerized Sewing Machine
My janome wll not pick up bobbin thread
Cleaned bobbin case don,t know if i put it in right
  • Hi SANDRA J WILSON, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? do you have a manual for the machine?
    New Friend:
  • 37 Answers
Did it pick up the thread before you removed the bobbin case?
Posted on May 08, 2014
Janome memory craft out of sync
check to see if you have the thread in the bobbin case the right way
Oct 13, 2014 | Janome Sewing Machines
How do I change the bobbin in a Janome sewing machine?
There is a small plastic plate where the needle goes down through the foot, remove this cover and you will see the bobbin. Remove the bobbin and refill or selecting another bobbin turn it so that when you pull the thread the bobbin turns anti-clock-wise, slip the bobbin into the black plastic casing, pulling the thread towards the small red arrow at the bottom of the casing, slip the thread between break in the silver metal sleeve pulling it to your left between the 2 pieces of metal this is where the tension on the thread is. You have now changed your bobbin. With the plastic plate still off, hold the top thread with your left hand and with your right slowly turn the wheel, this will send the needle (holding your top thread) down into the bobbin casing and will pick up the bottom thread, pull on the top thread and bring the bottom thread up through the hole in the plate. Replace the plastic plate and recommence sewing. Good luck
Sue
Sep 24, 2014 | Janome Sewing Machines
Have Janome DC3050. Bobbin thread is getting caught on the hook shaped guard to the right of the bobbin. Hook race? I know threads got caught in bobbin and believe it bent or moved this. Now makes a...
I don't know your model but my Janome 6500 has a bobbin case held in by magnet on the underside and it will dislodge and move if there is a jam up. This then prevents it from forming stitches correctly. You need to lift out the bobbin case and put it back into position. With mine, when it has moved, the needle then strikes part of the case when it comes down. This often results in a burr in the plastic which then causes the thread to catch again even when the case is back in correct position.
There should be two marks, one on the case and one on the outside to align it to.
9k=
this is my bobbin case, and the cut away part on lower part of the image is the bit that goes into the machine away from you.
Feb 07, 2014 | Janome DC3050 Computerized Sewing Machine
Janome 3000 bobbin thread will not catch. It just quit while I was sewing. I've cleaned the bobbin case and anything else I could but when I put the needle down the thread does not circle the b
try changing the needle
rethread the machine top & bobbin
make sure to use every thread guide
make sure the bobbin is not over wound
make sure the bobbin is turned the right way in the bobbin case
make sure the bobbin is not warped or damaged
if you've done all these things then it's also possible that the machine
is out of time & needs to be checked at a repair shop
Sep 01, 2012 | Janome Memory Craft 3000
Bobbin thread is jammin up after about 3 rotations of wheel on my janome 8077 - is this a timing problem?
make sure the thread has not come off the thread take up lever
make sure the bobbin is not over filled
make sure the bobbin is not damaged
it's very possible that the machine could be slightly out of time
Sep 01, 2012 | Janome Sewing Machines
I have been using the zig zag stitch for appliques and all of a sudden the bottom thread which is a different color is showing on the top. I have rethreaded top and bottom threads, changed needles, cleaned...
it sounds like no bobbin thread tension. there should be some resistance when you pull on the bobbin thread. if there is none or too little you may have some lint or thread caught behind the bobbin case tension spring.
very carefully try and push the tip of a thin pin into the bobbin case tension spring and pick any accumulated thread or lint out.
if the bobbin case spring is clean, try tightening the bobbin tension a little at a time until your zig zag looks ok.
of-course all this is done after checking needle threading and needle for damage.
scott.
Jul 29, 2009 | Janome Sewing Machines
Want pick up my bobbin
re-thread the top thread
when putting in the bobbin, make sure you put it in right,
hold the bobbin between you thumb and first finger of your right hand when you pull the thread with left hand it should rotate the bobbin counter clockwise.
If you run your machine all day you need to clean under the bobbin case,
Take the cover plate off, take out the bobbin case and clean under, i take a q-tip with machine oil and rub around the inside of the metal case and around the bobbin case,
replace the plastic bobbin case making sure it's in right, turn the hand wheel by hand, the case should stay still and the inside will move, the needle should not hit anything
put all back together and try again
if the bobbin turns clockwise you are going to have problems
if this helps please rate it
thanks,
good luck
moni
May 09, 2009 | White Sewing White 4400 Computerized...
Bobbin thread won't pick up and tangles up in a mess.
Here is the Janome website with many good FAQ.
I had previously read thet the bunching on the bottom of that fabric is caused by the tention on the bottom thrread is not enough . Increase the bobbin tension slightly. You may have to download a manuaol to learn how,if you don;t alrewad have one?
http://janome.com/index.cfm/Search
Dec 07, 2008 | Janome Memory Craft 10000
Janome Memory Craft 9500 Troubleshooting
Have you tried a new needle?
If re-threading, changing the brand of thread, etc. does not work, then it's likely your machine is out of time. Search for sewing machine timing or take it for service.
May 24, 2017 | Janome Memory Craft 9500 Computerized...
Brother CS-8150 Computerized Sewing Machine Logo
94 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
