Refrigerator measure fill reset
Measure fill is starting at .34 oz instead of zero oz. Is it possible to reset the measure fill settings or re calibrate the measure fill? Thanks!
3 Suggested Answers
  • 2501 Answers
SOURCE: My new Kenneth Cole kc3730 wristwatch when I use
If it is a new watch then have you still got the user manual?
I have seen some watch instructions detailing how to do want you want to do, so it might be a common problem.
If you cannot sort it out and have a Kenneth Cole dealer near you, then take it in and discuss it with them.
Their web site does not seem to have any instruction manuals for downloading , so I can't read the instructions for myself but if phone them on 1 800 KEN COLE (536-26530), then they may be able to help you.
Posted on Jan 23, 2010
  • 45 Answers
SOURCE: CDJ 1000MK2. CDJ pitch control
JUST REPLACE IT.
Posted on Aug 26, 2016
Is it possible to reset display on F/P frig display panel E522b powr outage yesterday cooler----- warmer display blank
Your refrigerator could have been a victim of a power surge or spike.
Modern appliances have circuit boards which are highly susceptible to surges & spikes and you really should have these type appliances plugged into a surge/spike protector.
If all else fails, have a qualified repairman come take a look at it, or contact the manufacturer.
Dec 13, 2017 | Refrigerators
What can I try next to prevent my food from freezing?
The damper door may be broken. I had this problem in the past and the fresh food was too cold. I replaced the damper assembly and all was fixed.
Nov 10, 2014 | Refrigerators
What s the A/C compressor oil capacity in 2003 dodge durango with rear A/C
If it was shipped empty just add the amount that's stamped on the compressor. But most of the ones that I have seen where shipped wet/ full . to check get a beaker and simply remove the plugs and drain the oil into the beaker. when the system is opened it is recomended that you replace the RECEIVER DRYER also. if the compressor is damaged internally then you need to replace the EXPANSION VALVE also. hope this helps
_____________________________________________
Refrigerant Oil Capacities
Total System Fill - Front A/C Only 5.07 fl oz (150 ml) Total System Fill - Front and Rear A/C Only 7.40 fl oz (220 ml) Receiver/Drier 1.0 fl oz (30 ml) Front Evaporator 2.0 fl oz (60 ml) Rear Evaporator 1.0 fl oz (30 ml) Condenser 1.0 fl oz (30 ml) Compressor drain and measure the oil from the old compressor
Jun 28, 2014 | 2002 Dodge Durango
What is the fill volume for icemaker in white westing house model rt179h
HI,
Your answer to your question is 5.5 oz or 2/3 cup.
I hope this helps
Mar 08, 2014 | Sub-Zero 632 / S
Ice maker makes ice but freezes before it can be dispensed so the dispenser is always clogged with frozen ice. Cleaned out the ice maker and started over but same results. The temp is set at 38 for the...
Hi, The freezer should be "0", the possible clogging you have could be a leaking water valve or an over filling ice maker. I would have the ice maker checked for volume of water dispenser during harvest, should be 5.5 oz. (2/3 cup), if more the 6 oz. the ice maker is bad. If fails to stop filling or leaks/drips, replace the water valve behind the unit.
I hope this helps.
Aug 27, 2011 | KitchenAid KBFA25ER Bottom Freezer French...
Ive never filled my own gas bottle Co2 do you screw the filling station straight onto the carbon dioxide gas bottle or do you run it through a regulator ?if so at what pressure do you set regulator at
You just need to. Hook your fill station up to the big co2 tank and then hook your little tank to the fill station and turn the little one on first then the big one and make sure the little one is completely empty before filling. Co2 is measured by weight not pressure you will also need to weight before and while filling to make sure you do not overfill. if its a 20 oz weigh it before filling it then zero your scale and fill until it reaches 20oz on your scale.
Dec 03, 2009 | Tippmann A 5 Standard Paintball Gun
Lg frig side is warm but freezer side is good
You are setting your fresh foods side to 34 but the display will go back to showing the actual temp. It is still set at 34. The refrig should be able to reach the 34 setting, so although 40 is an OK temp for a refrig, it is not what you set it to and you are definitely having a problem with the unit. Instead of starting to go through a long list of checks, I would advise you to call for warranty service, as the unit is only 3 months old.
Please don't bother rating this solution, as anything but a FixYa will lower my score. Thanks.
Nov 30, 2008 | LG LRSC26940ST 36" Side-by-Side...
Sub-Zero temperture fluctuation
Just posted this elsewhere and it sounds like the same problem:
As you probably know, the recommended temperature range is between 35-45 F so if your control will not allow you to set this, the sensor or associated regulator has failed.
This seems to be an issue with Sub-Zero.
Aug 02, 2008 | Sub-Zero 650 / O Bottom Freezer...
Need equivalent cup measure for lost Sunpentown rice measuring cup
Use 3/4 of an American cup measure instead. The Japanese cups are 6 oz, American cups are 8 oz.
Apr 25, 2008 | Sunpentown SC-0720 4-Cup Rice Cooker
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
