Question about Refrigerators
How to reset refrigerator measure fill
Measure fill is starting at 034 oz instead of zero oz.
2.8 oz of onion straws is how much in cups???
cut up the onion straws and weigh out 2.8 ounces
get out your measuring cups and take the weight and start filling the measuring cups
there is no correlation between weight and volume as a conversion
Nov 24, 2016 | Coffee Makers & Espresso Machines
What s the A/C compressor oil capacity in 2003 dodge durango with rear A/C
If it was shipped empty just add the amount that's stamped on the compressor. But most of the ones that I have seen where shipped wet/ full . to check get a beaker and simply remove the plugs and drain the oil into the beaker. when the system is opened it is recomended that you replace the RECEIVER DRYER also. if the compressor is damaged internally then you need to replace the EXPANSION VALVE also. hope this helps
_____________________________________________
Refrigerant Oil Capacities
Total System Fill - Front A/C Only 5.07 fl oz (150 ml) Total System Fill - Front and Rear A/C Only 7.40 fl oz (220 ml) Receiver/Drier 1.0 fl oz (30 ml) Front Evaporator 2.0 fl oz (60 ml) Rear Evaporator 1.0 fl oz (30 ml) Condenser 1.0 fl oz (30 ml) Compressor drain and measure the oil from the old compressor
Jun 28, 2014 | 2002 Dodge Durango
What is the fill volume for icemaker in white westing house model rt179h
HI,
Your answer to your question is 5.5 oz or 2/3 cup.
I hope this helps
Mar 08, 2014 | Sub-Zero 632 / S
Where can I find the measuring cup for Black and Decker Model RC446 part #RC426-30
Using 1 cup of rice to 2 cups water does not result in perfect rice in this rice cooker. The measure cup that comes with the unit is actually 5.5 oz. measurement of dry rice and then you fill the water line accordingly. 5.5 oz of dry ingredients is equal to about 2/3 cup.
Nov 08, 2012 | Black & Decker RC400 7-Cup Rice Cooker
Ice maker makes ice but freezes before it can be dispensed so the dispenser is always clogged with frozen ice. Cleaned out the ice maker and started over but same results. The temp is set at 38 for the...
Hi, The freezer should be "0", the possible clogging you have could be a leaking water valve or an over filling ice maker. I would have the ice maker checked for volume of water dispenser during harvest, should be 5.5 oz. (2/3 cup), if more the 6 oz. the ice maker is bad. If fails to stop filling or leaks/drips, replace the water valve behind the unit.
I hope this helps.
Aug 27, 2011 | KitchenAid KBFA25ER Bottom Freezer French...
Gas ratio for a weedeater XR50
the listed 40:1 ratio works fine but 50:1 has been my usual mix. Important - use non ethanol gas E0 or gas that has chem ethanol modifier. (Pilot brand Gas works) When finished try to run it out so the carb is empty. Even a dead start with quick start to clear all fuel. Easy mixing is to measure a 41 oz marked bottle. Add 1 oz of best two cycle oil then fill to mark.liljack
Aug 16, 2011 | Garden
Ive never filled my own gas bottle Co2 do you screw the filling station straight onto the carbon dioxide gas bottle or do you run it through a regulator ?if so at what pressure do you set regulator at
You just need to. Hook your fill station up to the big co2 tank and then hook your little tank to the fill station and turn the little one on first then the big one and make sure the little one is completely empty before filling. Co2 is measured by weight not pressure you will also need to weight before and while filling to make sure you do not overfill. if its a 20 oz weigh it before filling it then zero your scale and fill until it reaches 20oz on your scale.
Dec 03, 2009 | Tippmann A 5 Standard Paintball Gun
How mutch fork fluid does it require for the xt 600
hay matey, best to use mums or the mrses plastic gravey jug,or if u have your own 4 measuring .. , in each fork leg u need 18.9 imp oz,,or 18.1 us oz of 10w fork oil or equivalent, after filling ,slowly pump fork up and down to distribute oil,, ,ok m8,, i had one of these babys,,so u no if its filled correctly, from the top of the inner fork tube, fully comprest with out the spring inserted,,, the gap from top of tube to the top of oil level , should measure 155mm,, hope that helps yuh
Jan 10, 2009 | 2000 Yamaha XT 600 E
Need equivalent cup measure for lost Sunpentown rice measuring cup
Use 3/4 of an American cup measure instead. The Japanese cups are 6 oz, American cups are 8 oz.
Apr 25, 2008 | Sunpentown SC-0720 4-Cup Rice Cooker
Refrigerators Logo
19 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
