How do you get to the safety switch under the lid of a estate washer etw4300tqo how do I bypass the switch
  • 41 Answers
Do not bypass the lid switch this is an important safety device the machine would be classed as dangerous if you did manage to do it sorry cant help you .
Posted on May 11, 2014
5 Suggested Answers
SOURCE: GE Profile WPRE6100G Top Load Washer how do you
worst washer I ever owned how do you bypass water level so you can wash a comforter man I am so disappointed with this GE Profile energy saver if I can't move the water level up I'm going to put it out along the road a trash day and it's only 4 months old
Posted on Dec 26, 2010
  • 215 Answers
SOURCE: Estate washer lid switch
Simple, dont as this could be very dangerouse. as machine will work. Think saftey as you dont want children, or your own limbs ripped from your body for the sake of saving a small ammount of money.
Posted on Mar 09, 2010
Controlfrk
  • 304 Answers
SOURCE: hotpoint washer how do i bypass lid safety switch
I think a magnet will do it. Lay it on the plastic pad beneath the lid
Posted on Aug 23, 2009
ercupa190
  • 12223 Answers
SOURCE: ESTATE etw4300TQO washer runs water for 30 seconds and then shuts off
1) test the timer for defective, however clean the contacts, loose wires or broken repair see the diagram
2) lack of cold water, fix it.
God bless you
Posted on Jul 03, 2012
How do i bypass the lid lock switch on my amana top load washer
I had that problem with a top loader and wedged half of a wooden clothespin between the lid and the switch to close it. Problem solved!
Feb 18, 2013 | Amana Washing Machines
God bless you
Jul 02, 2012 | Estate Top Load Washer
Washer has stopped and won't move on to rinse cycle and won't drain. It's done this before but if I jiggled the lid, it would continue. That is no longer working. The washer has finished the wash cycle...
Its the lid switch that is defective..located under the top panel portion of the machine and engages the lid when it shuts as a safety device....unplug and try to locacte it yourself.
Feb 23, 2011 | Estate TAWS800JQ Top Load Washer
When we start Washing Machine it takes the water as it required but agitator does not work & not spining. Please tell me the reason & also solution of the said problem. Thanks &...
the lid safety switch is bad,this switch located under the lid kills the power to the machine when you open the lid during any cycle,but the fill cycle for obvious safety reasons,remove 2 screws from the control panel,then 2 brass colored clips under this panel with a screw driver,then unplug a connector from the top of the unit,this is the lid safety switch,you can try bypassing 2 of the 3 wires that go from this plug to the control panel which will be either black or white or gray wires, but leave the green wire (usually found in the middle or on one end of this connector) alone as this is the ground wire,then if the washer runs by jumping the other 2 wires,then replace the switch by tilting the cabinet towards you all the way to the floor and replacing this switch under this cabinet but (be careful when bypassing this switch( if you try it) as when its plugged in there is 120 volts across these wires)
Feb 13, 2011 | GE WBSR3140DW Top Load Washer
I have a whirlpool washer estate, it will not spin. what can I do.
replace the lid safety switch under the lid by removing the control panel and then the top cover and unplug the old switch connector under the control panel you removed and remount the new switch on the cover and lid mounting area
Aug 01, 2010 | Whirlpool Washing Machines
How do u remove the safety which is under the lid of the washer
the washer lid is held in place with spring clips, use a putty knife to pry the lid up gently and expose the switch
Jul 29, 2010 | Estate TAWB600JQ Top Load Washer
The machine starts out fine but when it is supposed to spin it does't always do so. If you bang on the top of the machine where the lid switch is it will then start the spin cycle. Estate Heavy Duty/ Super...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
May 10, 2010 | Washing Machines
Mar 09, 2010 | Whirlpool LSR6232J Top Load Washer
It fills up and won't agitate. It seems taht
not advisable to bypass switch this is a safety device to prevent injury your switch is adjustable or repairable by lifting the hob locating switch and doing necessary repair or adjustment please do not bypass think of your safety and the safety of others
Nov 04, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
How to Find Lid Switch on Maytag Washer
i would recomended, becouse it is not just lid switch, on this model it is a small conroler..but if you still want it...it is on thge back of your top lid, right on the center..open your lid and look under
Aug 25, 2009 | Maytag LAT3600A Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
