How to disassemble fujitsu siemens S7210?
I am trying to remove the front casing which is open on the left but stuck for some reason on the right!!
  • 31 Answers
Question:
1. Why do you want to take this thing apart?
Options:
1. Get the service manual
2. Pay someone qualified to do this in person, or, instruct you remotely (a local shop that does this day in and day out)
3. Do the work yourself, and keep very careful track of where you put all screws.
Posted on May 09, 2014
Testimonial: "I am trying to replace the AC jack as getting no power on laptop. I never thought of getting the service manual, but have now managed to get it from ebay. Thank you so much your help is very much."
SOURCE: Fujitsu Siemens AMILO Pro V2020
check if the power botton ve not shifted on the board and confirm if the system was properly shut down,but if the problem continues try and repair the operating system.
Thx
Posted on Feb 22, 2008
SOURCE: Samsung v20 disassembly
After removing the screws, lift the keypad by releasing the two latches just below the ALT key and WINDOWS key. Two more screws are hidden beneath the keyboard. Hope this helps
Posted on Sep 05, 2007
gcsltd
  • 239 Answers
SOURCE: how do I dismantle fujitsu siemens amilo pro v3515 w1
Please before doing so, connect another screen to your laptop & switch on monitor, then laptop. If the 2nd monitor displays well, this means that your graphics are OK but the LCD panel is faulty.
Faulty LCD is caused by the inverter board or CCFL lamp in LCD. This means that only LCD is affected.
Please rate this advice if you found it helpful. You can come back to me in case you need to know more. Thanks friend.
Posted on Feb 27, 2010
  • 4 Answers
SOURCE: Disassemblly of the case of a LENOVO Y510
We did it!
http://jump.fm/UQSLA
enjoy
mail me to mk4th@walla.com if it gets down
Posted on Aug 08, 2010
SOURCE: How to disassemble Fujitsu Siemens esprimo?
ikkenom you ******* ****, Is that a solution?? ********!
Posted on Nov 10, 2010
How do I change an HDD in Fujitsu Siemens DT7-D2264?
Remove any external power source and laptop battery. Turn the laptop over and remove the screws that hold the cover. Remove the hdd.
Sep 19, 2014 | Computers & Internet
I want to open the cover of fujitsu siemens desktop
Did you check the section in the User Guide titled Opening the Casing?
If you have the keylock on the front make sure it is in the unlocked position. Press the two tabs on the sides and slide the case to the rear about 2 CM, then it will lift straight up.
If you don't have the manual, you can download it from here:
http://www.fujitsu-siemens.com/support/manuals.html
goodluck
Feb 23, 2011 | Intel Computers & Internet
I have got a problem,when i wanna run the wireless on laptop,it doesnt allow me to connect,it keeps saying "turn on your wireless compability" and it says that you can do this by switching on a...
Here the list of FUJTISU SIEMENS-AMILO models and where the wireless switch is located. Hope this will helps. Check what family your laptop belongs to then turn on the wireless swith using the list below:
Fujitsu Siemens Amilo A Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo D Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo K Series ---- Not Wireless
Fujitsu Siemens Amilo L/EL Series ---- Fn / F1 to turn on/off
Fujitsu Siemens Amilo La Series ---- Fn / F2 to turn on / off
Fujitsu Siemens Amilo Li Series ---- Easy launch button (one of 3) on top of keyboard
Thanks for using Fixya.
Jan 27, 2011 | Computers & Internet
How do I replace the fan in my Fujitsu Lifebook S7020 or find instructions to do so?
I found this in my archive, it is not the S7020 but it is the S7010. I believe they have the same case design, so this will most likely work for you. It is a aolor picture guide to the disassembly of the laptop.
http://www.r3uk.com/index.php/tech-tips/34-disassembly-guides/48-fujitsu-siemens-s7010-disassembly
Jun 23, 2010 | Fujitsu LifeBook S7020 Notebook
How to remove hard drive fron siemens lifebook s7110
Turn Laptop over, looking at it so the battery is at the top edge. In the bottom left hand corner is a rectangular access cover with some air vents, unscrew the 2 screws and take off the cover, you my need to use a flat screw driver to lift it, you should now be able to see hard drive. Remove any screws holding drive and slide it either left or right to to disengage it from its connections and lift it out.
Mar 31, 2010 | Fujitsu Siemens LifeBook S7110 Notebook
How do I remove the cover on a Fujitsu Siemens SCENIC E600
Just remove the thumb screw and slide the casing going to the front.
Jan 21, 2010 | Fujitsu Siemens SCENIC E600 Green PC...
Not picking up wireless networks
What you need to verify is that the wireless adapter is not disabled or turned off. There is a switch on the front edge of the unit that will turn the adapter off and on.
if you go to http://solutions.us.fujitsu.com/www/content/pdf/SupportGuides/S7210_GSG_B5FJ-5241-01EN-00.pdf you can see the picture of where it is, but from the center on teh front edge, where the latch is, moving to the left, is the mic socket, the headphone socket and them the on/off switch you are looking for. slide it the other way and that should get you back on.
If that doesn't turn is back on, verify in the network connections that the adapter is enabled as well.
May 18, 2009 | Fujitsu Siemens Fujitsu LifeBook S7210...
CPU cooling fan failure on Fujitsu Siemens Lifebook 7010D
I have opened dozens of these in the past and i have one in front of me at the moment...the easiest way to do it is. Get a blank white sheet of paper. Close your laptop and turn it face down. Remove all the screws underneath.As you remove the screws put them on the white piece of paper.So if you remove the screw from the top right then put the removed screw on the top right of the blank white page.
When you have all the screw removed the first thing to come off is the section at the on/off button (about 1nch thick covers the six buttons and has the display on it) Open the screen flat and fully extended.Remember at the back you will need to clip off on both side the grey plastic piece.(beside 2 usb connections and network port) when this section comes off you will see 2 screws underneath for the keyboard to come off...I think you will get it from here....
PS: watch out for the wireless button on the front left... this can pop off when putting it all back together....I'd say somewhere like maplin is a good place to look for one of these fans when you have it removed....best of luck
Mar 26, 2009 | Fujitsu Siemens LifeBook S7010 Notebook
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
