Question about Refrigerators
Amana refrigerator ice maker
Mana ARSE665BS side by side. Ice maker works, water dispenser does not. When dispenser pushed slow trickle of water and great thumping heard from back of refrigerator. Occasionally it will thump on its own. Water flow is good, I checked it. Water tank in bottom of refrigerator not frozen as I can see air bubble move inside of it when twisted around. If I'm getting water, albeit slowly, out of the dispenser I conclude the line is not frozen. Checked continuity on each of the two solenoids and I get continuity from one of the double plugs on each, not both. I'm assuming one controls the ice maker and the other the dispenser, but don't know which. Assuming it is a bad water valve but can't reach around to push dispenser to hear or feel it vibrate. About the replace both for lack of ability to determine which is bad.
    Top Expert:
  • Refrigerators Master
  • 12,962 Answers
You are on the right track since the solenoids control the amount of water reaching the ice maker and the water tap. Sometimes over a period of time the plunger or moving part of the solenoid just gets stuck and a good cleaning will restore it to proper operation.
Posted on Mar 16, 2017
aborcass
  • 2651 Answers
SOURCE: Slow water coming out od water dispencer in door.
first off replac ethe water filter in the unit this will slow down the flow
Posted on Feb 16, 2009
  • 74 Answers
SOURCE: ice maker and now water dispenser does not work
Do you get water to the connector at the bottom of the freezer door ? if you do then the water pipe in the door is probably frozen - read new door ! if not then check thw electrical connector at the bottom of the freezer door as they have a habit of corroding.
Posted on Feb 26, 2009
mastatech
  • 478 Answers
SOURCE: water does not reach ice tray, ice maker appears to be cycling
Pull the filltube from out of the back check for ice inside, use warm water to melt.
Posted on Mar 12, 2009
  • 5603 Answers
SOURCE: My Frigidaire refrigerator is model
Look up how the valves work. They are "servoed", that is a SMALL pintle is pulled by the solenoid from a small hole in a diaphram which then actuates the main valve seat. A tiny bit of crud in the pintle hole will block operation. These valves are used in many appliances such as dishwashers.
You MAY be able to clean the valve by removing the unit and disassembling where the diaphram is. Theree will be a spring behind the pintle so don't lose it when you open it.
Posted on Jun 08, 2011
SOURCE: ge profile refrigerator slow water dispenser
Have had problem with slow water dispenser in GE Profile refrigerator for two years. SOLUTION IS TO INSERT A THIN PLASTIC OR BRASS WASHER. The washer must have a hole large enough go over the center post / plug with the two O rings but not so large it interferes with the seating of the filter. The objective is to fully depress the little black valve piece. The little ramps on the new filters do not fully engage the valve and thus the water trickles out. Volume increased from one cup per 20 seconds to 1 cup per 10 seconds, double the flow. Washer 1 mm thick will do the trick (about a dime thickness). I used a thin brass washer which barely fit the center post, had to remove O rings to get it on. (Re-install O rings.) The outer diameter of the washer was just enough to touch the little black valve nub. If this works for you please repost and pass the word.
Posted on Nov 12, 2012
Frozen food defrosted and ice maker stopped working......water dispenser is working and refrigerator is working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
adafd
Apr 11, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Outside ice despenser is dripping, no ice
water dispenser -Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
ice maker - If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Sep 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana ice maker clicking - still makes ice just really slow
level the refrigerator. i/m not level causing it to jamb and cause low ice production
Aug 25, 2009 | Amana 25.8 cu. ft. Side-by-Side...
Ice maker will not make ice, water dispenser is working
heatman101
oypyiooiyp
May 27, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Water dispenser no longer dispenses water. Ice maker still works
Has it stopped completely or just slowed to a trickle. If a trickle you need to replace the filter. If stopped either the feed line to the fridge has been pinched/shut off or the internal line has frozen, or the valve is no longer functional.
May 25, 2009 | Whirlpool GS5SHGXKQ 25.3 Cu. Ft. Gold Side...
Water does not reach ice tray, ice maker appears to be cycling
Mar 12, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Feb 15, 2009 | Amana ARSE66MB Side by Side Refrigerator
Automatic ice maker doesn't fill with water
Probably the double water inlet solenoid valve on the back of the cabinet (one for the water and one for the ice, one component). Or a blockage in the water supply line, and even on one occassion the pipe feeding the ice machine was not in situ and water runs down the back of the freezer. Easiest way to check is to locate this part (back RHS) and switch the ice and water over and see if this has an impact. If you are not a practical person do not touch the back section (compressor side). Hope this helps.
May 26, 2007 | Amana ARSE665BS Side by Side Refrigerator
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
