When I typed in images for places, I could swipe loads of pics. Now it doesn't work like that any more. Why not?
Fingerprint reader working but not showing image
From the description it is a software problem, If you were sticking things in the scanner bar that would not help and it will prevent the laptop from working.
Mar 30, 2012 | HP Compaq 6910p Notebook PC PC Notebook
Some how i can't see my friends pics. and my family pics. on my wall..thanks
The solution will depend on which browser you are using. But try this:
On your friends list, right click on the place where a photo should be.
You should see an option near the option for blocking pictures from Facebook, turn that option off.
If you are using Firefox:
Go too tools, then options and click on the content tab. Under content choose exceptions for the load images automatically option.
Profile.ak.facebook.com should be listed as blocked, remove it from the list and profile pictures should be visible.
If you are using Google Chrome:
Go to Preferences, then Under the Hood and click "Content Settings" in the Privacy section. Under "images" make sure "show all images" is selected.
Please let me know if these solutions do not work. Thank You.
Sep 05, 2011 | Facebook Social Network
DOWN LOAD PICS FROM PC TO PHONE
Basically, you just mount your phone via USB and place the images on the sdcard. Ideally you would want to create a Media\Wallpaper folder or something to put them in to stay organized.
Once the images are on your phone, you unmount, long press on any open area of your screen and select set wallpaper (or hit Menu > Wallpaper). Then choose gallery and you should see whatever folders you dumped them into. It will scan the entire sdcard so their location really doesn't matter, it's more of an organization thing as I said.
You could also just text them to your phone, or send them to gmail and download directly through your phone without having to mount it.
May 16, 2011 | HTC Inspire 4G Smartphone
I was looking my friends profile pics,accedentally i was click the block images...my problem is when i open my facebook i cant see my profile pics and ny friends profile pics...what im going to do to go...
In your browser window, check under Preferences then Content and click the exceptions button to the right of "load images automatically" and see if Facebook is blocked. If it is remove it. If load images automatically is unticked, put a tick next to it.
Jan 14, 2011 | Computers & Internet
Transferred pics from computer to card and the camera will not display them - all are jpeg just like what the camera takes. These were from the camera but I wanted them back on the card also.
once out of the camera & deleted form the card, the camera will not display any of the images because it does not have that function. even jpeg images being the same format cannot be viewed.
Apr 21, 2010 | Kodak EasyShare One Digital Camera
Can't load more pics to internal memory,past about 100 photos
Your jpg files(pics) may be too large.
reduce them (i use 800x600.)
Irfanview is a good resize pgm(free)
fred
Dec 11, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
Pics don't load
check the size of the pics that you upload, there is always a size constraint o the images and the most important thing is that check the format of image most of the website support only jpeg(jpg),gif,png format
Nov 03, 2009 | Facebook Social Network
Scanner working wrong
Distorted images with lines present from scanned pics arises when the power supply is already below the rated output voltage or regulated power supply is defective. try fixing the power supply section but check if it still have a correct output voltage, or replace the power supply with a new one if the power supply of your scanner is a plug in type, or try to plug the scanner somewhere else in your place... hope this help :-)
May 24, 2009 | Epson STYLUS CX3900 All-In-One InkJet...
Up loading pics
The camera comes with software, if you cannot find the disk, you can download it from here:
http://www.canon.ca/inetCA/en/serviceDetail/method/load/id/1/sid/50/mid/2000029/type/D/opt/1
Download this manual
http://gdlp01.c-wss.com/gds/4/0900001034/01/DCSDV30_EN.pdf
Read pages 16 - 20, they explain all about different methods of downloading all images, just new images or even selecting specific images.
Mar 03, 2017 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon XTI
There are a few things to do in order to identify the problem more accurately. First, is it a "spot" or a "line" on the images. Second, is the "swipe" in relatively the same spot on multiple images. Are you using an external flash? In order to rule out the dust problem, you'll need to retreive the manual for your camera, and after removing the lens, follow the intsructions listed to move the mirror inside the camera to it's raised position and open the shutter. Once the mirror is out of the way and the shutter is open, you can inspect the camera's imaging sensor for dust or dirt. Based on your description of your problem though, it sounds as if you may be using an external flash. If you are using an external flash, you need to be certain that the camera does not exceed it's "sync speed". The maximum shutter speed used should be 1/250th of a second with this camera. If you are using a faster shutter speed, the images will be noticably darker on one half of the image. Hope this awas helpful.
Dec 07, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
