Question about AT&T 650530003417 Cordless Phone
No names on called ID
I have 2 phones, and one does not show all of the Called ID. Some of the numbers come up, but they are not all visible. I have tried to put it on the main base for an hour or so, but it still comes up with not visible.
Can it be the battery? I don't want to buy a new battery if it is the phone, and I have to purchase a new phone
  • 48 Answers
Problems like this generally do point in the Battery direction. I would try it, and see. I recommend BatterySpecialists. We at IdacomUSA buy batteries from them quite often, and I've never been burnt.
Here's a link to the battery you need from their site. For $10 dollars, you can't go wrong.
AT&T 1487 Cordless Phone Battery
Posted on Jun 22, 2009
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
Caller ID does not display name on Nortel phone
Cell phones do not send caller name, so create a Speed Dial entry for that number with the name you want to see. When a call arrives from that number, the system will show the name you have programmed.
Jul 11, 2017 | Nortel T7316E 2-Line Corded Phone
How do you display caller name and not just telephone number
Caller ID (caller identification, CID), also called calling line identification (CLID) or calling number identification (CNID), is a telephone service, available in analog and digital phone systems and most Voice over Internet Protocol (VoIP) applications, that transmits a caller's number to the called party's telephone equipment during the ringing signal, or when the call is being set up but before the call is answered. Where available, caller ID can also provide a name associated with the calling telephone number. The information made available to the called party may be displayed on a telephone's display or on a separately attached device.
Apr 24, 2011 | Innovage Touch-panel Phone 1502084
No called ID
Does the LCD just display "Incoming Call"? if so please list your model number and I might be able to help you further.
Jun 23, 2010 | Uniden DECT 6.0 Cordless Telephone...
How do i get my lucent partner 18d to show caller id name & number
2 line caller id is offered on newer versions of software. On earlier versions a call id name button is used to toggle between the clid name and number.
To program a button on your set press feature 00, press a button you wish to program as clid name,
and press feature 16, press feature 00 to exit programming. Press the button to toggle from clid number to clid name
Nov 03, 2009 | Lucent PARTNER18 Corded Phone
No caller ID
u go 2 settings and there will b 1s 2 do with calls 1 should say show user id?
Jun 25, 2009 | Cell Phones
Caller id will not show on incoming calls. it will not show number or name just call. i have tryed all settings please help
I had the same problem with my phone on the Orange network. I called Orange service help desk and they sent me a service message which once read and deleted, corrected the proble so that i can now see who is calling.
Mar 15, 2009 | Nokia 2630 Cell Phone (Unlocked) - Black
Caller id
First you need to verify if the caller id does that to all incoming calls, showing numbers only, or if it only does that to only numbers stored in directory. If it does that to all incoming calls then you need to check manual to see if there a setting to allow both name and number of all incoming calls. Either way you need to make sure caller id functions allows both name /number on display.
Oct 13, 2008 | Panasonic KX-TG5672 Twin Cordless Phone
Caller ID not working. It did work then one day nothing. Called phone company they checked and said nothing on their end. This is the KXTG5777ST base phone with 4 satellites. None of them have caller...
try entering *82 then followed by the number u are calling, for example : the number ur whom to call is 123456789 then u'll enter *82123456789 try that and if that works. go to urprovider to have it unblocked coz u have a blocked phone caller id. and note ur phone number will be show if it is emergency call....
glad 2 help...
May 04, 2008 | Lands Phones
AT&T 650530003417 Cordless Phone Logo
102 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
