Question about Hayward Pool & Spa
How do you know if your hayward s 200 is not running right
I have sand in my pool
    Champion:
    Scholar:
  • Hayward Expert
  • 239 Answers
Sand in your pool is a sign that you may have damage inside your sand filter. it is not uncommon for laterals to break during winter months. also, as the sand wears, it becomes smaller and may pass through.
remember that the filter sand is white. if you have sand in the pool that doesnt look like filter sand, you may have a problem with a broken line back to pool. keep an eye on your water level as you will lose water with this scenario
Posted on Mar 16, 2016
  • 52 Answers
SOURCE: There's sand in my pool!
I have had this issue with several clients and before worrying, you might have had sand being drawn back into pool lines during winterization. this happens when you blow out lines, plug holes, but keeping it pressurized. if it keeps happening check draw fins on bottom of filter.
Posted on Mar 02, 2009
  • 19 Answers
SOURCE: How to change sand in Hayward S-200 Sand filter
hayward S-180 filter takes 150lbs, S-210 takes 200lbs not familur with the S-200. To change sand you have to remove the vari flow valve on top. You can either unplumb the filter and roll it over on its side and try washing the sand out or try scooping it out upright. Whatever you do dont damage the laterals on the bottom of the filter. When refilling with sand you want to make sure all the laterals are undamaged and in the down position. I always fill the filter half full of water to keep the sand from damaging the laterals while re-filling the filter with sand. Make sure you use pool filter sand and not play sand!
Posted on Apr 30, 2009
  • 93 Answers
SOURCE: How do I chabge the sand in my s-200 Hayward sand
take top off open bottom drain use a small wet vac hose to get as much out through top out be careful not to damage filter bars wash the rest out through bottom drain with a garden hose
Posted on Jul 03, 2009
john224
  • 1378 Answers
SOURCE: How to refill the Hayward s200 sand filter for
Fill the empty and cleaned tank about half way with water, cover the stand pipe in the filter with a plastic cup or some other means to ensure sand will not go down the pipe. Be sure the pipe is centered in the hole. Add 200# of #20 silica sand and once filled use your hand to reach in a level off the top as best you can. The sand will be about half way up the filter and now the water will be near or over the top. Once done, secure the valve in place and connect the hoses and you are ready to go.
Posted on May 18, 2010
jharwell668
  • 640 Answers
SOURCE: hooking up filter to pump and pool
This website contains a copy of the owners manual for the S180T pool filter. It should have all of the information that you need.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
It is in PDF format. let me know if you have any trouble opening it.
Posted on May 24, 2010
How much sand do you add to a Hayward Sand filter S-21OT
200 pounds of sand make sure you use pool filter sand make sure not to get sand in pipe
Jun 27, 2014 | Hayward SAND FILTER, PRO SERIES
I have a hayward sand filter pro series and for some reason the water from the pool keeps draining I need to know if the switch at the top is at the right direction
check to see if water coming out of backwash valve while if filter position bad multiport gasket you can put a valve on it and close when not backwashing
May 20, 2014 | Hayward SAND FILTER, PRO SERIES
We need to change the sand in our filter ,it is a sw256t hayward ,but dont know how to remove other sand,does anyone know how?
Once you have the plumbing disconnected and valve removed,
Use a shop vac. Works well.
Once the sand is almost all removed, you can tip the tank over & rinse out with hose for the rest.
Jul 28, 2012 | Hayward Pro Series 18" Above Ground Pool...
Sand coming into pool from newly installed 220 hayward sand filter. It was recommended by the local pool distributor to add a 50 pound bag of gravel to the bottom and then 200 pounds of #20 sand. Should...
The problem was you didn't fill the tank with water or added the gravel to fast and now the lateral assembly is broken and letting sand into the pool. You'll need to empty the tank and replace the laterals. Add gravel slowly after you fill the tank half-way with water first.
John
May 13, 2011 | Hayward SAND FILTER, PRO SERIES
Hayward 1.5 hp sand filter
Hi i have a Hayward S-180 sand filter and when i clean the pool green algie shoots back into the pool.
Jul 26, 2010 | Hayward SAND FILTER, PRO SERIES
I need to change the lateral holder assembly and bottom screen on a Hayward S-200 sand filter. Will I need to remove the variflow valve or will it just come right out?
You will need to remove multiport valve and remove all the sand with a scoop. Not alot of fun. Think about replacing sand with ZeoBrite filter medium when you put it back together
Aug 02, 2009 | Hayward SAND FILTER, PRO SERIES
We have found sand in the bottom of our inground pool we have a hayward pool sand filter what could be the reason
have you added sand to filter if so may be to much make sure that handle is in the right position check by changing setting several times to make sure sprocket under handle is not damaged sounds likeit is not seated
Jul 14, 2009 | Hayward SAND FILTER, PRO SERIES
Jul 02, 2009 | Hayward SAND FILTER, PRO SERIES
Apr 27, 2009 | Hayward SAND FILTER, PRO SERIES
Pool & Spa Logo
50 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
