Question about Microwave Ovens
How do i change interior bulb in tesco MC209 combination microwave oven and grill?
How do i change interior bulb?
SOURCE: MICROWAVE OVEN
TURN TABLE WORK S BUT THE GRILL IS WARP
Posted on Mar 31, 2008
ginko
  • 19396 Answers
SOURCE: microwave not working but oven and grill do
Test the high voltage capacitor, the rectifier diode.or the magnetron.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Posted on May 21, 2009
  • 97 Answers
SOURCE: MICROWAVE OVEN NOT HEATING UP FOOD
Will need to pull apart to check....common failure with magnatron fuse....but could be magnatron, capaciter, diode. sugg to have a tech look at....if your not able to check, also call manufacturer, sometimes will cover.
Posted on Jun 10, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave lamp burn't out
You can find owner's manuals (which would cover any user-replaceable lights if present), installation instructions, and parts list, which have helpful exploded view diagrams here.
You can order parts here.
Posted on Jun 30, 2009
  • 128 Answers
SOURCE: GE PEB1590 microwave oven. Interior light burned
Remove the screws from around the rear of the oven and slide the cabnet off to the rear. You should be able to access the bulb from here.
WARNING: any time you work on a microwave you have to be careful of the capacitor. Unpluge the microwave and discharge the capacitor with a large screwdriver with a plastic handle.
Be careful.
Posted on Dec 31, 2009
Change interior light In my ge pvm1870sm3ss microwave
have to take the outer shell off to access the light .
Mar 09, 2016 | GE Microwave Ovens
Grilling bulb out
hello chris microwave is an american model
I found the tube/bulb you looking for is like the picture and called quartz grill tube and can be replace by similar voltage 120 v
Apr 01, 2014 | Whirlpool GH6177XPS Microwave Oven
The light in my microwave went out. how do i replace the light bulb?
Some have a plate on the interior of the oven that can be removed for easy bulb replacement but if yours does not you will have to remove the entire outer covering to access the bulb. If you have a combination microwave/Range vent you will have to remove the entire unit from the cabinet, then remove the outer cover, replace the bulb and re-install the combination unit.
Dec 13, 2011 | Microwave Ovens
I need to replace the interior bulb on my GE profile model jvm1850dm2vv microwave oven. Can I access it from the area where the replaceable filter is?
The oven interior bulb is on the top. Look closely at the grille above the door. There are two recessed screws that hold the grille in place. Remove these and carefully pull the grille straight out. You may have to wiggle it a bit - it's a tight fit on most of those I've serviced. Look in the center of the oven above the door. There is a sheet metal cover held in place with one or two screws (usually one, plus a plastic tab going into a slot in the sheet metal). Remove this screw and pull out the sheet metal. You will see the light bulb and the microwave stirring plate motor. Note that the instructions say you should unplug the oven before changing the light bulb. GE's lawyers are afraid you'll stick your fingers in the wrong place and somehow get shocked if you don't have the power removed.
Jan 31, 2011 | GE Profile Over-the-Range Microwave
I have a MTG06 combination microwave oven and grill that i purchased from tesco. i broke the glass turntable and need a replacement, where can i get one other than from tesco Thanks
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
The information is normally free of charge.
I hope this helps
Jan 09, 2011 | Microwave Ovens
GE profile spacemaker mircoware oven change interior light bulb
Check behind the grill on the front top of unit. you can remove it by takign out a few screws from the top. There may be an access door there, if not unit would have to be pulled down and the case taken apart.
Dec 02, 2009 | Microwave Ovens
Amana AM6177 Microwave
Interior light bulb is located behind the grill, above door. It requires removing 3 or 4 screws to remove grill. I have same problem. I pulled out bulb, it looks like it was glued in some type of foam material. There are two pin connectors at the mounting. but I can't see how they fit into bulb.
Apr 07, 2008 | Amana AMV6177 Convection/Microwave Oven
How do i change the lightbulb in my Zanussi ZCM32T Combination Oven
hi
two VERY important things... first, turn off the breaker (power) to the unit, and second, do NOT touch the bulb with your bare hands (use thin gloves or rubber gloves), you don't want to get any thing on the bulb, like grease. I don't know this exact model but, to remove the bulb, there should be a grill on top of the microwave, take that off and there should be a panel above the bulb inside, remove that and you should be able to reach the bulb now.
Mar 21, 2008 | Microwave Ovens
Interior Light
The interior oven light can be accessed in the following way:
1.Open door and remove the top grill via the 2 screws along the top edge.
2. In the interior light will be under metal plate with fasten by single screw. The halogen bulb is rated at 120V 20watt. Looks like a G-8 bulb with 8mm pin spacing with o.a.l. 1-5/8" long
Get these bulbs cheap at http://www.1000bulbs.com/120-130-Volt-G8-Base-Halogen-Light-Bulbs/
Jan 01, 2008 | GE JVM1790 1000 Watts Convection /...
Microwave Ovens Logo
104 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
