Question about Dishwashers
Eaton viking dishwasher
My viking dishwasher is leaking at the pump when in the drain cycle. Are there any pumps available?
  • Harr Nov 05, 2007
    I replaced the viking with a Fridgedaire. Thanks
  • 640 Answers
It may not be the pump.if it leaks when you run a wash cycle then the pump seal may be bad but if it only leaks when you drain it,it seems that its a drain hose/piping connection.
Posted on Nov 04, 2007
yes the drain pump should start at this point so I would suspect a faulty drain pump,But try a reset first push and hold power button until lights reset then try a cycle if this fails to fix problem then I would suspect the drain pump.adrian,,,,,
Feb 11, 2015 | Viking Dishwashers
Viking DFB450 Tripping breaker in pots and Pans,normal, econo,cycle after prewash drains and fill. Heater or pump/motor bad? Does the pump have 2 speeds?
You may have a bad breaker. Have you tried replacing the breaker? I would not think you heating element was bad unless it didn't heat up. If the pump works at all then the pump should be ok. If it does not work and you have power going to the pump motor then it may be causing a phase to ground resulting in the tripped breaker.
Oct 05, 2014 | Viking DFB450 Dishwasher
Dishwasher keeps making suction sound though cleaning cycle is done
You made have a leak causing the drain pump to keep running, if you never worked on this unit before I would suggest you call a professional. If you have worked on this before then look for water in drain pan to unit, the reason is water has entered drain pan and caused the float to turn on pump, could be from the drain hose, leak in a hose, or the diverter. all this part are located unit unit in access area (small panel under large door).
Good Luck, I hope this helps...
Jul 21, 2011 | Viking 24 in. Professional Series VUD040...
Hi - my Viking dishwasher has developed a problem where the pump runs continuously, whether the power switch is ON or OFF. After the power is turned ON, the troubleshooting guide indicates that there is...
if you open the kick plate, you'll see the pan below the motor and check for leaks. The leaks will trigger the sensor to pump water out. Once you dry out the pan, the pump motor will stop and you should be able to reset the program.
Oct 15, 2010 | Viking DFUD042 Built-in Dishwasher
The draining cycle remaining on is an indication that the anti flood sysyem (polystireen float / micro switch) at the bottom has been activated via a water leak. This anti flood system puts the pump motor on and shuts the inlet water. Dry the water at the base / find the leak or blocked pipe causing the water and this should rectify your problem.
Jan 20, 2010 | Viking DFUD042 Built-in Dishwasher
Viking dishwaser turns on, but I can tell that it is not cycling.
Check the following to address this issue.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Jun 03, 2009 | Viking DFUD042 Built-in Dishwasher
Viking dishwasher that does not stop draining cycle - keeps on running
I have the same thing, unit pump keeps running, when I pulled it from under the cabinet, if you tilt it back a little it stops, as soon as you lower it back down the pump starts to run again. Getting code as too much water in the tank even though it is empty. PLEASE HELP!!!!!
May 17, 2009 | Viking DFUD042 Built-in Dishwasher
My Viking just stopped providing water - it goes through all the
You probably have a leak, in the pump housing area below the unit, which is causing the drain pump to run continuously.
Jan 26, 2009 | Viking 24 in. Professional Series VUD141...
Cycle just continues with the pot symbol blinking
disconnect the hose and run it into a bucket, is it pumping freely?.
did you check the trap for a blockage?
You may have a leak in the pump housing area below the unit, this would cause the drain pump to run continually.
Jan 24, 2009 | Viking Designer Series DFUD041 (Premium)...
Dishwashers Logo
583 people viewed this question
Top Dishwashers Experts
