Question about FMF Power Bomb Stainless Steel Header Kawasaki KLX 450 R 2008-2009
Myklx 450 r have oilpump gear broken after replacing the gear box dont operate
I can not change gear
Shredder No Longer Does
Office shredders, even the heavy-duty ones, tend to jam up over time and have to be cleaned up to restore operation. If you have removed all jammed paper bits and still get erratic operation, the shredding process may have bent or broken some internal parts. It is not economically practical to try to repair. Better to buy a replacement.
Dec 27, 2013 | Royal Jaws Shredder
Gear box 1994 sonata
Does it go into gear with the engine stopped?
If so, then check your clutch operation (manual) and check gearbox oil level and quality. Change if necessary.
More information would help.
Nov 15, 2012 | 1994 Hyundai Sonata
Hi guys, just researching the rmz450"s. What
i have 06 450 with 4 speed gearbox and have had no problems, its abit of a pain only haveing 4 gears cuz 1st is abit tall and 4th tops out at 120kph but its a great bit, just need to ride it hard and torque it as it loves to pull, a positive is u dont have to change gears as often ;)
Jan 30, 2011 | 2005 Suzuki RM-Z 450
I dont know where the gear box oil plug is
Gear box and engine oil are the same
Nov 23, 2010 | 2004 Yamaha YZ 450 F
I am having the same problem that everyone else with a chrysler 300 either has already experienced or will experience. My gear shifter stick is stuck in park. I read on this site a few minutes ago where...
Recalls are only for safety reasons. No one is going to get killed if your car wont shift out of park. There is a fuse, I dont know where you get info from. Usually its the same switch that works the brake lights, if they work, the switch and fuse is good. the shifter is most likely bad, just fix it. You can always call a Salvage Yard and buy a used one, then replace it when it fails again, and again.
Aug 27, 2010 | 2006 Chrysler 300
Tring to time oilpump but when hole on oilpump shaft is inline the timing mark moves out of timing hole working on harley 63 sportster
Bring the engine to top dead center and find a way to lock the engine in that position. When you lift the oil pump into position, you'll notice the the oil pump drive gear rotates when it engages the pinion gear. You have to turn the pump backwards so that when it rotates while you lift it up, the hole comes into alignment with the slot when fully seated against the case. Just like timing the distributor or magneto.
Mar 05, 2010 | 1979 Harley Davidson XLH 1000 Sportster
Need to replace oilpump is it hard/?????
well it involves dropping the sump and i dont recomand a novice do it
Jul 13, 2009 | 1991 Dodge Ram 350
FMF Power Bomb Stainless Steel Header Kawasaki KLX 450 R 2008-2009 Logo
65 people viewed this question
Top FMF Sport & Outdoor - Others Experts
Are you a FMF Sport and Outdoor - Other Expert? Answer questions, earn points and help others
