What is sustainability - Computers & Internet
  • Harrie May 12, 2014
    Hi taiseng ly, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Why do you ask a question like this on a technical forum for Motherboards? Computer boards that is.
Sony Plasma KE-42M1 -70 volt section is not stable when Y sustain board is
Sounds like the sustain board is damaged. Replace it as as card basis.
May 27, 2014 | Televison & Video
Casio Keyboard CTK700 The sound does not sustain when the key is pressed for 4 notes. How to rectify the same
sustain is typcially a product of the sound you have chosen, If you have a sustain pedal you can sustain any sound. you may also have some choices on the switches that allow special sustain, but I dont own a casio keyboard (I have yamaha) but they are nearly the same in operation. The easiest way to get controllable sustain is by plugging in a sustain pedal
Mar 24, 2011 | Casio Computers & Internet
A bought an Yamaha DGX 640 grand a week before and the note sustain for a longer duration and overlaps with the current playing notes. I checked the sustain in the function setting and it is also showing ...
The function setting is for the PANEL sustain (Page 68 of your manual)
The other method of sustain is by footswitch or pedal option. See page 13.
If you use a footswitch, it needs to be a normally open contact type. If you plug a Roland type in, it is opposite polarity and will sustain UNLESS the pedal is pressed. Make sure nothing else is plugged in the sustain jack... headphones that are inadvertently plugged in there would sustain.
Mar 06, 2011 | Yamaha DGX640 Music Keyboard
Sustain Pedal doesnt sustain long enough. can it be adjusted to sustain longer
You haven't told us what keyboard you have... HOWEVER the pedal itself will have no effect on the length of sustain as long as it is held. The decay of the sustain is controlled by a parameter in the keyboard itself and some allow it to be adjusted and others do not. We have no way of knowing about yours as you didn't tell us which you have.
Jan 19, 2011 | Compaq Keyboard
Is a sustain foot pedal similar to a tattoo machine pedal?
The sustain pedals have only two wires. Usually they terminate in a 1/4 inch mono plug.
yamaha USUALLY sustains when switch is closed. Roland usually sustains on a switch between the wires when the switch is open.
NO POWER should be supplied BY the sustain pedal... it is ONLY a switch.
Apr 19, 2010 | Casio Ctk 496 Electronic Keyboard with 61...
I want to plug in a sustain pedal to my very old yamaha psr 300 keyboard but there isnt a slot. the only slot it fits into is the headphone slot, but then you get no sound! can I get an adaptor for this?
Sorry to bring the bad news but the PSR300 does NOT have a connection for a sustain pedal.
It will however recognize a MIDI command for sustain so if you had a MIDI sustain pedal that emitted controller 64 code, you could use that.
It is UNLIKELY you would want to do this as such devices are not readily availablle. If you slaved this from another synth that had a sustain pedla capabilty you could play booth together and use the sustain of the other synth.
Dec 26, 2009 | Yamaha Portable Keyboard with 61...
Sustain is in reverse yamaha p-85
I have the same problem, But I have been using the same pedal since new. Infact it came with this pedal. Then suddenly it started doing this. Could I have changed soem setting by accident?
Jul 08, 2009 | Music
Sustain Pedal Opposite Effect
I found that if I plug in the sustain pedal BEFORE turning the power on, it works fine. If I plug in the sustain pedal AFTER turning the power on, then it works in the opposite way. Probably just the design. So I would try playing with that before doing anything drastic.
Feb 16, 2009 | Yamaha Full-Size Keyboard
Looking for the "sustain" feature
I don't think there is a setting for this directly, but there is an optional sustain pedal you can plug into it.
Dec 07, 2008 | Casio WK110 Portable Keyboard
Computers & Internet Logo
134 people viewed this question
David Payne
David Payne
