Question about Wolff Sunvision Pro 24S Tanning Bed
Turned sunbed on, #4 ame up then .01l. wouldnt start?
Zip code for 2311 Aspen Road, Ames, Iowa
2311 Aspen Rd Ames, IA, 50010 - Condos for Rent ' Zillow
www.zillow.com > Iowa > Ames > 50010
ZillowView 10 units for 2311 Aspen Rd Ames, IA, 50010 - Condos for Rent, as well as ... Ames Middle (assigned). 6-8 ... Nearby ZIP codes include 50012 and 50013.
2311 Aspen Rd Unit 101, Ames IA, 50010 ' Homes.com
Dec 16, 2015 | Computers & Internet
Ergoline sunbed, Sunbed lights keep going on and off while it's on cycle, it trips and the goes back on immediately does any one know what could be wrong?
Check your power supply rating of the circuit breaker that is feeding the outlet. The safety relay on the sunbed may be triggering because your circuit breaker won't allow enough current to flow to the sunbed. (The safety relay is far faster in actuating that the circuit breaker is to pop when drawing too much power.) Check the owner's manual and it will probably tell you you need a dedicated 16Amp circuit for the sunbed. These means the wiring has to be of proper diameter (gauge thickness) to handle the current. It shuts off and allows the sensor to cool down and then cuts on again... repeatedly. Also check the polarity of the outlet and ensure they match with the plug-in jack. (Often electrician's put the black wire and red wires on wrong poles inside the wall socket.. turn off the circuit breaker for the socket before changing them using an electrician's screwdriver with lamp inside the handle to assure the power is off first, please and make sure the green (ground) wire is connected also.)
Apr 24, 2015 | Health & Beauty
How do you do the lectrical wiring for a upright sunbed
Doesn't it just plug into an outlet? You should have an RCD already if you are going to install a sunbed.
If not or if you don't have an earth leakage breaker on your supply then call a qualified electrical contractor who will need to install a RCD for safety reasons I.e preventing death by electric shock.
Jun 17, 2014 | Cameras
The plug lead is getting very hot on my sunbed.why
can you tell me why the plug to my sunbed is red hot i darnt use is what is the problem
Mar 26, 2013 | Cars & Trucks
Is there are connection with sunbeds and cataracts?
Yes, there is evidence that sunbed use can cause damage to the eyes and the UV rays can lead to cataracts developing.
Feb 18, 2013 | Health & Beauty
Are there any tips you can give me for tanning bed safety?
Make sure you use a salon with trained staff. They should have a good knowledge of sunbed safety, timings, skin types etc.
Also make sure that you don't exceed the recommended time on the sunbed.
Protect your eyes from exposure as they can be easily damaged.
I am looking for a users manual for a alison sunvision v180 xxl sunbed to see how it is wired to the electrics
call 0808 108 7778 for all alisun sunbeds parts and trim, i have a 180xxl in my tanning salon
Jan 05, 2011 | Kitchen Ranges
UWE Speedfire Sunbed Turns Down
your problems is the hand controller is faulty had the same problem with a bed the other week replaced the hand controller and the problem was cured
Jun 01, 2009 | Office Equipment & Supplies
Wolff Sunvision Pro 24S Tanning Bed Logo
22 people viewed this question
Top Wolff Health & Beauty Experts
Steve
NOEL
NOEL
Are you a Wolff Health and Beauty Expert? Answer questions, earn points and help others
