Question about Car Audio & Video
What is negative fourteen times positive four?
  • 30 Answers
-56
Posted on May 07, 2014
48volt system i got 4 deep cycle 12volt batterys. Would like 2 know how 2 hook up.
Hi, you would connect the positive side of one battery to the negative side of the next battery. Then connect the positive side of that battery to the negative side of the next battery. Do that two more times until all four batteries are connected-positive of one battery to negative of next battery. The last battery will have 48 volts as compared to the negative terminal of the first battery. I can make a picture if you need it.
May 28, 2017 | Cars & Trucks
Can my eclipse 4 channel amp 36401 be bridged on bchannel. and what would the ems be?
You can bridge the speaker outputs; positive from channel two(2) , and negative from channel one (1) : Positive from channel four (4) and negative from channel three (3).
I believe this will provide 140 watts from each bridged channel.
Jun 09, 2014 | Car Audio & Video
I want to put 4 batteries together 4x 12v 7AH. and how many volts and AH would that be.
It depends on how you connect the batteries. If you connect the negative of battery one to the positive of battery 2, the negative of battery 2 to the positive of battery 3 the negative of battery 3 to the positive of battery 4 then the positive of battery 1 and the negative of battery 4 will give you 48v 7AH. (This is known as connecting in series.)
If you connect the four positives together. Connect the 4 negatives together it will give you 12v 28 AH. (This is known as parallel connection.)
If you connect the negative of battery 1 to the positive of battery 2. Connect the negative of battery 3 to the positive of battery 4. Connect the positive of battery 1 to the positive of battery 3 and the negative of battery 2 to the negative of battery 4. You'll get 24v 14AH from the connection of the positive of battery 1 and battery 3, and the negative of battery 2 to battery 4. (This is known as series parallel connection)
Jul 19, 2011 | Electric Cycling
I have 4 x 12v batteries 7ah each. if i put these 4 batteries together . how many volt and AH would this be. please reply . thank you
My light has just gone dim. brightness settings dont work.... help!
connect your display light connection with keypad light. if u can see display light connection in your display then there is a positive and three negative point total four. there u can connect positive to positive keypad bulb and negative 3 points with negative with keypad bulb in single wire.
May 26, 2011 | Apple iPhone 3G
I cannot find a diagram of how to wire a boss audio phantom p128dc dual voice coil subwoofer with there being 4 binding posts on each side of the woofer.
I will assume that you mean four posts total and not four on each side. It's a dual voice coil and you will need a jumper. Take a small strip of speaker wire and connect the positve and negative of one coil together. Take a close look, there is a dot on one positive and a dot on one negative. Jump these two together. Now wire the other positive and negative to the amp's positive and negative.
May 24, 2011 | BOSS AUDIO SYSTEMS P128DC Car Speaker
How do i wire these sony xs-ld106p5 10" sub they have four terminals i never seen this. i have a sony xm-zr1252 2channel amp 800 watts. im bridging them im only using one sub.
Dual voice coil. Positive from amp to either positive on speaker. Same with negative, then hook the opposite positive on the speaker to the negative on the speaker with a short wire.
Mar 23, 2011 | Sony XSLD106P5 Car Speaker
SOMEONE GAVE ME SOME BOSE 6X9 CAR AUDIO SPEAKERS. THE SPEAKER HAS FOUR HOOK UP WIRES. TWO TO THE TOP OF THE SPEAKER AND TWO TO THE BOTTOM. MY QUESTION IS WHEN INSTALLING THESE SPEAKERS IS IT OK TO MAKE...
Hook up the speaker wire like this...Positive wire to positive terminal on top then run a loop from the top positive to the bottom positive. Next run the negative wire to the negative terminal on the bottom then run a loop from the bottom negative to the top negative.
Dec 06, 2010 | Bose Car Audio & Video
This unit comes with a Four Conductor Cable to hook up power in. How are these four conductors hooked to power?
Disconnect the battery. Connect the green wire to the Negative terminal.Put a 20a fuse inline on the black wire and connect to Negative terminal.Put a 20a fuse inline on the red wire and connect to Positive terminal.
Put a 1a fuse on the yellow wire and connect to ignition switch - if you don't want to use the Ignition Sense feature, connect the yellow wire to Positive terminal.Re-connect the battery and test.
Nov 11, 2010 | Motorola VC5090-MA0QM0GH6WR Wireless...
Connections for speakers isnt just a positive and negative, its a connection block with four wires, how can i still fit new speakers
u should check out in which point the negative and positive wires fits properly and give sound out put the 2 wires r for woofer nd two are foe speakers
Jul 18, 2009 | Car Audio & Video
Car Audio & Video Logo
24 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
