Question about Sewing Machines
Brother PS-31 My needle snapped. I changed it and the next one snapped too. Think there's a problem with the bobbin holder which is getting in the way of the needle. Please help!
  • 11,896 Answers
Yes you are probably right. THe needle will actually have to be set higher. Make sure the bobbin and cover plate are installed correctly, than raise your needle height
Posted on Jun 22, 2009
Needle hits bobbin holder
Hi, sounds to me like you haven't refitted the bobbin correctly
Regards
www.electronicrepairs.co
Dec 27, 2013 | Brother CS6000i Computerized Sewing...
Cant get bobbin to catch
here are my suggestions, if none of them help then the machine
needs to be checked for a timing problem
try changing the needle ---make sure it's the right needle for the fabric
being sewed.--make sure the needle is inserted all the way into the
needle holder--and also make sure the needle is turned the right
way.
rethread the machine --top and bobbin
make sure to use every thread guide
make sure the bobbin is turned the right way in the bobbin case
if the machine is a front or side loading bobbin make sure the bobbin
case is inserted correctly
Dec 05, 2012 | Brother Sewing Machines
Brother se 400
try changing needles
also possible that the machine is out of time
Apr 09, 2012 | Brother SE400 Computerized Sewing Machine
My Brother XL-5021 sewing machine has stopped working and won't pick up the thread from the bobbin.
it's called being out of time,,and the machine can only be timed by a sewing machine repair technican,, because they have the tools for job
Feb 01, 2012 | Sewing Machines
I have a janome 1 step sewing machine and it keeps jaming. I have been sewing a thicker fabric recently with no problems, but now it jams after about 3 revolutions. I think something is wrong with the...
Do you have a manual for this machine? You need to follow the cleaning instructions and remove the needle plate, and clean under the bobbin holder. I've attached an image from my Janoma 6500 manual, I think yours has a top loading bobbin inside a magnetic bobbin case so this info should work for your model. There may be a little triangular shaped tool in your kit but any short flat blade screwdriver will remove the two setscrews. (always good idea to unscrew off the pressure foot and take out the needle first so you've got room to work).
PLEASE NOTE: If you've never pulled this bobbin area apart before, good idea to snap pics with your digital camera as you go to refer to and for reference next time!!
This uncovers the bobbin holder area, you'll see there is a black plastic holder which your bobbin goes into which has the tension device on the side and this then sits inside an outer metal casing which is the hook race. The bobbin holder is held there by a magnet underneath it and sits up against another little stopper. Look at the bobbin case and the stopper, there should be two red marks that must line up. Are they???
If the answer is no, then you need to remove the bobbin case, clean out any lint and fluff using your little brush that came with the machine, and you may also have pieces of thread caught in here too. Once clean, place the bobbin case back into the outer surround, under the other piece and lining up the two red marks. This is where photos are so helpful.
Now replace the needle plate and screws, pressure foot, pop in a new needle and thread everything up again.
If the thread continues to catch then you may have managed to damage the bobbin case; as they are plastic if they move out of position the needle can catch and burr or pierce them. If this has happened you could try to smooth out the burring with an emery board or similar. Or you may need to replace it if damaged badly. I've changed mine twice so far because I've pierced it with the needle several times.
I hope that this helps you out, good luck with your machine.tally_girl_3.jpg
Apr 13, 2011 | Sewing Machines
Needle broke of and I think it went into the bobbin area. Now I think that the timing is off . I have a bernina 180.
Have you removed the broken pieces? The bobbin holder snaps out with 2 side holders to remove broken needle pieces. I don't think that the timing can get off by a broken needle. My first original bobbin holder got damaged which was made of hard plastic, from embroidering, and I ordered a stainless steel model which is available from a Bernina dealer, and all works very well for the last 2 years, there was never any problem.
Feb 12, 2010 | Bernina Artista 180
The bobbin holder turns so the needle hits the holder and breaks.
Out of alignment means the timing is off...take it to a pro to have it cleaned and re-timed...if that's the real problem.
However, it seems that you think the issue is may be a bobbin holder that wasn't installed properly??
Do you have a top, side, or front loading bobbin?
Sorry...I don't understand: "If I manually turn the bobbin and holder clockwise just as the needle comes down, it goes all the way down without breaking or bending."
Do you mean that you're turning the hand wheel towards yourself...and that works properly? If so, it's probably not a timing issue.
If you have a metal bobbin case that you insert a wound bobbin into and then place that bobbin holder w/bobbin into your machine...perhaps the bobbin case just needs a slight turn in order to snap into place.
If that's not it, check your machine's manual to see what part might be missing...then, to find that small, shiny metal part, try shining a flashlight across the area where it was lost.
Apr 06, 2017 | Brother XL-2230 Mechanical Sewing Machine
Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Apr 07, 2009 | Brother LS-2125 Mechanical Sewing Machine
Bobbin holder
Make sure the needle is in the highest position before you try putting the bobbin holder in. The bobbin holder has a metal 'finger' which fits into a 'slot' in the housing and it only goes in if you have the needle up.
Mar 31, 2009 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
74 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
