Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Can i get detailed instructions on how to put my whirlpool washer mdl #LSQ9549PW6 back together?
    New Friend:
  • 29 Answers
5 Suggested Answers
Nicesuit
  • 61 Answers
SOURCE: I am trying to assemble the clutch on my whirlpool
why did you remove the clutch in the first place? I take it the clutch fits directly to the motor shaft, and is a twin speed i.e. when the motor spins faster the clutch closes and spins the drum faster? you should have taken pictures when dismantling the system this would have helped a lot, I could not comment on how without looking at the set-up attach a link to a photo or attach one
Posted on Jul 23, 2009
localwonder
  • 6784 Answers
SOURCE: Whirlpool Duet Mdl GHW9150PWO Washer stops
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Posted on Oct 16, 2009
machinetech7
  • 1344 Answers
SOURCE: what company manufactured lid switch PS350434 FOR WHIRLPOOL WASHER
3949247 is the actual part number for that lid switch, and you won't find a blow out of the thing taken apart because its a molded part and not designed to come apart/
Posted on Jun 04, 2012
richroth
  • 9472 Answers
SOURCE: how do you take apart a whirlpool top loader washer to replace the inlet valve
What is the model number of your unit?
Posted on Nov 21, 2012
Forgot how to put whirlpool washer back together
Go to www.repairclinic.com and enter model. You will be presented with a list of common replacement parts and may be able to view a generic Whirlpool disassembly video. Following the disassembly procedure in reverse should get your machine back together again.
Feb 25, 2017 | Whirlpool Washing Machines
Potential Causes
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool lxr7144eqo washer
Find the lid switch, it may be held on by two screws on the right side of the washer opening. If it looks broken, try to super glue it back together. If that doesn't work, bypass it by cutting and stripping the wires, and connecting them together. Use a good insulator, wire nut, or wire crimp. Put the wires back where they were, make sure they can't get bumped by the drum. The washer will now operate with the lid up, so be careful. Keep kids away from it, don't be sticking your arm in there when the machine is on.
Sep 07, 2008 | Whirlpool LSR7333 Top Load Washer
Putting it back together
Jacquee, they are going to hook onto the back panel and snap in, check this picture out...Catriverfd7bc24.jpg
Jan 16, 2008 | Whirlpool LSR7333 Top Load Washer
RE: Putting whirlpool washer back together
ok I know this is a problem heel i had trouble doing y first few but i learned a trick 1. make sure your front feet are off the ground at least 1/2 inch if they are rusted or broken place a screwdriver under the black rails. ok 2. wirh the cab. in front of you open the lid andhold it under that lip tilt it forward and then slide it toward the unit look down the lid hole you want the front edge to line up first as you slide it down there are two flat pins sticking up on both sides about 7" back fron the front corners these must fit into the cabniet you then drop it down slowly put the left clip on first then place you hand down the back right side pull it forward and install your other clip one note the fill dispenser will need to get under the cabniet before it will seat properly. connect your lid sw and close the console. let me know if this works and please rate this help
Thanks Gary
Dec 03, 2007 | Whirlpool LSB6200PQ Top Load Washer
My roommate removed the water in hose and I need to find a manual to put it back together
starslight07 You can find the repair manual for your washer here: http://tinyurl.com/32d5lu Good luck. Gendos
Jul 06, 2007 | Whirlpool LSR9434PQ Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
43 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
