Question about Tools & Hardware - Others
WHAT IS AN ELEC POWER?
BURN POWER SUPPLY INSIDE.
2 Suggested Answers
  • 3 Answers
SOURCE: my compaq laptop lost power supply
If you smell some thing burning from the charger get a replacement from somewhwre like Maplin.If you smell something burning from the laptop then take it to the PC shop an get expert advice.
Posted on Apr 14, 2010
How to turn on DPS1200ab power supply
get a power supply tester ($20) and if the ps is ok it will turn on when the tester is plugged in
Dec 11, 2012 | Delta Elec DPS-1200AB Power Supply Server...
Magnavox Television
There is an 8amp 250v 5mm x 20mm ceramic slow blow fuse on the power supply board inside the TV. The picture below shows the board with the fuse circled in yellow. If you had a big enough power surge it may have damaged other parts of the power supply beyond the fuse. Look for burn marks on the power supply board when you replace the fuse. If you need additional information just let us know tech@ccl-la.com
Jul 25, 2012 | Magnavox 40MF430B LCD TV
Picture is too wide
It may be due to power supply regulator inside the tv circuit. Your TV is working at overvoltage. most of todays TVs are working at 110v DC. It is derived from a switched mode power supply section inside the tv circut board itself. You must rectify it soon, otherwise it may lead to several problems later, including filament burn of picture tube. Contact an expert mechanic soon.
Oct 15, 2010 | Bush Televison & Video
Smells like hot electrical from the power supply. which way should the round fan face in the case? Towards the motherboard or out the top. Ran system check, it is not hot. I thought it might be new and...
Is this a new ATX switch mode power supply?
If the ATX power supply is old then the capacitors may leak and overheat to give a burn't smell. I would not advise you to try and repair these power supplies, they operate with dangerous mains voltages inside the case.
The ATX power supply has standard mountings holes that line up with the desktop case and can only be fixed to the case in one position.
If you have overheating problems you can add addition 12volt fan inside case, The fan should be positioned to draw air into the case.
Dec 04, 2009 | Dynex 400-Watt ATX CPU Power Supply
My Dell Dimension 3000 PC won't start when I push the power button
A.Bad Power On switch. (Behind the Power On button)
B.Bad power supply
C.Power supply cables have come loose inside the computer.
1.Power supply to motherboard. (20-pin connector on motherboard)
This connector has two pins in it for Soft Power On. The power supply does not connect directly to the Power On switch. The power supply connects to the motherboard, and turns on via Soft Power On.
ADVISEMENT!!
ALWAYS have the computer unplugged from power before reaching inside!
ALWAYS work on a table. DO NOT work on a bed, or directly on a carpet floor. These are high areas for Static electricity! Static electricity will silently burn out computer hardware components. You may not see it or feel it.
Touch the metal frame of the computer case, to relieve your body of static, BEFORE you reach inside.
Sep 30, 2009 | Dell Dimension 3000 PC Desktop
No picture no sound....Mitsubishi WT-46809
Your Power supply will most likely have to be replaced. Very common, the capacitor's inside these units due tend to get overheated and burn out. You can test power coming from the power supply with a voltmeter
Sep 30, 2009 | Mitsubishi WS-55809 55" Rear Projection...
My 600 watt amp for my car just now start putting a red light on
You may need a new power supply inside amp. If you where running speakers with to many watts it will burn up the power supply. Try unplugging all wires. Replug them in also check fuse underhood and inside amp
Dec 12, 2008 | Pioneer GM-7200M Car Audio Amplifier
TV sparks inside case
there will be a problem in powersupply.and ity is best to be checked by the technician in order to see the deffective parts..
Aug 16, 2008 | RCA 32V550T 32" TV
Tools & Hardware - Others Logo
20 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
