15 amp is a fair current draw and for it to blow after a few minutes means that there is a short in that circuit that is allowing a drain to earth that just exceeds the 15 amp. It is in the ignition part of the system and may be a bad connection ( water ) or a problem appearing in the ECM or relay . Run fault codes to find the area of the fault. Because it is taking time to blow the fuse, it will be difficult to find. Check all wiring for rub marks .
SOURCE: 2005 Land Rover Freelander aux fans staying on too
The first thing you need to note is if the temperature is normal whilst you are using the car, if it is then it is probably just a sticking thermostat and to be honest that is not a great problem, however if your car is running hot whilst driving you need to check your coolant level which can be seen in a spherical bottle at the rear (left side I think) of the engine compartment ( DO NOT OPEN THE TOP OF THIS BOTTLE UNTIL THE ENGINE IS COOL ) if the level of coolant is low top it up, also look for debris around the radiator grill and keep the air flow path open.
If everything seems ok but the fan still runs excessivly leave another thread and I will explain how to faulf find the circuit to check the thermostat.
regards
juyamah
SOURCE: 2004 Land Rover Freelander - Engine Shakes
Hydraulic lifters? I have been racking my brains for this one. Lifters will sometimes pump up when cold and then lose pressure as they get worked. Would explain why your camshaft died. Suggest you look at old camshaft, see the cams that were worn and replace those lifters. Only thing I can come up with!
